4 wire outlet and 3 wire dryer, how do i hook up the new 4 wire to the dryer
  • 5,911 Answers
The following link explains how to correctly install an appliance power cord:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
The main difference between 3-wire configuration and 4-wire, is how the Neutral (WHITE) wire and Ground (GREEN or BARE COPPER) wires are terminated at the terminal block on the back of the dryer. In a 4-wire configuration the Ground and Neutral are independent of each other are not terminated together. Match the corresponding color wires at the terminal block and make sure you remove any ground straps from the neutral (if installed). Connect the ground wire to the equipment cabinet.
Read through the link provided and let me know if you have any questions. I hope this helps you.
Posted on Dec 11, 2009
I am trying to change my miller welder 4 prong plug to qa 3 prong to match my dryer outlet ? which wire goes where ?
On 4 wire outlets the neutral and ground wire were seperate on 3 wire the ground and neutral are combined so hook up the 2 hots (black&red) as before on the 2 outside terminals and combine the green and white together onto the center terminal
Nov 12, 2011 | Whirlpool LER5636P Electric Dryer
Need help hooking up a 3 prong dryer outlet to a 4 prong dryer outlet
You will not be able to connect a 3 wire cord you need to install a 4 wire cord and this is how it goes on
It seems to get confusing where the wires go in the back where the cord connects to on your brand new,or previously dryer that you have brought to a home thats new to you
4 wires goes as such with oldtech2332.jpgthe red wire going on the right side,the black wire going on the left,the white wire goes on the center terminal. Now what exactly do you do with the green wires is what your asking yourself. It goes onto the cabinet after removing that little link that went from the center terminal that was beweeen the cabinet and and the white wire terminal.Yes remove that link and install the green wire where that link was just attached to a minute ago.
Aug 21, 2011 | Maytag Neptune MDE5500AY Electric Dryer
We just recently moved and the original house had a 4 prong dryer connection which my Matag neptune has. The new house has a 3 prong outlet. I have purchased a 3 prong cord. How to do I hook up the...
DON'T DO IT!!! Get an electrician to install a 4 prong outlet for you. Your exposure is DEATH, be safe and get the correct outlet.
When some types of failures happen, you can charge the CASING of the washer. then you can become the connection to ground.
Get the correct outlet, return the three wire plug.
Jun 24, 2011 | Dryers
Dryer is 2 years old. Worked fine until we moved to a new house and could not hook it up. 1 year later I finally had the electric problem fixed and hooked the dryer up No Heat. Dryer turns on but NO Heat.
is the outlet 3 or 4 prongs?. voltage check the outlet for propper voltage. check connection at dryer power cord. 2 of the wires power the motor circuitry(120vac) the other 2 the heating element. you may have a loose connection in outlet,switch wires or bad-half trip breaker. if not,,,, there's a dryer problem, call us again with update please. good luck to you.
Feb 07, 2011 | Dryers
New house had dryer outlet that electrician installed a Range outlet ( 30 amp breaker) by mistake on the wall. I changed my cord on Samsung dryer to match the outlet and dryer made a loud noise and would...
You still do not have one of the wires hooked up right...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Feb 01, 2011 | Dryers
I have a dryer with 4-pronged plug and just moved to a home with a 3-pronged outlet. Can I buy a 3-pronged cord to use with my dryer?
Yes, you can convert your 4 wire to three wire.
Go to the following website for the way to hook it up, it is easy.
This is a free answer, Please rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Oct 16, 2010 | Whirlpool Dryers
Brand new dryer threw braker twice, then no heat and timer stopped working. Electrician tightened connections on wires to dryer settings dial, had heat for one load, then same as before. Replacement dryer...
might want to check your dryer outlet. If the terminals are loose in there it could cause you problems. If your dryer plug is a 4 prong you might be loosing one of your 220v legs due to a short . As the dryer runs the wires and connections will heat up and expand , if there is a faulty wire or connection then it may loose connection after a load. could be quite dangerous and a very possible fire risk so i would check it out ASAP . if the outlet is old they sell for about $20 at you local home depot or lowes home improvement. for a 3 prong plug you need to hook up the black and white wires on the brass screws and the copper ground wire to the green screw. in a 4 prong application you hook up the black and red wires to the brass screws, the whit wire t the silver screw and the copper ground wire to the green screw .
If your new dryer is supposed to be a 4 prong plug and you have it with a 3 prong cord then you will run in to issues . The difference being a 4 prong electric dryer is a dual voltage unit where it needs both 220v and 115v to operate correctly, where a 3 prong dryer only has 220v and the earth ground. if your not familiar or comfortable with electricity please call a qualified electrician to come hand handle the work. if not done correctly it can cause fires or possible electrocution
Oct 30, 2009 | Amana NED5500TQ Electric Dryer
Just hooked up outlet. Dryer tumbles, wont heat. Have I wired the outlet wrong?
Hi, Did you put red and black wire to the outer posts? White wire ti center and green to ground screw on cabinet? Dry will run on 120V but needs 240V for heat. Make sure there is 240V to the outlet as well.
Hope this helps. If so, please feel free to rate my answer so that I know how I am doing.
Vic
May 10, 2009 | Dryers
Change fr 3 prongs to 4
They wire in the same except the green wire will go to a ground screw which should be right in the same area with a green color to it. If no ground screw, hook the green together with the white (center) wire. Hope this helps!
Dec 27, 2008 | Frigidaire GLEQ642A Electric Dryer
Washing Machines Logo
168 people viewed this question
Top Washing Machines Experts
