Question about Philips Magnavox DVD/VCR Dual Player
Dvd door won't open
I have a Magnavox MWD2206 vcr/dvd combo unit. All of the sudden the dvd door won't open. It doesn't matter if you try on the unit itself or the remote. Nothing. And if you turn it to dvd (rather than vcr), after about 15 seconds it goes back to vcr.
  • 6 more comments
  • Anonymous Feb 04, 2008
    dvd door will not open.have changed batteries in remote.functions properly when playing a vcr.
  • Anonymous Mar 01, 2008
    Have the same exact problem....what is going on with these?
  • gary mattson Mar 28, 2008
    dvd door will not open when using the remote or the manual controls
    on the front of the unit. everything hooked up properly
    dvd wont open when using remote control or the manual controls on the
    front of the unit. unit is hooked up properly.
  • lonestarjean Mar 31, 2008
    I have the same problem. It used to work fine until I watched a few VHS tapes which worked great. Now I can not get it to stay on DVD or get door to open. What is up?
  • gopackgo Apr 27, 2008
    I unplugged the unit for about 15 seconds and plugged it back in. Works fine now
  • tcwilless94 May 22, 2008
    what is the solution? ours does the same thing -- suddenly we can not retrieve the DVD! Or VHS from the machine.
    Help
  • Anonymous Mar 26, 2014
    power go off 5 seconds after pushing the tape.
Mine just did the same thing about 1/2 hour ago. Found this site and tried advice of gopackgo - worked perfectly!
Posted on May 26, 2008
HOW TO GET A STUCK DVD DISK OUT
not sure if your is listed but here is link to manuals Free Magnavox DVD VCR Combo User Manuals ManualsOnline com perhaps if you can get the case off then you can carefully eject the disk
Mar 12, 2015 | Magnavox MWD2206 DVD/VCR Combination...
GO VIDEO model 1030....VCR works fine...DVD..nothing happens...door won't even open?
Combo units have this essential flaw--if one half fails you are usually done especially if the DVD side fails.
If Door does not open either a disc is jammed inside the mechanism or the mechanism is out of alignment or damaged.
Good argument against buying these units--DVD individual parts are rarely sold--only (if available) would be the entire DVD unit itself--not cost effective to repair.
DVD players are now real cheap (see some for as little as $20) so if not a simple jammed disc or something like that buy a DVD player.
Apr 05, 2012 | GoVideo Go Video DVD/VCR Combo
I have a Magnavox DVD/VCR combo that I have lost the remote to. I have bought universal remote after universal remote trying to get one that will work the DVD player or at least will setup the date and...
Universal remote does not work with Magnavox combo of dvd vcr, because no dubbing button. But magnavox has many remotes that will NB884, NB559, NB677.NB627 which also works on Sharp dvd vcr combo.
Nov 05, 2010 | Philips Magnavox Learning Universal Remote
DVD won't eject from magnavox MWD2206
Do u see a small hole in the front plate of the dvd player?
if you do ur in luck, unravel a large paper clip to make it straight, then very slowly push it straight into the hole until you see the dvd open.
If no hole then u will have to open the case while it is unplugged.
May 24, 2009 | Philips MWD2206 DVD Player/VCR
Magnavox vcr/dvd combo--dvd's play about 1/3 of the way then quit
sounds like bad pick-up unit (optical eye). these will heat up and reduce the fm envelope signal causing the optical eye to not read disc info. not worth repair. (it may could use cleaning, but usually a dirty eye will effect the movies from the beginning not after warm-up. mch
Mar 08, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Tv keeps turning itself off
This Sounds like you need to have the flyback replaced on the main board!
Dec 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Need remote control code
I found that on the back of the 2205 it said that the unit was made by Funai. I looked in the Innovage book and found that the codes for Funai DVD are 231 and 233. 233 worked on mine. Good luck.
Dec 26, 2007 | Philips Magnavox DVD/VCR Dual Player
DVD door will not open
Turn off the unit, Unplug it. wait 30 seconds. plug it back in. Press the power button on the unit press source so that its on dvd and press eject
Aug 25, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips Magnavox DVD/VCR Dual Player Logo
893 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
