I have a 65''hdtv philips i just moved and found some of the liquid from the blue light on the board. i blew a fuse i just need to figure out wheather it is a 5 amp or .5 amp any ideas
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
It should be marked on the end of the fuse in very small letters and on the top of the circuit board--also on top of the board will be a location number for it---Give me the exact model number and the location number and I will try to locate the value and part number.
You understand the liquid is Glycol and very toxic?
It will damage and short any parts it gets on and only water will remove it. If you get it off wear rubber gloves and do not get any on your hands etc--If replacing the fuse lets the set work--
You have 2 choices---remove, drain and reseal the leaking tube or cut a piece of cardboard and insert it above the boards but under the tubes to stop any liquid from getting on the boards.
If enough glycol leaks out the picture tube will go bad--it is in a sealed area and keeps the face of each tube cool.
REMEMBER THIS LIQUID IS TOXIC! IT IS LIKE ANTIFREEZE BUT MORE CONCENTRATED.
IF this information helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 11, 2009
SOURCE:
No blue light after boot
Yes, I've seen the ballast bad after a lamp shorts out. It takes out a 1K resistor out in ballast. If original lamp blew up this could be your issue
Dec 29, 2013 | Toshiba 72HM195 72" HDTV
Olevia 537-b11, blue light won't come, even when power cord is replaced. Please help!!!!
Since you've already replaced the power cord and still the led light won't came on, this is an indication that the power supply board of your unit is dead. If it is not under warranty period(if so, avail it because the manufacturer will fix it for free) open the back cover and check the continuity of the fuse using the multimeter, if you found it open replaced it with the same current(ampere) ratings and then try to turn on the TV. If the replacement fuse blew again, this is an indication of more serious problem on that board. If the replacement fuse didn't resolve the issue, other parts on that board gone to malfunction as well. If this is the case, I would advice you to replaced the entire board for your convenient. The cost will almost the same rather than troubleshoot it. Check the actual part no of your board and check this LINK.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Sep 09, 2011 | Olevia LT37HVS 37 in. LCD HDTV
Is there a difference between a 15 amp light blue fuse and the same thing in a darker blue color?? The original light blue fuse blew, and I replaced it with a darker blue 15 amp, which in turn also...
No, the reason the fuse blew is because the positive lead in the circuit is connecting to a ground (negative) lead. There is a short some where in this circuit.
Mar 19, 2011 | 2004 Jeep Grand Cherokee
My blower blew a 3 amp fuse..i replaced it....the blower is running...but the ac wont kick back on
why did fuse blow thats what i would figure out? check for power at compressor it maybe locked up(you haft to reverse polarity to unlock)!! :)
Jul 05, 2009 | Heating & Cooling
Philips HDTV wont turn on
If your model number is 60PP9202 you dont have a bulb, you have three CRT picture tubes instead, and if the power light doesnt come on check the fuse on the power board. Remove the rear cover after unplugging the cord and look at the small board on the irght where the power cord attaches you will see a fuse its most likely blown.
Jun 27, 2008 | Philips 60PP9202 60" Rear Projection...
Low voltage power supply fuses blown
If the convergence power supply fuses blew you can bet that the convergence ICs need to be changed. The blue connector will be pressed down on the rear of the connector to release or pulled up on the back end of the socket. Ps dont forget to rate this.
Oct 11, 2006 | Toshiba 57H81 57" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
