Question about Maytag Dryers
Dryer quit spinning.
I have a maytag dryer model DE410. The drum quit spinning. The heat and blower still work. How can I check to see if the belt is broken or if it's the motor that's bad? Your help is greatly appreciated. My email is craigapp@hotmail.com... if you need to answer me there. Thank you so much. Craig
  • craigapp1 Dec 11, 2009
    Is it easy to change the belt on a Maytag Dryer?
  • 1,305 Answers
If the blower is working, then it's most likely the belt, a belt pulley or a tensioner spring.
Open the dryer, it will power off, and then spin the drum by hand. If it moves with little resistance, it's your belt.
Posted on Dec 11, 2009
SOURCE:
Maytag electric dryer de410 trouble shooting! How do I remove the cabinet?
There should be an element behind the spin drum,take cover off the back to undo drum.
Jul 26, 2014 | Maytag Dryers
Maytag model no: de410 Looking for manual
I need the 6 digit model number from your dryer.
May 28, 2008 | Dryers
Maytag ensignia
follow this steps and fix it. God bless you
Drive Motor
The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer stops the motor might be defective. If the dryer stops and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. Also try rotating the drum by hand with the belt off, it should rotate freely. If the drum doesn't turn freely, determine what is causing it to bind. The dryer motor can't be tested easily. If the drum turns freely and the blower wheel is clear, and yet the dryer still keeps stopping mid-cycle the motor may be defective. it will need to be replaced. It is not serviceable.
Enter your model number to see parts for your dryer.
Help me find my model number
Drum Roller Axle
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely which can overload the motor and the dryer stops. If the dryer stops mid-cycle, remove the belt and spin the drum, it should spin freely. If not, check the rollers and roller shafts.
Drum Roller
This dryer has drum support rollers. There will always be two supporting the rear of the drum, and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If they are worn out or start binding the motor can get overloaded and the dryer stops. If the dryer stops mid-cycle, check to be sure the drum turns freely with the belt removed. If not, check the rollers. Do not lubricate the rollers or roller shaft, lubrication will attract lint and cause the roller bearings to wear out faster. If the rollers don't turn freely, replace them. The roller shaft can often be reused, unless it has worn down. Clean the shaft thoroughly before installing the new rollers.
Drum Support Roller & Axle
This dryer has drum support rollers.There will always be two supporting the rear of the drum and on some models there may be two supporting the front of the drum. The rollers must spin freely to work properly. If the roller axles are worn out the rollers may not spin freely. If not, check the rollers and rollers shafts. If they are worn or do not turn freely they will need to be replaced.
Drum Slide, Glide, or Pad
The front of the dryer drum is supported by small pieces of plastic-like material. As the drum rotates, it slides on these plastic pieces. If the dryer stops mid-cycle, it may be that one or more of these plastic slides or glides has worn out. When they wear out the drum can start binding and put strain on the motor. The motor then shuts down and the dryer stops. Check the glides for wear and replace as needed.
Drum Bearing
The drum bearing supports the rear of the dryer drum. Over time this bearing will wear out and may cause several different problems. If the dryer stops during the cycle it may be that this drum bearing has worn out and is putting too much strain on the motor. If the belt is removed and the drum spins freely, the drum bearing is probably not worn out. If the drum bearing is worn out, there may be some grinding or squealing, and the drum will be hard to turn.
Drum Support Bearing
Dryness Control Board
The dryness control board shuts off the dryer when the clothes have reached the level of dryness selected by the user. If the dryer stops too early, the dryness control board might be defective. This is not very common and other possibilities should be checked first.
Jul 21, 2013 | Maytag Dryers
The drum on our Neptune Dryer has stopped turning. It still heats up, but the drum just won't turn.
If the heater and blower work then th eprblem is with the drum turning system
This includes the motor ( which we will presume works because the blower does),the belt (Item #25 in the Cylinder, heater and bulhead diagram) and a spring and idler pully (Items 20 and 21 in the Base, Motor, and blower diagram)
Most likely problem is the spring broke releasing tension that halds the belt to the motor pully and drum. Second most likely is the belt has stretched.
You need to open the unit to determine where the problem lies.
Here are diagrams and parts listing for that machine.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MCE8000AYQ/3048/0151200?searchedModel=MCE8000AY&blt=
May 24, 2011 | Maytag Neptune MCE8000AY Electric Dryer
Belt broke on Maytag dryer DE410. I purchased a
The squeak may be coming from the drum rollers, check them to see if they need lubrication.
I recommend that you use a good grade of machine oil to lube them such as 3 in One oil. Lube them at the shaft of the roller. Also check the rollers to see if they have flat spots on them, if they do then they will need to be replaced.
Recheck your location of the idler arm bracket with pulley to see that you have it in the right location and that the spring is also in the right location. Look for wear spots on the frame and idler arm and match them up.
Good Luck,
I hope this helps
Oct 12, 2009 | Maytag Dryers
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
Heat Element is working and drum spins, but no air is blowing?
First make sure that the dryer is vented properly, then check the blower wheel. A common problem is for the center of the blower wheel to get rounded out through wear and tear, allowing the blower wheel to spin on the shaft, thus not spinning at the same speed as the motor. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 07, 2009 | Maytag MDE308DAYW Electric Dryer
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer Drum Won't Spin
Reach inside and grab ahold of the baffle. Try to spin the drum, it should have resistance. If it spins freely you have a broken belt. Hope that helps. Dave ww.washermd.com
Dec 16, 2008 | Maytag Dryers
Dryer stopped working
does this drum go round, if not replace the capacitor which in most models is fastened to the main motor, if this doesn't cure the fault you could be looking at a replacement motor, assuming you have checked for any jamming of the drum, does it rotate be hand as well a working motor will just buzz if the drum is jammed hope i have helped, if so please rate me well
Oct 06, 2007 | Dryers
Dryers Logo
205 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
