Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
I never had a password installed..and I have someone using my connection... I want to share my 2 computers together so I can use the printer on with both computers How do I set password on my D Link?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 105 Answers
How to make mp760 wifi
This printer has only an USB connection that connects to your computer and cannot connect to wireless network directly. You can attach this printer to a wireless printer server/router to enable wireless printing.
OR
SET UP A SHARED NETWORK PRINTER
Any printer that is connected to a computer and is connected on a LAN can be configured so all other computers on the same network can print to this printer. This means the computer with the printer attached to it MUST be booted up at all times when other computers want to access the printer. You need to install the printer driver on the computer and configure it as a Shared printer. The other computers on the network need to add this printer to their computer. Follow these steps to set-up a shared network printer :- 1. Connect the printer to the computer and install the printer driver. 2. Open Printers and Faxes - right click on this printer and click Sharing - click Sharing tab and click Share this printer, and then if you wish you could change the Share name, then click OK 3. Right click on the printer - click Properties - click Print Test Page to confirm printer installation. Follow these steps to configure the computers on your network :- 1. Open Printers and Faxes - click Add a printer - Next - select a network printer, or a printer attached to another computer - Next. 2. Select Browser for a printer - Next 3. Click on and expand the Microsoft Windows Network down to the computer with the printer - Next 4. Select Yes for - Use this printer as the default printer - Next - Finish 5. Right click on the printer - click Properties - click Print Test Page to confirm printer installation.
Dec 02, 2012 | Office Equipment & Supplies
Tip
Setting up a Shared Network Printer
2. Open Printers and Faxes - right click on this printer and click Sharing - click Sharing tab and click Share this printer, then if you wish you can change the Share name, then click OK
3. Right click on the printer – click Properties - click Print Test Page to confirm printer installation.
1. Open Printers and Faxes – click Add a printer – Next – select A network printer, or a printer attached to another computer - Next.
2. Select Browser for a printer – Next
3. Click on and expand the Microsoft Windows Network down to the computer with the printer – Next
4. Select Yes for - Use this printer as the default printer – Next – Finish
5. Right click on the printer – click Properties - click Print Test Page to confirm printer installation.
on Dec 19, 2009 | Office Equipment & Supplies
Can I connect 2 computers sharing a KVM Switch to 1 USB printer?
You need a USB printer share device such as this one http://www.amazon.com/IOGEAR-2-Port-Printer-Sharing-GUB211/dp/B001SEB45M/ref=sr_1_1?ie=UTF8&qid=1328912939&sr=8-1
Feb 10, 2012 | Brother Office Equipment & Supplies
I have a retail store with 7 x Win 7 Workstations. i have 1 x Epson Tm-T88iii thermal receipt printer connected and installed on lpt1 port on my 1 workstation. We use a Dos application for our sales. The...
Hi, details below for creating a ersistent connection from LPT1: to you \\computer\\printername printer. Do the following on the other workstation that is not printing.
Use the net.exe command to establish a persistent connection.
To do this, use the following syntax at a command prompt:
net use lpt1 \\printserver\sharename /persistent:yes
where printserver is the print server that is sharing the printer, and where sharename is the name of the printer share.
For example, to map LPT1 to a printer shared as Laser1 on a print server that is named Pserver, follow these steps:
1. Click Start, and then click Run.
2. In the Open box, type cmd, and then click OK.
3. Type net use lpt1 \\pserver\laser1 /persistent:yes, and then press ENTER.
4. To quit the command prompt, type exit, and then press ENTER.
Note In Windows XP, non-administrative users cannot map an LPT port to a network printer path when the LPT port exists on the computer as a physical parallel port.
Apr 12, 2011 | Epson TM-T88III Thermal Printer
HP Color Laser Jet printer CM1312nfi: scanner no longer working; when I try to scan, receive error on printer:scanning error, cannot connect. Printer is networked. This error occures only on a networked...
Go to your network and sharing center. Choose homegroup and sharing options. Change advanced sharing settings. Under your home or work profile, scroll down to file sharing connections. Switch to enable file sharing for devices that use 40 or 56 bit encryption. If that does not work, under password protected sharing, select "turn off password protected sharing". This is not recommended if you use your computer in multiple locations (laptop). I have found that turning all of these features off, running a scan from the printer successfully and then turning them back on, Windows seems to be comfortable allowing the printer to connect to the computer.
Jul 22, 2010 | HP LaserJet CM1312 All-In-One Printer
Problem networking printer
Share the printer. give everyone access or enable Guest account create password. go to the other computer look for the computer which the printer is connected. Right click on the printer the install. i will automatically install the drivers to the computer. and make sure all computers connected are in the same WORKGROUP.
Oct 29, 2009 | HP OfficeJet Pro K5400dn Photo Printer
How do I connect my printer to be used by 2 computers?
Install it on one computer and share it by right clicking it in the Printers and faxes folder and choosing Sharing. And secondly connect the 2nd computer to the shared printer.
But if you're on a network and your printer does have a network port you should install the the printer on both the machines by choosing network printer as you're installing it.
Mar 16, 2009 | HP Officejet 5610 All-In-One InkJet...
Missing password and printer connection
are you using internet router for your wireless network? you download software for your internet router or if you want reset your internet router this will refresh your router and give the manufacturer original settings with "admin" user without password.
you can also connect your printer to other computer and share it so that other computer on your network cab use it. just open the share printer in the network and windows will install it or go to add printer and look your printer using network.
hope this will help you.
Nov 24, 2008 | Linksys Ultra RangePlus Wireless Routr...
Help please....printer name does NOT appear
You must have a network set up, and you must enable file and printer sharing on the desktop. The laptop and the desktop should be in the same workgroup. Some firewalls will cause this problem.
Start with the network setup wizard in Settings/Network.
Jan 25, 2008 | D-Link NETWORK CARD DFE550TXREF Network...
How To Configure FM114P or FR114P for an Internet Connection and Printer Sharing
There are three steps: 1. Configuring the router for Internet access 2. Installing and configuring the print server 3. Adding the printer to the Windows configuration To Configure the Router for Internet Access 1. Connect the modem to the router's Internet port and your LAN computers to the router's LAN ports. 2. Shut down your LAN computers. (Power them off.) 3. Power off the router. 4. Power off the modem. 5. Power on the modem. 6. Power on the router. 7. Start the LAN computers. 8. Enter 192.168.0.1 in a Web browser's address. 9. Type username and password (by default admin and password). 10. Click Setup Wizard to configure the router's Internet access. To Install and Configure the Print Server 1. Install the Printer Server Driver program on a computer. 2. After installation, make sure to select the Run Print Port Setup now box. 3. Click Finish. Print Port Setup runs, showing you the firewall and the printer. 4. Click Port 1. 5. Click Add. A pop-up message says whether a port was created, then the Add Printer wizard starts. To Add a Printer With the Windows Add Printer Wizard 1. Continuing from the last section (or clicking Start > Settings > Printers > Add Printer), click Next. 2. Select Network Printer, and click Next. 3. Click Next again (leaving the port as LPT1). 4. Select the manufacturer and printer model of your printer. (If your printer does not appear, you need to get the CD or floppy that came with the printer, and use Have Disk to specify the file location. Note that it is looking for a file that ends with .inf.) 5. Click Next. 6. Change the printer name to something users on your LAN will recognize easily. 7. If prompted by the Add Printer Wizard about sharing: DO NOT enable sharing! Now test the printer. Other information about Windows configuration is available in Windows help in the article "To connect to a printer on a network".
Feb 19, 2006 | NetGear FR114P Router
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
99 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
