Question about Berkeley Forge G-PH001PSS Open Flame Patio Heater
The pilot light will not turn off after the burner is on... I think it over heats, because it will just shut off after several minutes.... any suggestions? Thank you
    Champion:
  • 274 Answers
The pilot light must remain on, even when the main burner is on, to keep the thermocouple hot. If the thermocouple cools off, the gas flow shuts off. It sounds like something is interrupting the gas flow. If this is an LP heater, try replacing the regulator.
Posted on Jan 11, 2010
SOURCE:
My majestic fireplace lights and the burner lights and I turn on the switch and the burner stays lit for a minute or two then I hear a click and the burner and pilot light shut off
yes this would appear to me to be the classic symptoms of a bad thermistor , this little device proves that fire has lit (via heat) and keeps gas valve open , otherwise gas valve times out and shuts off (safety)
Oct 15, 2016 | Majestic Heating & Cooling
Hearthmaster fireplace shuts itself off
So the main burner does fully ignite, but after a minute everything shuts off including the pilot? May just need the pilot cleaned
Sep 12, 2017 | Heating & Cooling
Bryant plus 90 intermittent start-up
That's an intermittent problem. Could be: dirty filter, dirty blower wheel, dirty secondary heat exchanger, dirty evap. coil, weak or damaged high temp safety, loose wire connection, fault at control board, poor air flow. Just about 100 guesses! Could be's don't solve anything. Check for cleanliness. Clean flame sensor(flame rod that burner flame comes in contact with). These are the first I would try.
Mar 10, 2017 | Heating & Cooling
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
No flame
Several steps here to check...
turn power off unit and back on
set thermostat to heat
watch for pilot to ignite..igniter should glow orange or cherry red or spark if its a spark type ignitor
Did you see a pilot light ignite?
If not you probably have a bad igniter.
If pilot lit....in a little bit you hear a click of the gas valve opening..then the main burners will ignite
If you see the pilot and the main burner lights but goes out in a few minutes or immediately you may have an issue of the "high limit" switch tripping.
Is the blower fan turning that blows air out of your vents?
are all your vents open in your house? too many times i see homes with almost all vents shut.
Jan 08, 2011 | Goodman GMS90703BXA Heater
Wall mounted CBN30T, pilot goes out
IF its balance flue it could be blocked . Burner or orifice blocked lack of air to pilot slightly blocked thermocouple defective .
Mar 03, 2017 | Desa International CBN20T Heater
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
Pilots lites , holds ok for minutes,but once move
Hello KJGreen, It sounds, based on your description, as though the thermocouple is faulty and should be replaced. If the pilot light stays lit and you've left it on for several minutes before turning the knob on to light the log set, then that indicates that the thermocouple is bad.
The thermocouple is a safety device (heat sensor) designed to stop the flow of gas to the burner in the event the gas flame goes out and the pilot goes out. The sensor will only allow the gas valve to open once it has reached the preset temperature.
To confirm that the thermocouple is defective, I would light the pilot light and allow it to remain lit for up to 10 minutes before I attempted to turn on the log burner. If, after 10 minutes, the log burner still won't stay lit, then you know that the thermocouple needs to be replaced. Otherwise, the burner should light, since after 10 minutes, the sensor should be hot enough to signal the gas valve to open.
If you are going to have this replaced, please make sure you use only an approved supplier, since an incorrect replacement part could cause an unwelcome malfunction of the gas log burner. Safety should be primary when dealing with open flame burners.
Hope you find this Very Helpful and best regards!
Nov 23, 2009 | Vanguard International Infra Red - Large...
After a few minutes of burner heating the water, gas shuts off.
A couple of things to check:
If possible, remove the pilot gas assembly and clean the gas jet and thermocouple - they can get carboned up and stop working properly. Make sure the pilot flame and deflector is aimed properly and making the thermocouple glow red hot. If the problem persists, you may want to replace the thermocouple and also check the propane regulator.
Apr 20, 2009 | RTO Atwood Water Heater - 6 Gal LP
Furnace runs about 1 minute, then total shutdown
What type of gas supply line do you have? Is it black pipe or copper? If it is copper, there can be a film like substance that builds up on the inside of the copper. The debris will the get caught in a pre screen where the supply enters the valve thus cutting the supply of gas to the unit. Also, the thermocouple may be bad. You didn't say that you replaced it. Try replacing it as well. Also, you could have a limit switch turning the system off and thus cutting the gas off completely but it is highly unusual for the pilot to be cut off as well unless the pilot is being blown out when the gas is shut off. Also, turn the unit to fan only without calling for heat. Using a flame of some sort, put it into each baffle of the heat exchanger. If your flame is being blown around in one of the baffles, then you have a hole in the heat exchanger and what is happening is that the roll out switch is cutting the unit off and the air still moving through the heat exchanger is blowing the pilot out. I have seen this actually happen. If your furnace is in excess of 15 years old, it does need to be checked for possible holes. If it is in excess of 25 years old, it is a huge possibility that the unit has already developed a hole. If you feel hair coming out of one of the baffles, then shut the unit down immediately and have it replaced!
Apr 05, 2009 | Heating & Cooling
Heating & Cooling Logo
158 people viewed this question
Top Berkeley Forge Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
Are you a Berkeley Forge Heating and Cooling Expert? Answer questions, earn points and help others
