Question about Franke WD-3428 Little Butler Garbage Disposer AIR Switch
Garbage dispoal air switch not working
The air switch must be held down to run the garbage disposal. Upon release it turns off rather than running until depressed again. I've had it 4 weeks.
  • 142 Answers
Make sure the airline is secure, a slight air leak could cause this problem
Posted on Dec 12, 2009
Testimonial: "Thank you."
Is there a reset button on the badger disposal?
If your garbage disposal won't run you may need to reset the garbage disposal using the RED overload protector button on the bottom. ... Turn on a cold stream of water and turn the disposal switch to "ON" position, the disposal should now run again. How to Reset Garbage Disposal InSinkErator
Use the wrench provided and turn disposer counterclockwise wise (of course the power is off.. do not repair it is better to replace with a new unit. Use 1/2 Hp minimum. Available at HD or Lowe's
Mar 20, 2018 | Electrical Supplies
Where is reset button on gemline garbage disposal
To reset garbage disposal follow these simple instructions:
  • Make sure that the disposal switch is in the "OFF" position.
  • Gently press the red button in to reset garbage disposal. ...
  • Turn on a cold stream of water and turn the disposal switch to "ON" position, the disposal should now run again
Oct 14, 2017 | Electrical Supplies
Garbage disposal won't stop running
Check switch. replace switch. If switch checks out, then replace disposal to avoid risk of overheating and in-wall short.
Copy following link to repair, troubleshoot and replace disposal:
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Add a comment as needed, or repost question with detail
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 18, 2011 | KitchenAid Batch Feed Garbage Disposal...
Garbage dispoal not working. The blades spin freely inside, the reset button has been reset, when you switch it on the moter makes a faint humming sound, and the allen wrench will not rotate either way.
You need a new disposal.
Free-rotating blades show there is no obstruction.
Humming says you have power.
Frozen allen wrench says bearings are rusted.
Motor is now overheating each timer electricity is turned on, and motor will overheat and stop humming.
At least the drain is clean and water is not flooding under the sink, which means you can continue using sink until disposal is replaced.
I wrote tips for installing disposal from days when I worked apartment maintenance:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Feb 01, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My garbage disposal does not have an electric on off switch it is turned on and off by inserting the drain stopper and removing it, I have removed the drain stopper but the in sinkerator continues to run.
The switch is bad that the stopper hits to activate the disposal...
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
Aug 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My garbage disposal runs but turns VERY slowly, nothing is stuck, it just turns slow and steady.
The motor has gone bad or got water in it...
heatman101
Jun 14, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: Just hums and won't run, even after assuring that ...
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
May 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My insinkerator Badger 5 is leaking from the bottom. It runs, but water runs out of all spots on the bottom; including the ara where the conduit runs into the unit - please help!
My bet is that the garbage disposal in not what is leaking... the connection to the bottom of the sink is leaking and running down the sides of the disposer...
Look higher and you will find your leak..
How is the best way to use a Garbage Disposal
http://www.fixya.com/support/r4062792-best_way_use_garbage_disposal
heatman101
May 04, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water doesnt flow thru and the disposal hums when u turn it on but doesnt run
Aparantly your dispoal has not run for several days or a week or so. In thedisposal are 100 little holes that the groud-up food must pass through and the water as well. If the disposal does not work(Turn) then food particles begin to block all the holes and no water moves. You need to get the dispoal fixed ( or maybe it is jammed) still need to fix it, or use the wrenchette that comes with it (or a 1/4" allen wrench) in the bottom center hole to turn it by hand; this will free the foor particles and allow water to move.You can also plunge the water; this pushes the food through the holes and solves the problem. But, it starts over again until you have the disposal working on its own.
goodluck, Macgivor
Oct 11, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Disposal blade locked up after finding bone piece
You need to purchase a garbage disposal wrench. It has a Tee at the top and extends down to a pivot with a large forked head. Drop this down and turn the blades until they start to move. Remove the wrench, run hot water and turn on your disposal. Both blades should now be free. There also might be a red reset button on the bottom.
Jul 04, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Franke WD-3428 Little Butler Garbage Disposer AIR Switch Logo
838 people viewed this question
Top Franke Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Franke Electrical Supply Expert? Answer questions, earn points and help others
