Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
Tried to start my polaris 1998 500 RMK, and finally figured out I wasn't getting any spark! I had just replaced my spark plug cap! that's all I did, I am still getting power to my headlights when I pull on it, what does this mean?
  • 767 Answers
The sparkplug wire may be broken or not making contact with the coil that goes around the end of the spark plug.
Posted on Dec 11, 2009
Start up idle is slow below 1050 rpms and sounds like going to stall while idling. Runs fine otherwise.
How to adjust your Polaris Snowmobiles TPS. - YouTube
? 6:05
https://www.youtube.com/watch?v=aEPx7OsywNk
Dec 11, 2009 - Uploaded by PolarisRich
A quick video on how to adjust your Polaris Snowmobiles Throttle ... TPS cause this? it seems like it hits top rpm, it runs flawlessup to the ... Would this work on a 2011 Polaris pro rmk 800?? ... I have a 2006 Polaris Fusion 600 h.o. It seems to bog out when u first start ... Sounds like its a carb or clutch issue!
2011 Pro RMK 800 Top End Bogging [Archive] - SnoWest Snowmobile Forum
www.snowest.com/forum/archive/index.php/t-298871.html
Jan 30, 2012 - 52 posts - ‎33 authors
[Archive] 2011 Pro RMK 800 Top End Bogging Polaris: Pro-Ride. ... Sled is a 2011 ProRMK 800 155, 1700 kms, MBRP can. ... problems with bogging at every rpm and roughidle, I am running 91 from .... fuel filter yet?...almost sounds like your fuel pump can't keep up with ..... I am running a 2010 660 CFI-4. 2010 dragon 155 RMK electrical problems
Feb 3, 2013
Polaris update
100+ posts
Nov 15, 2009
~~The Official Phazer Thread~~
100+ posts
Sep 12, 2009
M1000 Hiccups on the Bottom
100+ posts
Jan 28, 2008
More results from www.snowest.com
Jan 12, 2016 | Polaris 2010 RMK 800 Dragon 163-Inch
Keeps fowling plug 2009 rmk
Your fuel must be too rich or you are burning oil
Feb 02, 2015 | Polaris 2009 RMK 800 Assault 146-Inch
Sparkplugs no spark
For spark plug problem, click the help links provided below: ---
Car has no spark?
http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
How to Replace Spark Plugs?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
Car cranks, has spark but will not start?
http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
The spark plug firing order for car?
http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
How to gap spark plug ? http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
Spark plug Replacing for?
http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
How to identify number one spark plug on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
How does the spark plug wire go on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
Spark plug Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
This will help.
Thanks.
Feb 04, 2012 | Polaris ATV
1997 Polaris rmk 700 has no spark. Kill switch is in run position and key is on. Sled ran fine last year. I get a little tail light when I pull starter rope
try bypassing the kill switch and the ignition switch. Often the switches fail before the other components. the ignition can usually be bypasses by simply unplugging it from the harness. You may have to loop the wires to bypass the kill switch.
Jan 22, 2011 | Polaris New Genuine Polaris Snowmobile...
I have a 2000 polaris 800 rmk that i just bought and am not sure
With both of your questions the parts book is a recomendation for a specific condition. If you have 410's now and the spark plug looks like it's burning a nice caramel brown then you are fine. If the spark plug looks like it's burning white you need even bigger jets, if you are burning black then you need to go smaller. Always change them by one or two sizes and check again. As for the weights, the different weights change shift points of the clutch a heavier weight would cause the primary clutch to engage at a different rpm, I am in a stage of trial and error on which ones to use to make the clutch shift when and how I want it to.
Dec 28, 2009 | 1984 Honda CBX
I have an 2002 polaris Rmk with a igition switch that has 2 differant fuel settings (normal octane & preminum). The instructions that came with the tether switch does not mention this type of ignition...
Not sure if this helps...but my bro has a 01' RMK and it says to only use premium gas, I believe he may have tried to use regular or even mid grade and it bogged or started to. Never the less...I think that it is always best to run premium in high perfomance "toys" like smowmobiles and such...
Oct 18, 2009 | Polaris New Genuine Polaris Snowmobile...
2005 polaris 500 stalling
Yes, yes, and yes. Begin by installng new spark plugs. Also, a new air filter, and finally put carbeurator cleaner into your fuel tank, usually one ounce per gallon. You can purchase these items at any auto parts store. Bring the old plugs and air filter in so u are sure to get the correct ones. Finally, charge up your battery.
Jul 04, 2009 | Polaris ATV
2000 rmk 600
You may have a sticky exhaust valve due to carbon build up on the stem.
Aug 26, 2017 | Polaris New Genuine Polaris Snowmobile...
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
386 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
Bill Boyd
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
