Question about Panasonic Lumix DMC-TZ3 Digital Camera
How do I transfer pictures from on my memory card to my computer? I have plugged the cable into the camera and into the computer is there somthing else I need to do. the camera is panasonic DMC-TZ3 thanks
  • B_o_B_1 May 11, 2010
    What is your operating system (XP or Vista). If you have a Mac, I can't help you.
    Brigadier General:
  • 11,967 Answers
Easiest way...buy an inexpensive card reader to download your pics to a folder you create on your desktop...works every time.
Posted on Dec 11, 2009
How to transfer internal memory pictures to computor
You have two options:
1) Remove your memory card from the camera, if you have one. Then connect the camera to your computer using the supplied USB cable.
2) Use the "Copy" command in the Playback menu to copy the pictures from the internal memory and then download the pictures from the memory card. Once the card is plugged into a card reader attached to your computer, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer.
If you need a manual, you may download a copy from here.
Sep 16, 2012 | Nikon Coolpix S9100 S-9100 26248 Black Hd...
Ricoh Caplio R5. Have used cable transfer of pictures to my PC twice , but now the plug will not enter the camera socket.
hi!!!
try to replaced your usb plug
or removed the memory card and plug in
memory card reader!!!
if you want to move the pic to the computer
Sep 23, 2008 | Cameras
I took pictures on my camera without a memory card can i still download my pictures
I'm glad to provide the steps to transfer images from Internal Memory of the Camera. When the camera does not have a memory card in it, the images are saved by default to the camera's internal memory, which holds different amounts of images based on how many megapixels are built into the internal memory and what image quality and compression are selected in the camera's menu. Once a memory\picture card is inserted in the camera, the camera then saves the photos to the memory\picture card and ignores the internal memory.
There are two ways to transfer the images from the internal memory.
  • To transfer photos to a computer from the internal memory using the USB cable, first remove the memory card from the camera. Then, when the camera is connected, the computer and software will only see what is in the internal memory and transfer those photos or videos. During the transfer process, the computer makes copies of the photos and videos-the original images remain in the internal memory. After the transfer is complete and the camera is safely disconnected from the computer, the contents of the internal memory can be deleted by using the MEMORY FORMAT function in the SETUP menu in the camera's menus.
  • The other way to transfer photos from the internal memory is to transfer them to the memory\picture card using the BACKUP function in the SETUP menu. If there is no memory\picture card in the camera, the BACKUP function is grayed-out. During BACKUP, copies of the images are transferred to the memory\picture card-the original images remain in the internal memory. After the BACKUP is complete, the internal memory can be cleared by removing the memory\picture card and formatting the internal memory using the MEMORY FORMAT function in the SETUP menu in the camera's menus.
Note: When the camera is connected to a computer using the USB cable with a memory\picture card in the memory\picture card slot, the computer will only see the contents of the memory\picture card.
Thanks for understanding. Please let me know if you require any additional help.
Jun 16, 2011 | Olympus Cameras
Trying to transfer pictures taken on nikon coolpix L4 to apple imac computer. i have the cable plugged in to computer. camera says preparing to transfer but doesn't transfer. what can i do? i have...
Welcome to Fixya
Try the alternate way of transferring the pictures to your computer instead of using cable.
To download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer. Once the card is plugged in, it will appear to your computer as a removable drive. Just drag&drop pictures from the card to the computer's hard drive, the same way you copy any other files.
Thanks
Mar 06, 2011 | Nikon COOLPIX L4 Digital Camera
I receive a "communication error"
To address the present problem make sure the camera is off before plugging in the cable either to the computer or the camera. Also make sure the batteries are up to charge, low batteries or batteries that fail during file transfer will corrupt the memory card. With batteries up to charge plug the cable into the camera and the other end into a USB port and turn the camera on. Now, I would like to suggest that you invest in a memory card reader these are fairly inexpensive and can be bought as a single reader for the type of memory card you have or as a multiple card reader for pretty well every memory card that's on the market. To use a Card Reader it plugs into a USB port and the memory card is removed from the camera and inserted into the card slot. The computer recognizes this card reader as an external hard drive and files can be transferred to your computer Hard Drive with ease. One thing you must remember with any external device and that is you need to do a safe disconnect or eject make sure the device is shut off and the file information is downloaded before you remove the memory card or the files/card can become corrupt. Okay once the transfer is completed insert the memory card back into the camera and format the memory card. Don't delete the pictures at this point Format the memory card. Every time you download the pictures to the computer Format the memory card.
Jan 14, 2011 | Canon PowerShot SX20 IS Digital Camera
How do I transfer my pictures from the internal camera memory onto the computer?
One of two ways.
1) Remove the memory card if one is installed. Connect the camera to the computer using the USB cable. Transfer pictures normally.
2) Copy the pictures from the internal memory to the card, then take the card out of the camera and plug it into a card reader. Transfer pictures normally.
To copy pictures from the internal memory to a card, press the playback button (right-pointing triangle) to enter playback mode, press MENU, then select "Copy".
You can use the USB connection or the card reader, whichever you're more comfortable with, whichever you normally use.
Oct 18, 2010 | Nikon Coolpix S3000 Digital Camera
I am user of L20 I have lost the cable to transfer pictures from memory card to pc how can I get transfer the pictures through card reader? Thank you
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo catalog/transfer program, such as Nikon Transfer.
If you want to continue using the camera as a card reader, you can order a new cable at
http://shop.nikonusa.com/store/nikonusa/en_US/pd/productID.213503000
Oct 05, 2010 | Nikon Cameras
My memory card is full and I want to transfer to my computer. I tried to transfer to internal memory but it says there isn't enough space. Anyway to transfer all at once instead of tagging individual...
Connect you camera to the computer using the USB cable. It will be shown as a removable drive(If the autorun is enabled windows should list the option to transfer pictures.Choose this option if it does so). Open the drive and and transfer the pictures to your computer.
Hope this helps,
Sai.
Dec 24, 2009 | Kodak ZD710 Digital Camera
Transfer from camera memory
there might not be a way of transferring picture within the camera. However the SD card _should_ have resolved the memory full issue. Plug the camera into a computer with its USB cable. Transfer the pictures to the computer and delete them off the internal memory. Assure that your SD memory card is functional by trying it in another camera or in the slot on a computer.
Nov 30, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Transferring pictures from camera
Go into the Setup menu, select "Copy", and copy the pictures from the internal memory to the memory card. Then you can copy the pictures to a computer by using a card reader.
Nov 09, 2009 | Nikon COOLPIX L18 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
136 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
