FixYa.com
Tags:
Lexmark X5150 All-In-One InkJet Printer
Problem printing w/ Lexmark X5150 (by 2 users)
By lawyer - usenet poster
I use Microsoft ME, and have an all-in-one Lexmark X5150,
with a USB cord, and the USB was pre-installed on my
computer, which is an e-machines. I've tried uninstalling
and reinstalling the printer numerous times, and using
both a USB 1.0 and 2.0 cord. neither helps. I can scan to
the computer, but I can't print. I get a print out
directly from the printer when I put the printer
cartridges in. But I can't even do a test page from the
computer. When i try to print something, the computer
thinks it is sending it to the printer and doesn't give me
any error message, but the printing job never gets to the
printer. I did notice when I check on printer status thru
the lexmark software that it says the printer is "output
to file" instead of to printer. The lexmark techs were
absolutely no help, and said the problem must be with my
computer, which is quite possible, but what is it? Anyone
have a clue? I'm about ready to return this printer.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on May 15, 2008
wyaUYDhhH
Best Solution
posted on Aug 10, 2005
Helpful (85)
Green1
Green1 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hiya! long time no talk!:(
Noel Paton (MS-MVP 2002-2004, Win9x)
Nil Carborundum Illegitemi
http://www.btinternet.com/~win noel/millsrpch.htm
Please read http://dts-l.org/goodpost.htm on how to post messages to NG's
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Bray
Bray - usenet poster
Rating: 0%, 0 votes
Yeah, it works great! Thanks! I've already spread the word
to folks I know to stay away from Lexmark. Like you said,
the tech support leaves much to be desired.
<anonym @discussions.microsoft.com>
Solution #3
Not Rated (0)
Bomber
Bomber - usenet poster
Rating: 0%, 0 votes
I'm too busy fixing Lexmark printers in XP!!!!!!!!!!!!
Cari
Solution #4
Not Rated (0)
Reynolds
Reynolds - usenet poster
Rating: 0%, 0 votes
Oh if only we could educate the whole world!
Cari
www.coribright.com
Solution #5
Not Rated (0)
Phoebe
Phoebe - usenet poster
Rating: 0%, 0 votes
 - makes sense !
I can cope with most of the Lexmark problems here - it's the others I have
difficulty with!<g>
Solution #6
Not Rated (0)
man1
man1 - usenet poster
Rating: 0%, 0 votes
Noel, you are now the official forever love of my
life!!!!  THANK YOU THANK YOU THANK YOU!!!! I've been
working on this problem for 2 weeks now, worked with
Lexmark techs for hours (not to mention the hold time on
the phone), looked at both lexmark.com and the emachines
web sites (I have an etower 566i2), and nothing to help
me. After looking at this board, I saw a note about trying
a USB 1.0 instead of 2.0 chord, so that plus your help,
and I was able to get my printer to print, and correctly
communicated to and from my computer. I was ready to bring
a sledge hammer to both the printer and computer! THANK
YOU! This Microsoft board is a life saver! From now on,
this is the first place I'm coming to if I ever have any
future problems with my computer or it's components! YOU
ROCK!!
Solution #7
Not Rated (0)
maartenw
maartenw - usenet poster
Rating: 0%, 0 votes
Temperance
Start|Settings|Printers - select your Printer, and r-click - select
Properties.
click on the Details tab
There should be a drop-down box labelled 'Print to the following port:' -
what does that say?
click on the down  arrow at the right of the box - that should give you the
list of ports available for the printer - one of them should be named USB-
<whatever> - highlight/select that one, and then click Apply, and OK
See if that turns the trick!
Solution #8
Not Rated (0)
Jimmy NY
Jimmy NY - usenet poster
Rating: 0%, 0 votes
Believe it or not, I've tried that too. It does say USB,
but specifically, it says "usb001 (unknown local
printer)". I'm wondering if the fact that it says "unknown
local printer" makes a difference.  I'm also wondering if
this particular computer (emachines) or the OS (Windows
ME), or even the combination of the two, has some sort of
problem with a UBS port. The computer thinks it is
communicating with the printer, but nothing happens with
the printer, and the status is "output to file". I've
about had it with this thing, but I'm thinking whatever
the problem is, if it is with the UBS port, then I'll have
that problem regardless of what type of printer I have,
and may have to get a new computer (it is extremely out of
date, in computer time, I got it in 2000). Does any one
know another way to change the "output to file", or if
there have been problems with either emachines from the
year 2000, or OS Windows ME in relation to USB ports?
Solution #9
Not Rated (0)
Beresford
Beresford - usenet poster
Rating: 0%, 0 votes
I agree on the taking back response. If I don't get this
printer working by this weekend, I probably will. I had a
feeling the output to file message meant it wasn't going
to printer, but I can't figure out how to change it. Do
you have an idea? Thanks!
printer. It needs to be
Solution #10
Not Rated (0)
2Pansy
2Pansy - usenet poster
Rating: 0%, 0 votes
Temperance - you need to reinstall the printer drivers.
First disconnect the printer
then uninstall the drivers/programs from Add/Remove Programs
Then Remove the drivers from Device Manager
Then Reboot - and install the Software again - following the manufacturer's
instructions completely.
Solution #11
Not Rated (0)
Beresford
Rating: 0%, 0 votes
I take it the thing works, then?<g>
Your experiences with the Lexmark are about par for the course - they seem
to be the most inept bunch of driver-writers imaginable.
Expect to have to reinstall the drivers every month or so, as they're not
likely to be stable:(
As far as their Tech 'Support' goes - I'm just surprised they didn't try to
get you to reformat and reinstall the OS (it's usually around the second
thing they suggest, from what I hear).
Whatever - I'm glad it worked for you,
 Good Luck
Solution #12
Not Rated (0)
Bouncy
Bouncy - usenet poster
Rating: 0%, 0 votes
Print to file means that the data is not sent to the printer. It needs to be
changed.
If you are unhappy with Lexmarks customer service/help, by all means take
the printer back.
Can you Help with these Printers problems?
dirty glass inside scanner
have you found a way to clean... Answer This...
cleaning the inside of Lexmark...
have you found a solution to... Answer This...
X5150 and Vista print issue
Purchased laptop with Vista... Answer This...
Fax Problems
Problem setting up fax, no... Answer This...
lexmark 5150 printer
printer pulls paper *******... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
