Question about Kitchen Appliances - Others
Magic chef breadmaker
Help,
I have a magic chef automatic breadmaker 1.5 lb. model # cbm 250-2. I need a drive belt for my bread machine. My machine works great i just need a replacement belt. any help would be greatly appreciated
  • 33 more comments
  • Okie Stan Feb 04, 2008
    My model 250-2 Magic Chef shows to be a 2-lb. Bread Maker.
    Same problem - drive belt failed and I have not been able to find a replacement.
  • Anonymous Mar 02, 2008
    Have the same problem, the belt shredded, need a replacment
  • Anonymous Mar 04, 2008
    Magic Chef 250-2 broken belt.
    same here .... I am going to check a vacuum repair shop, or an auto parts store.
    I called the magic chef #, they gave me a parts store #, who gave me Wal Mart #, who gave me Magic Chef #. Took 1 1/2 weeks to come full circle.
  • denniss265 Mar 08, 2008
    The drive belt on my magic chef cbm 250 broke, and I can't find a replacement or a substitute. Has anyone found a solution to this problem?
  • Miss Judy Mar 08, 2008
    I need a drive belt for my Magic Chef CBM 250 Breadmaker. I have searched many websites & am unable to find one.
  • Anonymous Mar 12, 2008
    I need a replacement belt for Magic Chef Model 250-2. Thank you !
  • Anonymous Mar 27, 2008
    my breadmaker (magic chef) runs okay, it's just that the drive belt has completely fell apart and was all over the bottom in little pieces.
  • Anonymous Mar 30, 2008
    need drive belt mod 250-2
  • Anonymous Apr 06, 2008
    I also had my belt break. I am trying to find a belt to replace it. I also had the same problem getting through to Wal-mart.
  • Anonymous Apr 21, 2008
    same machine , not a belt problem, but need paddles that mix the bread. Is it true that Maytag owns magic chef??
  • Anonymous Apr 23, 2008
    broken belt on cbm250 magic chef gave us nbr for walmart.com.......nice lady there but no belts
  • Lenaswill Apr 24, 2008
    Where can I purchase a replacement belt for my D280-2 Magic Chef Bread Maker? Thanks for any help
  • Anonymous Jun 14, 2008
    The belt on my Magic Chef bread maker also broke. I'm going to try vaccum belt.
  • 1lollipop Jun 29, 2008
    The belt on my bread maker broke to on the CBM250-2. Why do they sell something that you can't get replacement parts for??
  • peggyhuscher Jul 09, 2008
    I also need a belt for my 250-2. I have used this machine maybe a half a dozen times! I have made the same round of phone calls, ending with someone at Wal-mart not having a clue how to help me.
  • cristina382 Aug 02, 2008
    I have the same problem. Black grit fell out of the bottom and it quit mixing. Are there any parts for such a thing? CB
  • Anonymous Aug 06, 2008
    We just took the machine apart.
  • Anonymous Aug 18, 2008
    same problem
  • Anonymous Aug 26, 2008
    I have the same problem. I will post again if i find a solution
  • vincent l Sep 02, 2008
    need belt drive for magic chef breadmaker
  • Anonymous Sep 06, 2008
    same problem
  • Anonymous Sep 09, 2008
    have the same problem need a belt.
  • bhmjones Oct 18, 2008
    I have the same problem. My belt broke in the middle of the kneading cycle, I was able to use the [ole-Chevrolet-fan-belt-fix.]
    I used a pair of my wife's panty hose fashioned into a temporary belt. Just make you a loop so small that you have to strain to get it onto the pulleys and it seems to work ok for a little while. I'm definitely glad to know a vacume cleaner belt will work.
  • trimjoe Dec 24, 2008
    Machine started making weird noises; found blet in pieces when bottom was removed. Need to find a belt for this model, if available.
    Thanks,
    Lisa
  • Anonymous Jan 09, 2009
    Any solutions yet for the Magic Chef CBM 250-2 belt? My belt also disintegrated during knead cycle.
  • buttrflyer Jan 10, 2009
    same problem, hopefully we can find help soon!
  • emjay62 Jan 13, 2009
    I also need a replacement drive belt for CBM250( 250-2)
    The toll-free number is no longer available
  • Anonymous Jan 26, 2009
    I have same problem. Tried vac an sewing center with no luck.
  • michelle_692 Mar 11, 2009
    i am in need of the kneading blade for a magic chef 310
  • deehain Mar 13, 2009
    i'm in need of a new belt for my bread machine
    Magic chef model # cbm 250
  • Anonymous Apr 06, 2009
    I have the 2lb. Magic Chef automatic bread maker that needs a new belt also. any one know where they can be obtained???
  • joannesd May 20, 2009
    I have a Magic Chef CBM250-2 and also need a drive belt. Has anyone found replacement belts?
  • Anonymous May 22, 2009
    need a belt for a magic chef bread maker 250-2 if they can not get this part they should have to give a full refund.by law if the company can not
    sale you the parts you need.they have to give us a full refun
    New Friend:
Drive belt can be purchased from amazon, take a look: Live Conveniently with Rosewill Home Appliances. Wish you best of luck.
Hank
Posted on Jan 12, 2015
Recently I acquired a second hand magic chef bread maker CBM 250-2. I noticed the first time I used it there were pieces of black rubber stuff underneath, and before the cycle was done for the maker, the paddle stopped working. I ended up with an okay loaf of bread. After removing the bread container, turned the maker over and removed the bottom plate (easy to do) and saw the remains of the belt. I called one local appliance store and was told the nearest store for bread maker parts was over an hour away. Got a brilliant idea to check at an automotive store (knew they carried belts of assorted sizes) and found a belt that will work for $8.00. The bread maker will wear out before this belt will. Made a loaf of bread - all is well, yeah!
So, the auto parts store is called O'Reilly Auto Parts, the belt size I used was Gates K030250 (13/32" x 25 - 3/4"). To make it easier to put the belt on (auto belts arent made to stretch) take the big wheel off (easy to do), turn the belt inside out (made belt easier to put on), and then work the belt and wheel back on. Put all back together and it was a go. You may find that a little longer belt be easier to put on, but I didnt want the belt to be too loose that it would slip.
God bless!
Posted on Oct 07, 2010
  • Nancy Collins Apr 08, 2012
    Tried this per your specifications/instructions. Tension was way too tight,. Even though we got the belt on, it wouldn't turn. Back to O 'Reilly's with the belt and to Square 1.
The paddle for my Magic Chef Bread Maker CMB 310 (310) was destroyed in my garbage disposal. I couldn't find any Magic Chef replacement. I did find that the TOASTMASTER MODEL TBR2 and TBR 15 have the identical paddle. I was able to order it from www.abtecparts.com It is product code # 07CTM34923. It took a few weeks to arrive but well worth the wait. It works just fine.
Posted on Jul 14, 2008
I had the same problem,but dear husband searched and searched for me and found a place that carries a belt that is slightly wider but works perfectly for the Magic Chef 1.5 model cbm 250-2 bread machine.I've been back in the bread making for about 2 months now with no problems.We can send anyone that needs a new drive belt for $ 20.00, and free shipping anywhere in the United States.We do sell on E-bay occasionally,but mostly buy ; ) Payment can be made thru Paypal or money order.
Posted on Feb 11, 2009
You can get the belt from McMaster Carr , part number 9003K44. Their website is www.mcmaster.com
Posted on Nov 27, 2009
Do not get the McMaster Carr belt listed above by another poster. It is too short by 4 inches. Even getting their next size up belt which is 24.5" is too short. I bought both and returned both to McMaster Carr. McMaster Carr says to measure using a string, then subtract 10% for stretching. Well, their neoprene belts you cannot stretch them even one millimeter, they are extremely hard. (Im sure if one uses a crowbar and fitting the belt on an automobile it can be stretched by brute force but dont try this on your breadmaker you'll simply break the plastic pully or bend the shaft) The span around the pulleys is 25.5" long, using a soft inseam tape measure.
Posted on Dec 30, 2009
  • IntelliQ Jan 11, 2010
    I can confirm the post by Traceylovespa, that the DAYCO 4L270 does indeed work. It is a little thick, and at first I had to nudge the pulleys with my fingers to get them to turn after putting on the belt when the unit is turned on, but then they kept working by themselves with no help after about 1 minute.
    I bought the Dayco belt from Amazon.com for about $9 delivered.
    Thanks to this forum and Tracey's post, I saved myself money not having to buy another bread machine. Thanks!
    (This is an update from my previous post warning against the use of the McMaster Carr belt, which does NOT fit)
OK, I tried the O'Reilly's belt suggested. My DH & I got it on the wheels, but the tension is SO TIGHT that nothing will turn. Back to the store with the belt, and back to Square 1, trying to get a replacement part from Magic Chef.
Posted on Apr 08, 2012
My plastic paddle broke 10 years ago and I contacted Magic Chef. They sent me a replacement that I've never had to replace. The replacement came from DCI Housewares & Appliances Inc at 8467 Dalton, Town Mt-Royal, Quebec H4T 1V5, phone 1-888-888-2433. Don't know how helpful this is since it was so long ago.
Posted on Aug 31, 2009
I think I have this model and am unable to get a new blade for it. I don't know where you found the weight of the model but the model number matches. How do you locate the belt inside the machine. I can check it.
Posted on Aug 07, 2009
3/29/2009
Replacement belt can be found at Elliot's Hardware in Mesquite, TX- I used V belt DAYCO 4L270, has worked great.
Would like to find another paddle for my Magic Chef 2-lb; 250-2 model.
Posted on Mar 29, 2009
Actually, I was just looking around and saw a CBM 250-2 belt on eBay. Worth checking into??
Posted on May 01, 2008
I'm with the class action, but usually the victims don't get compensated, only the lawyers. So here we go again, maybe we should just boycott shopping at Wal-mart, since all they sell are Chinese made goods. I also called Magic Chef. The manual said to contact customer service at Wal-mart (wally world). I called several. I got comments: "We don't sell bread machines", "We are starting to sell the 'Sunbeam' breadmachine. I went to a belt specialty store and they did not have one that fit. They gave me two O-rings, but they aren't strong enough to do the job. Maybe I'll try the vac belt like the other suggested.
Posted on Apr 19, 2008
I used a dirt devil vacuum cleaner belt style 7. FOund at ACE hardware or elsewhere. Can't say how long it will last but it made it thru one 22 min. kneading cycle.
Posted on Mar 08, 2008
Guest
Same problem with the 250-2
Called Magic chef, and they gave me a parts store #, called the #, they gave me Wal Marts #, e-mailed Wal Mart, they gave me Magic Chef's. Full circle in 1 1/2 weeks.
I am going to a vacuum repair store.
Posted on Mar 04, 2008
I called Magic Chef also they gave me Walmart number also. I called back they gave me another number. The line is ALWAYS
BUSY. So now what do we do. Throw it out??
Posted on Apr 21, 2008
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: magic chef breadmaker
Your going to have to call magic chef at the # here. Customer Service: 800.688.1120
Canadian Customers: 866.587.2002
Good Luck
Posted on Jan 21, 2009
Magic Chef model 250-2. What is the $ for?
Probably just indicating that you are saving money baking your own.
I have been looking for a manual with no success, unless you machine is made by Panasonic and branded Majic Chef? There are three models with 250 in the title.
http://www.breadmachinedigest.com/beginners/archive-of-bread-machine-manuals.php
I did find a spare parts list whilst searching.
http://www.bread-makers.org/machine/magic-chef-bread-machine
Jan 26, 2016 | Kitchen Appliances - Others
Magic chef breadmaker instruction booklet for CBM310
The Magic Chef CBM-310 is an automatic 1.5 lb. size bread maker. This popular unit was considered a fully-featured unit for its time, with easy-to-use electronic settings that enabled users to make a wide variety of bread from recipes provided with the unit. Some Magic Chef CBM-310 bread makers remain in service, and are often found at garage sales and swap meets. It can be used with most bread maker recipes that are suitable for a 1.5 lb. breadmaker as well as to make basic bread.
http://www.ehow.com/how_8376443_instructions-bread-maker-model-cbm310.html
Read more: Instructions for the Magic Chef Bread Maker Model CBM-310 ' eHow.com
http://www.ehow.com/how_8376443_instructions-bread-maker-model-cbm310.html#ixzz1eIffllvu
Nov 21, 2011 | Kitchen Appliances - Others
NEED NEW BELT FOR MY MAGIC CHEF AUTOMATYIC BREAD MAKER MODEL CBM 250 (250-2)
I may have a belt that would work. I need to know how many inches in length your old belt was and I will check my inventory once I have that.
Aug 17, 2011 | Kitchen Appliances - Others
I am trying to find the manual to my bread machine, the magic chef breadmaker, model number CBM-310. Magic chef is telling me my bread machine does not exist. can you help me find one? HELP HELP HELP HELP...
You can find and download this manual at www.thebreadmakerguru@yahoo.com or call verizon mobile (567)429-8935. Also, try this site, www.scribd.com/doc/18573938/Magic-Chef-Breadmaker-Model-310-Instruction-Manual-Recipes-cbm310. I am sure you have found one by now, but you're question was open to answer.
Sincerely, shastalaker7
Oct 30, 2009 | Kitchen Appliances - Others
Good Luck
Jan 20, 2009 | Kitchen Appliances - Others
Drive belt needed for Magic Chef CBM 250 Breadmaker
http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Nov 23, 2008 | Kitchen Appliances - Others
Kneading Blade for Magic Chef CBM 250-2
Go to e bay. They have a couple of stores that sell nothing but parts for bread machines.
May 24, 2008 | Betty Crocker BCF1690 Bread Maker
Replacement mixing paddle for cbm 310 automatic breadmaker
07XTM34923 AbtecParts.com
Toastmaster Bread Machine part - works great, according to other website
I ordered mine today
Feb 13, 2008 | Magic Chef CBM310 Bread Maker
Kitchen Appliances - Others Logo
6,258 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
