Advueu Technology ADV178 17" Flat Panel LCD Monitor Logo
Posted on Dec 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need an ac power supply 19vdc-3a Adv178B modelEZ17F Where can I find one...Please help.
Anonymous
Level 2:
  • Expert 105 Answers
  • Posted on Dec 11, 2009
Anonymous
Expert
Level 2:
Answers
105
Questions
0
Helped
59127
Points
369
How do you wire a Nitecore NPS200 54.6AH Portable Power Station. Need diagram for a bench power supply?
Question edited for clarity (make model (what it is)
Just buy plugs to suit the voltage for your bench use.
  • AC Output:
    • 110V Version:110V~1.4A 60Hz, 150W, 300W Surge
    • 220V Version:220V~0.68A 50Hz, 150W, 300W Surge
  • Cig Lighter Port:12V=10A, DC Output: 12V=10A (Total 120W Max)
  • USB Output:5V=2.4A, 12W Max Each Port
  • USB QC Output:5V=2A/9V=2A 18W Max
  • USB-C Output:5V=3A/9V=3A/12V=3A/15V=3A/20V=3A 60W Max
https://www.flashlightworld.ca/products/nitecore-nps200-54-6ah-portable-power-station
Laptop compaq hp 6910 power supply pinout
laptops
that is an HP secret.
ask them at HP.com
its external power pack ac to dc.
most are 19vdc.
I need a replacement Power pack 12V-3A 36W. Can you please tell me where I could get one from?
Cherryl, You could try local stores that sell computers and electronics, Walmart, the source, staples etc. Check the attached links,for power pack/charger, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Premium 4 8 1 7mm Replacement Power Supply Cord Laptop Battery Charger...
Genuine Asus LCD Monitor 12V 3A 36W Ac Adapter Charger ADP 36EH
Laptop AC Adapter 12V 3A 36W 1 7 4 8mm
Amazon ca power supply 12v 3a
1helpful
I need to buy a power supply for a sidewinder force feedback wheel. where do i get one help
I suggest you buy it now. It is very rear to find
http://www.ioffer.com/i/x03-73497-microsoft-adapter-ac-cord-12v-1-3a-sidewinder-189530392
Please rate 4 stars if this is what you were looking for.
Need a ac adaptor for a Protron PLTV-32. MODEL LU32A1A3. INPUT 100-240V 50-60Hz 3.0A MAX.Output +24V-6A +12V-3A
I found one through Powerpayless.com at http://www.powerpayless.com/ac-dc-power-adapter-for-protron-pltv-32-pltv32-lcd-tv.html. It works great!
2answers
I have lost the original power supply for my dell 1701fp monitor. I have a power supply that I think may work as a substitute until I can replace the original. I need to know, what the acceptable voltage...
What ever you use, it must be REGULATED power supply that will maintain 14vdc output, rating at 3A. These regulated power supply can easily maintain the output voltage within +/- 5% with input AC voltage range from 100~240vac.
Linear regulator power supply may not work since it has slow response time to regulate the voltage.
http://www.amazon.com/dp/B002D1E8NE/ref=asc_df_B002D1E8NE1376531?smid=A3IZHOEADOGAP0&tag=dealtmp386264-20&linkCode=asn&creative=395105&creativeASIN=B002D1E8NE
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Need power cord for CM2017 Balance monitor 19Vdc 3A , connector is one single post Nothing comes up online, no one has heard of Balance Brand
As a workaround, simply get yourself a switchmode power supply that has the spec's 19 V DC @ 3 Amps, now, carefully cut of the end of the "Old" Power Jack, and the end off the "New" power jack, and Join up the wires, usually the "Inner" one is Positive, +, and the "Outer", or shield, is Usually negative, -, If you have a meter this should be used to check, connections. Otherwise just ensure you are correct. That should get you going, even if you cannot find an original, in fact, you may even find, that the PSU, you get has "Multi-way" changeable ends.
HP L2000 Sudden shutdown wont power up power supply good
what makes you think the ac park is ok
19vdc measured with a voltmeter proves this , only.
a 2005 (as old as) Laptop
its not new, things this old do fail.
Laptops are like dog years.. 7:1. so yours is 84years old
to fix a desktop is super easy
to test a laptop takes greater skills, the take down. is tricky
we take out the battery,
the the pack just make the fan run in the PC
does it>? if not the pack is bad.
or the MOBO regs are shut down. (shorts on any thing inside
some times the 19vdc is ok, at that pack
then 1 inches inside the PC its dead due to that silly power jack loves to fail. but not taking the thing down and testing that
its all just a guessing game...
the only insight there is on electronics, is power first.
no power, no joy.
test the power feeds first.
4helpful
I NEED A POWER SUPPLY FOR RCA WHP150C HEADPHONES
See this solution:
http://www.fixya.com/support/t558556-input_voltage_lost_power_supply_whp
If you're looking for a generic ac adapter, the specs of mine are: 19vdc @ 200mA, NEGATIVE polarity.
Important...the center pin is NEGATIVE (most center pins are positive).
Power supply cord
Any power supply providing 19V DC at 3 Amp with a positive tip connector will do.
Hope that helps.
Top Advueu Technology Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Advueu Technology Computer and Internet Expert? Answer questions, earn points and help others
