How do I restore factory settings on windows NT?
Resetting
a Dell Latitude to the factory settings allows the user to restore the
Dell Inspiron to the original operating condition as if it was just
taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.
Step 1:
Before reset any Dell Latitude laptop, backup your all important data
and programs, otherwise you may lose it. It is recommended to use an
external storage device for your entire data backup, so that you couldn't lose it in any sudden occurring issue...
Step 2: Remove any other unnecessary external drive and restart your Dell Inspiron laptop.
Step 3: Press 'F8' key continue until 'Advanced Boot Options' wouldn't be appear.
Step 4: Use your keyboard arrow key to select 'Repair Your Computer' from the list and hit 'Enter'.
Step 5: Now click 'Next' and login as the administrator account.
Step 6: Click 'Dell Factory Image Recovery and Data Safe options', select your language option and click 'Next'.
Step 7: Click the check box 'Yes, reformat hard drive and restore system software to factory condition' and click 'Next' to start Dell Inspiron reset process...
This
process will erase all your previous changes that have been made to the
Dell Inspiron laptop and reset the configuration settings to factory
setting.
Feel free to get technical assistance for all type of Dell laptop at http://www.vtechsquad.com/dell-support/
Add a Commenthttp://itech-softblog.blogspot.in/2014/02/system-refreshreset-or-restore-in.html you can also try dell recovery utility
Sir windows NT does no provide a factory settings... best solution is to overwrite the OS with the same OS... to do so first backups your files and check for some restoration points on your system restore settings....
click the window button, press all programs then accessories then system tools...
if there is an oldest restore point choose it..
after restoring your system to the oldest settings... put the OS cd and let it autorun...
choose the overwrite the present OS or something like that... after reinstalling you will see all default settings and programs back where you want them.
SOURCE: restore factory settings to acer aspire laptop
Restore and recovery
The restore and recovery features allow you to restore or recover the system
from a factory default image, from a user created image, or from previously
created CD and DVD backups. You can also reinstall applications and drivers for
your Acer system.
1 Press <Alt> + <F10> or select Acer eRecovery Management from the
Empowering Technology toolbar to start Acer eRecovery Management.
2 Switch to the restore and recovery page by selecting the Restore button.
3 Select the backup point you would like to restore from. You can also
choose to recover the system from a factory default image, recover from a
previously created CD/DVD or reinstall applications and drivers.
4 Follow the instructions on screen to complete the process
SOURCE: how do i restore to factory settings my Dell Vostro 1000
Try here...(http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_336966&isLegacy=true#Issue3).........or here........(http://www.techsupportforum.com/forums/f108/solved-dell-vostro-1000-restore-from-recovery-partition-issue-445057.html)
SOURCE: restore factory settings on a Dell Latitude C510
Resetting
Step 1:
This
Dell Latitude laptop and reset the configuration settings to factory
setting.
