Question about Westinghouse LTV-40w1 HDC 40.02 in. LCD HDTV
Have sound without picture...I believe it's the t-con board. where can I purchase the fuse or the board
    Problem Solver:
  • 12 Answers
I have all the boards for this set. aj00937@yahoo.com
Posted on Feb 14, 2010
Sharp Aquos LC60LE632U 60" TV 1080p. LCD HDTV. Great picture. Except, there is one green line, running vertical down the far right of the screen. I'm suspecting that it may be the TCON Board.
I had a similar problem with my Sharp Aquos 60" LED and it was the T-Con Board. Simple to replace and can be purchased in the neighborhood of 40.00. If you have sound and a picture, T-Con Board replacement should be your fix. Great videos on youtube if you need assistance. I would highly recommend that you watch the videos prior to proceeding. I am NOT a TV repairman, just a do-it-your-selfer....
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
Mar 31, 2016 | Sharp Televison & Video
I have a Samsung TV model UN50H6350AFXZA which has sound but no picture. Backlights work. Replaced t-con board with new one, but not fixed. What next?
Main board. T con board is only involved with video issues. Main board goes both ways and since you already replaced the T con board that is your only alternative. U got backlite so inverter board is good.
Nov 13, 2015 | Samsung Televison & Video
My PLCD5092A-B tv power button comes on but no picture no sound
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 21, 2014 | Proscan PLCD5092A 50 in. LCD HDTV
Lg263000
It could be a bad T-con, but it could also be a faulty LVDS (cable that connects the t-con to the main board), or you can have a main board fault. It sounds like your panel isn't getting power. The T-con board should be located top center on the backside of the set. It should be housed under a metal cover. BEWARE, some panel have the T-Con built into the LCD panel. If this is the case, you will have to replace the entire panel if the t-con is bad. Simply go to www.shopjimmy.com, and type in you actual TV model # in the search box. This will bring up all the parts available for your model. The results will also bring up pictures of the parts so you can see exactly what they look like.
Nov 23, 2012 | LG 263000 26 in. HDTV-Ready LCD TV
NO Picture ~ only sound
If you have back-light but no picture the problem is T-con board but if the TV don't have back-light the problem is inverter board..
Replacing one of the board will fix the problem..
Hope it helps..please rate..
Mar 11, 2012 | Element Electronics FLX-3211B 32 in. LCD...
Samsung LE46M5 lost picture can not even get menue on screen still have sound. disconnected and reconected all wires cables and power no joy. is this expensive? purchased 06
t con board fuse may have blown very cheap to replace on the t con board there is a letter P on the board near to the cable end check this with a meter if blown replace with a nintendo fuse they are the same rating and cheap and easy to get hold off, or you can go to maplins and ask for a micro fuse 0.5amp fuse.
Feb 10, 2011 | Samsung LE46M51B 46 in. LCD Television
I have an insignia NS-LCD37HD that has backlight and sound, but no picture. I can tune the tv and hear the channel changing, but get no picture. I don't see any damage to either the main board or the...
Chec to see if you are getting 12vdc at the T-CON board power input pin first.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Oct 03, 2010 | Insignia NS-LCD37 37 in. LCD TV
Sony Bravia KDL-32M3000 Has sound, no picture, back-lights are on, red lines flickering across the screen which seems to prove there is video present. I'm thinking T-Con board. I ask this question because...
There is no way to really check a T con without a lot of test equipment, only thing that is serviceable on that board is the small fuse that is by the LVDS connector...
Dec 19, 2017 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I am getting a white screen (no picture) on a polaroid LCD
People any lcd tv with a white screen cause by the T-con board if you have some experiences you can check with a multimeter the (smd) fuse on the T-con board it is right in de middel on top in the back of the tv. you might have to move some of the boards to get to it. if the fuse is broken replace it with another smd fuse otherwise relace the t-con.
Jun 28, 2009 | Polaroid FLM-1911 19 in. LCD Television
Picture died, no display only sound
Do this test and it should tell if the lcd panel is bad or not, turn the tv on and touch the screen in the center, push with your finger firmly but not to hard, if you have a backlight or light shows up around your finger then it is probably the T-con board/panel, the T-con board is attached to the lcd panel and is less expensive to replace, if you do not have any light then it's probaly the power supply
Jun 13, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Televison & Video Logo
112 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
