Question about Maytag Washing Machines
Maytag topload washer, model HA207: MY wife's description: During wash cycle, a sharp noise, burning rubber smell. I think it might be a belt. Any other likely possibilities? (Washer is 15-20 years old.) Is the belt & motor accessible from front? Only from the bottom (tilting back washer) If belt, can I replace it myself?
SOURCE: Burning rubber smell during drying cycle
get a new belt for the machine
Posted on Jul 08, 2007
clusterfx
  • 67 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
  • 39 Answers
SOURCE: very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Posted on Sep 16, 2008
  • 3 Answers
SOURCE: Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
Posted on Oct 01, 2008
  • 42 Answers
SOURCE: burning rubber smell
Even though manufacturers' love to advertise it, I personally would not load "too many items", as it may cause excessive normal ware and tear on your machine parts, motor, belt, etc.
Yes; the smell can be the belt and possibly your motor as well. The motor may be spinning, but the weight may be too much when the belt is engaging to rotate the drum. I would be careful not to burn the motor (About $120 - part only)
You should be able to access and inspect the drive-belt in the rear of the machine by removing an access panel (back of washer).
To replace the belt if fairly simple. Remove and re-install by wedging a long screw driver in between the belt and metal pulley (circular), while simultaneously rotating the pulley.
You may be required to make a belt repair if you start to have problems with your "washer not spinning" or "making a noise/not spinning"
Posted on Jan 26, 2009
Screeching sound; smell of burned rubber
What is the model number of the unit?
Oct 31, 2012 | Washing Machines
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
Maytag Atlantis washer
is the smell rubber or electrical? the pump could be seizing on it and burning the belt. check this out first.
Oct 25, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Washer whines during rinse belts burn
that friend is about the best possibility I can think of. This site has all your parts for the washer you have www.repairclinic.com
Mar 21, 2009 | Maytag LSE7806A Top Load Stacked...
Jan 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Washer Model: > LATLAT9457AAM Problem experienced: > High pitch sqeaky noise during spinning (draining) cycle. > Rubber burning smell(from transmission belt?) > Pulleys move OK with...
Most probably the bearings heating, which in turn heats the rubber seals and causes the belt to slip.
If there is no noise of metal on metal, you may be able to grease the bearings to get some more life out of them.
Taking the drum out is not an easy job though.
Jul 07, 2008 | Maytag Washing Machines
May 05, 2008 | Maytag Legacy Series Top Load Washer
Burning smell/noise with my Maytag Ensignia MAV7657EWQ Washer
it could be [motor] or 'condensur' for motor, starting to burn out or over heat, check drive belt as well for ware
Dec 08, 2007 | Maytag Ensignia 3.3 cu. ft. Top Load...
Washing Machines Logo
87 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
