I have a Sony KP-57WS500 CRT rear projection TV. The convergance has suddenly gone awry. The red and blue are both out of line and by quite a bit. The red is off by 1/2" or so. This TV has the automatic convergance button. Normally, you push this button and there is a sequence of flashing colored targets on the screen. Using these targets inan automated sequence, the TV self aligns. Not this time. Normally, this convergance adjustment process takes several seconds to complete. Now, when you push the button, the TV immediately returns to the normal full image. It's as if the auto circuit thinks the convergance is OK and it has no work to do. I know there is the real possibility that something has broken in there but, as I have some experience with CRT front projectors, if I knew how to get to the manual convergance setting mode on this set, I could certainly do a regular convergance adjustment. So, what is the way into the serviceman mode on this TV? Is this problem of a sudden lack of convergance a symptom of a problem that is greater than a simple adjustment can likey remedy? Thanks Tom
  • tomjoy315 Dec 12, 2009
    Thanks for your response. I'll get the parts right away.
    Tom
  • Televison & ... Master
  • 19,396 Answers
If the TV does not keep the presets and keeps loosing convergence, then using the service convergence procedure won't fix the problem.
In that case you will need to replace the two STKs mounted on convergence board. Those are the convergence ICs, see convergence board picture below:
The job consists in de-soldering old ICs and soldering new ones on convergence board. Better using coolant paste.
The convergence ICs are about $10 each (there are two of them). The job done by a professional is about $300.
The replacement ICs can be purchased on-line, from shops like Partstore or Vance Baldwin (encompass).
Here also all Service procedures for your Sony. Be careful when in service mode, some of the commands may damage the TV.
Service mode on NTSC TV.
Service mode on PAL TV.
Regards.
G.
Posted on Dec 11, 2009
SOURCE:
Screen turns blue and suddenly tv shuts off....red light on front blinking
The Blue CRT is the most likliest cause and will need replacement.You can verify by removing the Blue CRT drive board if the set powers up and stays on you will know the Blue CRT is causing the shutdown.
Feb 16, 2011 | Sony KP-57WS500 57" Rear Projection...
My TV (module # KP-57WS500) is in a weird double vision view as if it is in 3D. with blue,red, colors. top and bottom of the screen also curve into the center of the tv. worked perfectly fine night...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 24, 2010 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws500 flashes blue, green, red then turns off
Re-insering the flyback wire is usually very easy. Push in and give a slght turn and check to see if grabbed. It sounds as if there is more issues than flyback wire. TV should turn on without one crt connected
Dec 14, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws500
YOU HAVE A BAD CRT. CRTS ARE NO LONGER AVAILABLE FOR THIS SET. REPAIR COST WAS $1200-$1500
30 YR SERVICER
APGONZO
Jan 07, 2009 | Sony KP-57WS500 57" Rear Projection...
2 separate colors on screen
sounds like your convergence IC's have finally gone bad.. they seem to last 5 years on average.. have a look here: http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 19, 2008 | Sony KP-53V75 53" Rear Projection...
Sony KP-57WS500 57 inch TV
Probable convergence IC failure = replace both for reliability..T.
Nov 24, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws500
Probable bad blue CRT and if blue goes bad guess what might
happen to the red and green.........T.
Nov 07, 2007 | Sony KP-46WT500 46" Rear Projection...
BLUE SCREEN
I got this Sony KP-57WS500 57 in TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 25, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 Pictures problem
Your Convergence Correction Amplifier ICs have gone bad (STK329-110) They must be replaced along with the biasing resistors
www.electronix.com has the parts you will need plus I would suggest that you have a qualified TV repair person do the installation for you.
Make sure the traces on the circuitboard are good and that the solder connections are good.
But the ICs and resistors need to be replaced.
Thank you,
Shuttle83
Oct 30, 2006 | Sony KP-46WT500 46" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
