Question about Aloha Housewares (93645) Ceiling Fan
Does the switch to change the direction of the fan need to be up or down to pull warm air down
  • 767 Answers
In the winter you would want the fan turningclockwise and on most ceiling fans it is in the up position. and in the summer you want it in the down position running counter clockwise creating a wind chill effect.
Posted on Dec 11, 2009
How do I reverse direction of hunter fan using universal remote 99121?
you don't
Reverse direction for a ceiling fan is a clockwise motion producing an updraft. In the winter, when your heater is running, reversing your ceiling fan moves warm air near the ceiling down to the floor. This greatly reduces your energy use and can lower your energy bills by as much as 15 percent. You will need a ladder or a step stool to reach the motor housing. Turn off your ceiling fan and locate the direction switch on the motor housing. This one is here, sometimes they are on the top of the motor housing. Make sure your fan has come to a complete stop before flipping the direction switch in the opposite direction
Sep 03, 2018 | Hunter Dryers
Allen & Roth Eastview ceiling fan. How do I reverse to pull up warm air instead of blowing air down?
Look for a slide switch on the side of the housing beneath the motor. If the manufacturer wired it correctly, the up position will pull up warm air and the down position will blow air down.
Jan 09, 2014 | Dryers
I have Hawkins ceiling fan. How do I switch blade directions - between warm weather (counter clockwise) & cool weather (clockwise)?
Clockwise on high for Summer. Counter Clockwise on slowest speed for Winter, to get the heat off the ceiling. A good way to remember which direction it should go from season to season , is by the directional switch on the side of the fan.. Switch Up for Winter. Switch Down for Summer.
Hope this helped you. Please let me know. Thanks.
Jun 11, 2011 | Hampton Bay Heating & Cooling
Fan has a switch for winter and summer. Is it up or down for summer?
This is probably a reversing switch changing the rotation direction. Check the air flow from the fan to find if it is pulling air up or pushing it down. Pushing down from the ceiling will be the 'winter' setting, pulling up, the summer. Since warm air gathers at the ceiling, it is beneficial to have it move that air downward during cold weather and have it pull up cooler air from the floor in summer. I frankly don't notice much difference though.
May 30, 2011 | Hampton Bay 24002 Ceiling Fan
Refridge is warm, freezer is working fine. There is a damper controlled by a small motor behind the meat drawer or top drawer. Pulled out drawer, and hole that gets air from freezer was blocked with a...
This is known as the CZT or Climate Zone Technology fan and if you direct wire it and it does not run, replace.
This is the cold zone fan which supplies cold air to the meat and crisper drawers.
Feb 07, 2011 | Maytag MSD2758GEW
Beverage Air. Model: CFG24-1. The evaporator fan motor does not turn while unit is operating. The entire condensing unit is working, except the evaporator fan motor. When I removed the evaporator fan motor...
http://beverage-air.com/pdf/manualsbycategory/K%20Series%20-%20Bottom%20Mount%20Reach-Ins/CFG_CRG_KF_Series809-046A.pdf
The fan has a limit control wired in series that shuts the fan down until the coil temperature reaches 25*F. this prevents the fan from blowing warm around after defrost.
There is also a switch which is placed for the door to close. Either one may be defective.
Worst case is the freezer is not pulling down temperature wise.
Jan 19, 2011 | Beverage-Air CFG24 Freezer
Fan going in wrong direction! how to switch blades!
There is usually a slide switch on the motor housing. Simply switch it to the other position.
For summer, you want the wind to blow down on you. Hold a strip of paper in your hand and see which way it goes.
For winter, you want the wind to blow upwards. This will push against the ceiling, forcing the warm air to circulate down to the floor level.
Aug 15, 2010 | Progress Lighting (P250110) AirPro...
How to reverse the fan direction
most to all fans have a switch on the side of it where the pull things are its a little switch that has two settings up or down this typically controlls the direction of the fan. (note: some fans are not designed to change directions and they wont) check you manual or instruction booklet
Aug 11, 2009 | Minka -Aire Brushed Nickel Remote Control...
Installed the fan and remote will not reverse directions
switch on side of fan above the actual fan blades needs to be switched off . There is a directional fan swirtch that is located above the fan blades right in the middle of the motor housing should have to pull the sliding toggle switch oppsite of current position
Dave
Jul 16, 2009 | Hampton Bay 04078 Avanti Ceiling Fan
Aloha Housewares (93645) Ceiling Fan Logo
185 people viewed this question
Top Aloha Housewares Dryers Experts
Steve
Cesar Quant
Cesar Quant
Craig Butler
Craig Butler
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
