Question about Gigabyte GA-7N400E-L Motherboard
Ram System was working fine until I installed x2 512 elpida sticks of ram. Post picks up ram fine but after that does not continue to windows. System works fine if I take one stick out??????
  • sikness Jan 21, 2008
    the ram is ddr400 how do i change the speed????
    Genius:
  • 1,067 Answers
Is ram set at 333 speed mhz not ddr 400
Posted on Jan 20, 2008
Toshiba satellite turns on but power light blinks and screen is blank
Start as basic as you can, remove everything you can, RAM, HDD, modem (if equipped), WiFi card, optical drive, etc. It should beep when powered up, complaining about missing RAM. Install RAM and see if you can get it to POST. If so, install 1 item at a time until it stops working. Bad part found.
If it doesn't complain about the ram, it's probably a bad system board. If it does complain, but doesn't post with the RAM in, it could be still be a bad stick of RAM or a bad RAM socket on the board, try one at a time, and in each of the sockets.
Sep 15, 2012 | Toshiba Satellite Computers & Internet
Trying to upgrade RAM on GA-945gzm-s2 mobo. Already have 1gb 5300 ddr2 stick of RAM. Works fine until I place the 2nd stick of RAM in. I turn it on and get no post beeps, no video, but everything is...
The new RAM module could be faulty or the second memory slot is faulty.
Try removing the original 1Gb memory module and inserting the new memory module in its place to see if the computer boots up normally. If it doesn't then then new memory module is faulty.
Oct 24, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Dell 4400 won't power up Flea light works
For non-BIOS issues:
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a different powersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen. The PC may not boot to windows, but it Does post at this point, and with that the problem is resolved. If windows does not load, then you have a new problem. Best dealt with asking a new question.
Brian
Jun 28, 2009 | Dell Dimension 4400 Power Supply ** FREE...
Dell 2400 ram upgrade problem
RAM can be finicky so first test all memory slots with a known good stick (your 512MB). Make sure you're starting from a complete power down and you get a POST beep (hopefully your system is set up to beep when it powers on) and everything loads up all the way through to your OS.
Once you do that with all your memory slots test with the new stick by itself in all memory slots. If neither of the memory slots work with the new stick but you verify that it works in another system you should then check your BIOS settings and RAM timings to ensure compatibility with your stick. If you can't find the timing on the RAM stick itself, look up the manufacturer's part number for the information.
Feb 03, 2009 | Dell Dimension 2400 PC Desktop
Toshiba satellite A15 S127 pc notebook -how to set up CMOS: I cannot get into CMOS setup screen at boot up. I tried DEL, F5, F7, F8, etc. The reason I am trying this is as follows; I removed the original...
how to get into CMOS, simplly put F1, OR F2, F10,F12, OR DEL key, but very depend on your laptop itself.
tips, whatever key you need, will show on the boot up screen , like : type Fxxxxx for setup, Fxxxxxxxxx for boot up device order .
for your laptop, may have chance that you laptop too old, some model of ram are not fully compareable.
Jan 14, 2009 | Toshiba Satellite A15-S127 Notebook
Windows goes off with the msg 'NTLDR is missing'
NTLDR errors are usually caused by defective RAM on the motherboard. Try removing one of the RAM sticks on your board and see if computer works fine. If still gets error msg, swap the RAM stick and try again to narrow down which stick is faulty. Sometimes, its simply some corrosion on the RAM contacts which in that case, you only need to re-seat the sticks.
Nov 05, 2008 | Umax Astra 2000U Flatbed Scanner
MSI 7041 Motherboard problem?
RAM would be my next guess. If the board is bad, so could the RAM be as well. Try swapping some known good RAM and see what happens. Or, at the least (if you have more than one stick), remove all but one and try again. Repeat until all sticks have been tried by themselves - you could just have one RAM stick causing the problem.
However, usually even if you have one bad stick, your system will still post, just show less memory. On the off-chance that all sticks are bad, then you might have similar symptoms.
Sounds like a bad mobo to me :(
Scott
Oct 05, 2008 | Intel Motherboard
ASUS P5N-E SLI
Try RAM with a different speed. My 800 mhz RAM didn't work until I installed 533 mhz RAM and adjusted to 800 mhz in BIOS. Newly built PC, default must be set as 533 mhz because I reset the CMOS and still couldn't POST to BIOS. Only taking out all RAM gave me any sort of audible error code. Luckily I found some 533 RAM before I RMA'd the board.
Jul 06, 2008 | ASUS P5N-E SLI Motherboard
Installing 2 sticks of 1 gb ram = DRAM error beeps
If the computer is working with one gb stick and not the other, try this:
Swap the sticks with the one that does work. If it works then its the memory card slot on the motherboard. If it doesn't boot up, then it's the memory stick.
Jun 13, 2008 | Gigabyte GA-K8NS Motherboard
Random freezes
blue screen means you have problem with your windows software or memory if you don't fix this soon it will not work any more until you reload the windows check your memory cards for good attachment
Dec 31, 2007 | Chaintech 7NJL3 Motherboard
Gigabyte GA-7N400E-L Motherboard Logo
50 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
