Goes through cycle but there is no water coming in....
  • 57 Answers
This sound like a stuck or faulty pressure switch. The machine thinks it has water. Check the pressure / diaphragm switch and the tube going to it to make sure it's not just blocked.
Posted on Dec 11, 2009
Testimonial: "It is so nice to have a first class team right there .... at the tip of your fingers .. to help out when you get a pblm ... tks so much !!!!!!"
    Problem Solver:
Float mechanism and switch ....
Saeco odea does not brew coffee, all the water goes in the drip pan
Hello, the water in drip pan is clea water ot coffee water?(brown). Take a pucture inside machine with no brew unit inside.
Aug 27, 2017 | Saeco Coffee Makers & Espresso Machines
We have a ge profile dishwasher the panal (digital) comes on and goes through the cycle however no water seems to be dispensing during the cycle. Water is on and all hoses are already cleaned and hook
water inlet valve needs replaced its on the other end of the water inlet pipe on the machine,to buy about 15 dollars its a standard part so dont go to ge dealer as they will charge about 90 dollars,make sure power is of when replacing its what I would call a easy job .,,,,Adrian....
Jan 25, 2015 | GE Dishwashers
Cycle starts waters comes in, after about 30 seconds water goes out beeps 4 times goes off
Hi
It would be helpful to know the brand/ model etc.
Usually if the water gets in, and then drains out straight away, the dishwasher thinks that it is either not filling, or over filling. If there are 2 pressure switches, there would be one for fill and one for overflow, the fill one (or the pressure tube to it) would be faulty.
Otherwise, if there is only one pressure switch, it may be a dual switch, in which case it is faulty.
If it is a whirlpool or LG, there may be an issue with the flow meter which checks the volume of water coming in.
Best of luck with it. If there are further issues try to supply more info in your response as while dishwashers all do the same thing, some brands go about it in very different ways.
Adam
May 28, 2013 | Dishwashers
SM 8525492A whirlpool washer rinse cycle no water comes out, just hums
when the washer goes into rinse cycle it only uses cold water so clothes don't rinkle,so most likey you have a problem with your cold water,do this,shut down the water to the washer,remove the water lines from the back of washer and mark them so you know how they came off,stick the hoses into the washer if they reach or a bucket,turn on the cold water to see if water is coming out of hose,if water does come out of hose good then stick the cold water hose back on the washer and run it only on cold,if it doesn't fill then you know you have a problem with the water valve on the washer and it's not the house water valve that's bad,and usually if you have a problem with the washer water valve it will just hum and no water will enter the washer so if you hear a humming sound it will be the water valve.tried looking up the model number you sent but it doesn't come up on the parts lookup
Apr 25, 2013 | Washing Machines
Beans grind and are wet but coffee doesn't come out... it goes through the cycle and spits out a little. When cycle is complete, the water light comes on, but after priming the same thing occurs.
This tells me that either the grind is too fine and or the brew unit screen, and discharge tube needs to be cleaned. Try this first press the button for making a espresso using the manual function, do not add coffee through the door then press the brew button. If water flows freely then the grind is too fine, if you get the water prime error then the screen under the red o-ring on the brew unit needs to be cleaned.
Oct 19, 2011 | Saeco Incanto Classic Espresso Machine
My Viking just stopped providing water - it goes through all the
You probably have a leak, in the pump housing area below the unit, which is causing the drain pump to run continuously.
Jan 26, 2009 | Viking 24 in. Professional Series VUD141...
No water comes in - all else works
make sure you have 120 volts at the water valve when you know the unit is calling for water. if you have 120 volts replace the water valve
Dec 12, 2008 | Viking 24 in. Professional Series VUD141...
Brand new dishwasher not working
try this test: add water (one gallon each try) by hand fill and try the cycle again. Continue until light goes out. If light never goes out, then faulty water level switch or wiring. If light goes out, then water inlet valve is stopping too early, but need more info to determine why. Try this test: open door and find the door switch. Then activate the switch and turn on machine to watch water come in. It should not just "dribble" in; try to determine if water pressure is sufficient coming in.
Jun 19, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
