Question about Sharp Audio Players & Recorders
3 disc CD rotary changer jammed.Will not play or
3 disc CD rotary changer jammed. Will not play or eject
techman
  • 3130 Answers
SOURCE: CD changer not playing CD's
If this did not help the problem by cleani9ng the lens, the laser is bad or the spindle moteo is bad. if this unit is over 2 years old, buy a new unit. Good Luck
Posted on Jul 15, 2007
  • 26 Answers
SOURCE: cd jumps tracks
The CD lens may need cleaning.
Try a 'wet' CD lens cleaner.
The laser PU may be low emision.
Posted on Nov 09, 2007
tech48
  • 624 Answers
SOURCE: bose 6 disc cd changer
Some bose cd changers have a gear the get cracked and must be replaced. You did not specify which bose you have, so I have told you of the most common problem with the bose 6 cd changers.
If this is in one of the silver slimline type of units, it is very difficult to get them apart if you have not dome it before. The gear is also very hard to get to in the changer. it would be a good idea to let a professional service technician look at it. You will need to take it to an authorized bose service center because bose does not sell parts to any service centers unless they are bose authorized. They just started that about 2 years ago.
I hope this was helpful to you, let me know if I can assist you further.
Dave
Posted on Jul 01, 2008
Eagleeyes
  • 199 Answers
SOURCE: 307 5 disc cd changer wont play or eject cd,s 2003 307.
hi there is a repair kit for this unit.
please see: http://carradiospares.co.uk/repair-8619001490-p-256.html
mark
Posted on Jul 21, 2008
  • 4234 Answers
SOURCE: sa-pm29 cd-changer jammed
The loading mechanism needs to be rebuilt. There is also an engineering change that should be applied to this unit if it hasn't had the mod already. This is not a home repair. This unit should go to an authorized Panasonic service center.
Dan
Posted on Jul 29, 2008
6 disc, will not eject or play cd's
Try tapping on the changer. Sometimes a gear gets stuck inside the changer and tapping on the changer frees the gear.
Feb 15, 2012 | Alpine CHM-S630 6-Disc CD Changer
6 disc cd changer jammed in 2004 mercury mountaineer, says error when i try to eject or play jammed discs.
personally I used another not so valuable CD to push the jammed CD back, it appears the ejected CD may bump the open exit gate and get stalled. It has happened several times. Good luck
Mar 15, 2011 | 2004 Mercury Mountaineer
Error 3 on my 6 disc CD changer The manual says to eject and re-insert disc, but the player won't eject or play or change discs. What is the fix?
try disconnecting power to the radio for an hour or so. usually it is best to disconnect the battery overnight to reset the microprocessors.
Feb 28, 2011 | JBL MCDC100 6-Disc CD Changer
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
2002 Explorer indash cd changer malfunction 'cd error'
its an optical problem, you may try cleaning the lens or try replacing a new one.
Jul 09, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
Jammed CD & Magazine in an Alpine CHA-S634
Mine jammed after I dropped it, trying to swap it into a new car :-)
Same problem, however. Three of the six CD trays had wandered into the righthand mechanism (which selects and plays one cd at a time). Nothing else at all, most fortunately, was broken.
I removed the cover (3 screws on each side), and the small black faceplate that holds the eject button. The main faceplate came off too, needless to say; no screws, just tabs.
You have to remove the side brackets also, and the angle-adjust spring loaded pins on both sides need to be slid out. Then the body of the cd changer rotates out of its cover.
Now, you can see down into the mechanism. A CD was still stuck in the reader, along with several shifted trays. I could simply remove the CD, and with a small screwdriver, shifted the trays back over so that I could then successfully eject it. I removed and realigned the trays, which had been jammed, and it worked once more! Reassembled and reinstalled ;-)
Apr 26, 2009 | Alpine CHAS-634 6-Disc CD Changer
CD changer problem
had to replace player twice, luckily it was under warranty. FACTORY PLAYER JAMS EASILY !!! What I have learned is to put cd player in radio mode before ejecting instead skipping form disc to disc.
Jul 21, 2008 | 2003 Lincoln Navigator
JVC KD-MK66 12 DISC CD CHANGER WITH ERROR
try a new batt in the remote as it colud be flat?
Mar 15, 2008 | Car Audio & Video
Bose Wave Music Sys & 3 CD Changer
I have had a few of these come to my shop. The gears jump out of timing causing the cd lift to jam or become unalligned. The unit will probably have to be disassembled to get the CD out or have it serviced.
Dec 23, 2007 | Bose Wave music system Multi-CD Changer...
240 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
