Question about Whirlpool GR460 Electric Kitchen Range
Oven not working
Baked cookies-- after using oven noticed the next day that the program screen was blank-- unable to use oven--this happened once before and the screen just appeared after abput 3 wks and started working again so did the oven
  • 725 Answers
You can turn your oven off at the breaker and reset it and see if that makes it come back on. If it doesn't, you will have to replace your control board.
We have all the parts that you need for all your appliances, so contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 7 PM CST and we will get the correct parts out to you asap.
We know you want to get cooking againasap so don't hesitate to contact us asap.
We look forward to working with you. Thanks, Ella
Posted on Dec 11, 2009
When I was using the stove...the door locked and F-3 showed up what happened
it sounds to me like you have a self cleaning oven and may have somehow gone into the cleaning cycle
Oct 07, 2012 | Whirlpool Accubake RF362LXTT Electric...
When pushing the button bake and broil the red light starts to blink on lock ? this happened after i woke 1 morning n noticed there was no time where the clock was, it was all dark n nothing worked, after...
if the clock is blank it's bad and you have to change out the clock assy. if that's your model number MEW5527B it says your part is
WP74009198 and it's around 260 dollars but this must be an older wall oven because nobody has it in stock,you can go here,put your full model number in and go to control panel and look up your computer board or clock assy. same thing
https://www.searspartsdirect.com/model-number/MEW5527BAW/3048/0125300.html
Feb 06, 2018 | Maytag MEW5527B Electric Single Oven
Can i bake cookies on my sharp carousel with bake setting. can i use an ordinary micro safe plate or do I need something else?
yes you can bake cookies in the carousel on BAKE I suggest those new rubber looking bake plates help a lot to reduce the moisture that makes them soft.
I think they are silicone rather than rubber, i am sure you know the ones I mean
Thanks for using FIXYA
Oct 11, 2009 | Sharp R-1850A Convection/Microwave Oven
Getting oven back on fahrenheit instead of celsius
Actually for the Whirlpool Accubake I just figured out, the bake button didn't work, but holding the broil button did the trick.
Apr 19, 2009 | Ovens
Cannot bake cookies in my gas oven
First, I would buy an oven thermometer to use in the gas oven to see if the temp you set is what you are getting. Second, Perhaps, you used a different pan or cookie sheet in one vs the other? Also the cookies perhaps should be a little closer together as they bake. A cookie sheet with a lot of uncovered surface will get hotter than one with a bigger load. (ever notice the instructions for biscuits or cinnamon rolls say "sides touching"?, same reasoning. if you put a few rolls on a big sheet or pan, you'll burn the bottoms, gas or electric.) Hope this works for you, when you get happy using the gas, you won't want an electric again.
Dec 16, 2008 | Tappan TGFS26C Gas Kitchen Range
Display is blank, no heat no bake
The oven control panel has failed. For more tech help with this issue and a place to order parts I suggest you go the link below, it is where I go for parts and help. You will need to model number available. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 28, 2017 | GE Monogram ZET3058SHSS Stainless Steel...
The clock started flashing as if the power went out. Then when we tried to
The plug receptacle may be bad. Check the plug for proper tension. If feels loose, have the receptacle replaced. Inspect the plug for discoloration. (a sign of a bad receptacle)
May 22, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Lighting the oven
I have similar problems with several 20-inch Avanti ranges. Solution(s); Get a new range, different brand. Cool the range between lightings.
Dec 21, 2006 | Avanti DG241BS Stainless Steel Gas Kitchen...
Whirlpool GR460 Electric Kitchen Range Logo
74 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
