Question about Magellan RoadMate 2000 GPS Receiver
Screen frozen and will not pick up location...
The GPS satellites seemed to be in the green and good to go:however, the map does not pick it up. Its a frozen screen in a location I was months ago.
  • 1 more comment
  • pohenri Jan 22, 2008
    frozen screen take forever to come on
  • Anonymous Feb 04, 2008
    the screen is frozen, so i turned it off for three days. i just turned it on, and it is still frozen.
  • cjnj Feb 11, 2008
    when you turn it on, it is frozen from the location from you used it last. you can be in a differant state, until you fumble with the settings, sometimes that does it. and if it don't your screwed!
I had the same problem, and finally figured out to reset it. The reset button is on the left side under the strip. You need a pen to push it in. It took a few seconds to reboot but it came on normal after that.
Posted on Apr 15, 2008
My gps freezes when on speedo
Okay. I have to explain what happens when you use the speedometer option. While it is off, the GPS use using less cycles per minute to get the location from the satellites and sometime from ground beacons. When in speedo mode, it now needs more processor, memory, graphics speed and the power needed for the receiver. Now the unit is running about twice the cycles per minute to provide an accurate location to judge your speed.
How to work around this.
Best answer: Dont use this option! Its simple and you dont have to burn your noodle worrying about it.
2. If you must use it, then go into your display and map options and turn the map details and quality down. This will free up memory and CPU speed.
3. Turn tracking off. This will free up memory and CPU speed.
4. Use Garmin's mapping program to only load necessary map locations.This will free up memory space.
5. Be sure you are updated to the latest map data and firmware.
6. This can also be caused by the location of the GPS in the vehicle. On the main screen of most Garmin's, you press and hold on the corner near the icon showing the GPS signal. It will go to a more detailed screen of the satellites and signal strength. Stay in one place in an open area like a parking lot. Let the GPS locate itself first. Then relocate it where you can easily see it and you see 40% of signal or more from 4 or more satellites.
Have fun with what I gave you and good luck. VicFixx
Oct 27, 2014 | Garmin nuvi 1250 Car GPS Receiver
My screen is stuck on a location i am not at- it is basically frozen and does not tack my movement. and will not update- i let the battery run down and tried resetting factory settings what can i do to...
I had the same problem today. All I did was slide the switch to turn OFF and continued to hold the switch for about 20 secs. On restarting, the GPS started to search for satellites and also located me correctly on its map.
Dec 31, 2010 | Magellan 2036 GPS Receiver
I have just purchased a Garmin 1390 GPS with both NZ & Australian mapping, I am going to Oz today and donot know how to access the Australian maps, it just starts with NZ ones.
Press TOOLS (the spanner symbol)
Press SETTINGS (the spanner symbol) or LOCALE on some models
Press MAPS
There will be a tick beside whatever maps are selected. If the Australian map is not selected press the map name and it will be selected.
When you go to Australia the satellites should automatically pick up your location and load the correct map. If not or if you want to save an Australian location in favoutites before you go;
Press WHERE TO
When the screen comes up to enter the address you'll see NZ as the country selected
At the bottom of the screen you'll see an item CHANGE COUNTRY
Press this and you can select Australia
This should bring up the map of Australia and you can enter addresses there.
Dec 19, 2010 | Garmin nuvi 1390T Car GPS Receiver
I want to use the gps and navigator on my nokia 5800 can you please help
The Nokia 5800 has a built-in GPS satellite navigation receiver, which can tell you where you are anywhere on the planet. The 5800 also has cell-tower-positioning technology, which finds your location using the position of the nearest phone network mast if a satellite signal is unavailable. GPS is more accurate but can take a while (from 10 seconds to a few minutes, depending on how obstructed the sky is) to find your position ('Assisted GPS' is also present, to download the expected GPS satellite positions from the Internet and help speed up your fix.)
The 5800 also has a built-in mapping application called Nokia Maps, which shows you your location on a street map, tells you exactly how to get to another location by driving or walking, and can give details of nearby amenities such as shops, fuel stations, museums, etc. Nokia Maps uses both GPS and cell tower positioning to tell you where you are: the latter gives an instant rough position, while GPS data is used after the phone has locked onto enough satellite signals calculate its position. You'll know the phone is locked onto a satelite as the lock indicator at the bottom of the screen will turn green.
Other phone applications can also use the GPS receiver if required. For example the camera application can optionally "geotag" photos with your current location using the GPS receiver to work out where you are (click here to see our camera tutorial and find out more about geotagging). If you switch to the standby or menu screens while an application is using the GPS receiver, you'll see a little satellite icon in the top right corner of the screen to indicate that GPS is active.
How does the 5800's GPS work? Like all satellite navigation systems, the 5800 receives signals from many different GPS satellites in the sky, and calculates your position based on those signals, using a combination of triangulation, signal delay calculation and a lot of very heavy maths that you really don't want to know about.
Important Note: Satellite signals cannot penetrate buildings, so GPS satellite signals will be difficult or impossible to receive if you are indoors and away from windows. If you want to speed up the process of GPS showing your location, take the phone outside or place the phone next to a large window with a good view of the sky.
The 5800's GPS aerial is inside the top left side of the phone. If you want to get a good GPS lock make sure this part of the phone is uncovered
May 11, 2010 | Nokia 5800 XpressMusic Smartphone
Show map does not show current location
im going to assume the satellites are not locked on.
look up at the top right corner of the map screen, and there should be atleast 4 green bars..if not, the satellites have not locked on to your position yet and wil show the last location you were at when i lost the satellites.
take the unit out side in clear view of the open sky and turn it on, then hold the power button for ten seconds. after it turns off, hold the power button till it starts. let it sit outside for up to 30 minutes to aquire the satellites.
if that fails, go HERE and download and install the latest update. just follow the install direction and it should fix it.
Sep 30, 2009 | Magellan Maestro 4040 GPS Receiver
My Garmin 765t stopped navigating
There should be a small reset switch on the back of most garmin gps units. with the unit on, depress the reset switch with a pen tip or small object until the unit shuts off and restarts. It may take a little longer to pick up the satellite but it will reque the unit and unlock the navigation screen.
Aug 01, 2009 | Garmin nuvi 765T GPS Receiver
Cannot save waypoint on my magellan triton 200 gps.
Assuming you have installed the latest firmware. When you are on the map screen, just click on the center button and do a create a Waypoint and pick current location.
Or push the MENU button .. choose CREATE a WAYPOINT and when you GPS is on and has locked in on the Satellites . then create the Waypoint.
Mar 09, 2009 | Magellan Triton 200 Handheld GPS Receiver
Does not reset location
I too have sometimes to wait for 20 mins before my Roadmate picks up all the satellites it needs. The problem is worse if I'm surrounded by buildings.
I have at last decided to bin the Magellan as it's been nothing but trouble and Magellan Support just don't seem to care to respond.
Am now getting a Tomtom Go series with all preloaded, maps/ traffic/ cameras - it auto updates each time it's put on its cradle attached to PC/internet.
Nov 07, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 2000 GPS Receiver Logo
230 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
