I am trying to drasg and carry music from my documents to my blackberry and it keeps giving me an error # )x80070052 I am using Windows Vista
  • 4,472 Answers
Most likely you have too many files in the root directory. if you already have a previously created folder you could copy everything to a folder and then from now on copy mp3's into another directory. Here is a link that also explains the problem as well.
http://www.quickonlinetips.com/archives/2007/09/how-to-fix-error-0x80070052-on-usb-flash-drives/
It if fairly common. Worse case scenario. Copy everything off of it. Then either create a folder to save things into or format it then create a folder so you are not filling up the root directory.
Thank you,
Lee
Posted on Dec 11, 2009
Please help! I keep getting an error code: 0 x 80004005 when trying to open a document. What does it mean? Thanks
It means that the operation (opening the document) failed for unspecified reasons. These errors are quite common, and can be caused from any number of things.
To assist you further, I require the following information:
What program you are trying to use to open the document?
What version of Windows you are running (Windows XP, Vista, or 7)? Does the error come up when you try to open other documents?
Mar 28, 2011 | Computers & Internet
My itunes wont let me open it its saying unkown error has occurred 13010
Hi crag81,
I understand you are receiving error 13010 when trying to open iTunes. If you are using iTunes 8.0.2. I suggest you upgrade (but if you cannot): Remove the Genius database In the "Finder" go to the /username/Music/iTunes/ directory and delete the "iTunes Library Genius.itdb" file. This should allow the program to launch again. This file will be recreated upon first use of the "Genius" feature.
If you are windows, Remove the Genius database In the "My Documents" go to the /My Documents/Music/iTunes/ directory and delete the "iTunes Library Genius.itdb" file. This should allow the program to launch again. This file will be recreated upon first use of the "Genius" feature.
NOTE: If your using Vista or WIN 7 go to /yourusername/Music (one directory back from My Music (from above =)),
Nov 13, 2010 | Apple iTunes
I am trying to download itunes and it keeps coming unknown publisher.what can i do???
i had this problem , first you should remove you exitune and you i tune library and after that you should install a new i tunes
Microsoft Windows XP and 2000 \Documents and Settings\[your username]\My Documents\My Music\ Microsoft Windows Vista \Users\[your username]\Music\this is the addres of your itunes librarry delet that and make a new one
i hope it can help you
Dec 25, 2009 | Apple iTunes
I get an intellisync error 0x8004fd28 when trying to Sync my blackberry
Hi, When attempting to synchronize between the computer and the BlackBerry smartphone, the Error 0x8004fd28 message appears on the BlackBerry Desktop Manager. This is due to the intellisync folder is corrupted. To resolve this issue, you need to complete the following steps: 1. Close BlackBerry Desktop Manager. 2. On the computer, navigate to the appropriate folder listed below: · If you are using Windows® XP, go to C:\Documents and Settings\\Application Data\Research In Motion\BlackBerry\Intellisync · If you are using Windows Vista?, go to C:\Users\\AppData\Roaming\Research In Motion\BlackBerry\Intellisync Note: If you are unable to view the above folder refer to additional information section on instruction on how to view hidden files 3. Delete the Intellisync folder. 4. Open the BlackBerry Desktop Manager. Note: If the BlackBerry Desktop Manager attempts to synchronize at this stage, synchronization will fail. 5. Configure the BlackBerry Desktop Manager for synchronization by completing the following steps: a. Click Synchronize. b. Click Configuration. c. Click Synchronization. 6. Synchronize calendar appointments. OR If there are one or more corrupt entries on the BlackBerry smartphone . Take back up and clear the database on the BlackBerry smartphone. I Hope it helped you. Thank you for using ' Fixya ' and have a nice day!!
Nov 16, 2009 | RIM BlackBerry Curve 8310 Smartphone
Error: DSSMA: invalid state: 70. i cant surf on my inbox.
you will need to follow the steps listed below
2. You need to install a BlackBerry OS file that is specific to your device. The original version, as supplied by the carrier, is the safe choice, but you can use any model specific version. This is not supplied on your BlackBerry CD, Ref: 3 links to BlackBerry's download pages.
3. Once the OS has been installed, you have to prepare it for the device.
Select Start / Computer and select the Drive C: Icon.
Open Program Files / Common Files / Research in Motion / AppLoader.
Navigate to the bottom and delete the file Vendor.XML file.
4. You are now ready to restore your device. Verify that BlackBerry Desktop Manager is NOT running. Plug the device directly into the computer's USB port.
We are about to venture into the bowls of the beast. Windows is not suitable for this job, we are going to invoke the Command line interface with an option switch.
Windows XP: Start / Run... / Command
Windows Vista: Start / Command (type this into 'start search')
Jun 20, 2009 | AT&T Blackberry Curve 8300 Smartphone
Error 0x80070091 the directory is not empty
There is most likely a hidden or read only file located in this dir. Have you tried to view the hidden files?
Jun 11, 2009 | Microsoft Windows Vista Home Premium for...
Windows Media Center proplem ( unknown Audio Error 80040155 )
Go to start : All Programs: Accessories: right click on Command Prompt, click run as administrator. click continue: you should see C:\Windows\system32> type there regsrv32 wmp.dll It should look like this C:\Windows\system32>regsrv32 wmp.dll
(make sure to put the space in between 32 and wmp)
An info box will appear. Click Ok then restart.
That should fix it!
Mar 23, 2009 | Microsoft Windows Vista Home Premium with...
Downloading using vista
I've found a couple of solutions, some might not be exactly what your looking for. EDIT: Soultion #2 should be your answer...
Solution #1 - Change the Documents Folder Template
  1. Click the 'Start' pearl (button)
  2. Under your name and icon, you should see the 'Documents' option.
  3. Right click 'Documents' and then select properties.
  4. The window should pop up and read 'Documents Properties'
  5. Click the 'Customize' Tab
******* Soultion #2
  1. Go into your documents folder.
  2. Off to the left side you should see the 'folders' section
  3. Under 'Desktop' you should see the folder with the windows account username. Go into that folder.
  4. Under the the folder you should see all of the default Vista folders, EX: Contacts, Deskop, Documents, etc.
  5. You can right click each folder and select properties, then under the 'Location' tab you can select the location of all of the files, and such where you want them to be.
Hopefully this helps you out, my directions could have been a bit rough if you have any problems please reply to the post!
Mar 20, 2009 | Microsoft Windows Vista Home Premium with...
Installing Sprint Smartview on Windows Vista --Dell laptop
Smartview is supposed to work with Vista. Did you right-click on the install file and run as administrator?
If you can not get it to work there is a work around.
First, download and install the BlackBerry Desktop Manager software. After installation, plug in your BlackBerry and start up the software for the first time. Open the Options -> Connection Settings… window and set the connection to USB. Plug in the BlackBerry, enter your password if applicable, and Vista will find the device and install a “standard modem”.
Open the Control Panel
Network and Internet
Connect to a network
Set up a connection or network
Set up a dial-up connection
Select Standard Modem
Dial-up phone number is #777
Connect.
Everything should work, some have reported faster speeds using this method over the Smartview program.
Mar 13, 2009 | Computers & Internet
Open Questions:
51 people viewed this question
k24674
Marvin
Marvin
