Question about Competition INTERFIRE BIG BOY 2CH AMPLIFIER IFHB-23340C Car Audio Amplifier
I have a interfire amp connected to a sub it powers up then the blue light goes to red and shuts down within 30 secs. sometimes it works fine for like 30 mins. Dont understand its has a mind of its own it either works fine or it shuts down within seconds.
    Scholar:
  • 84 Answers
Check your ohm load from your sub... that's generally the problem causing protection lights to kick on or the amp to shut down.
Posted on Dec 13, 2009
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
My sub has all bin wired up proberly the sub works for about 30 secs then the green light goes out and no power to the sub at all
Green light on amp?? Seems like your amp is going into thermal overload. Check your power connections, and make sure there are no shorted wires. Hope this helps.
Apr 21, 2010 | Fusion FEW12PK Car Subwoofer
No bass
could be the speaker its hooked up to . try to disconnect the sub and see if the protect light goes out
Feb 06, 2010 | Competition INTERFIRE BIG BOY 2CH...
My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Aug 29, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
I have a jl 500/1v2 and when i have the volume up for some time it teens to turn the amber color light on and turns off my amp and sub i turn down the volume for like 30 sec turn it back up and every thing...
its probably wires touchin or the ground not connected well with fat enough wire. i would try to rewire and do everything all over again because one wire or fuse is messing up i had t he same probelm. its the red light on the amp is ur amp shut off or ur warning light?
Jun 03, 2009 | Jl Audio E1200 Car Audio Amplifier
Basicly my speakers were working fine, my subs were working fine but everytime i was turning my volume up to a certain level i would lose all base and all noise from the subs in my boot, so i turned it...
The amp should always light up showing you that it is powered and there will also be a red light that will light up if theres something wrong.Sounds like maybe the hot wire that goes to the amp isnt big enough to give the amp enough power.Check your positive wire and ground wire for tightness and make sure hot wire supply is big enough and also the ground wire is big enough and has a good ground.I hope this Helps you.Have A great day..
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Mar 31, 2009 | Pioneer GM-X722 Car Audio Amplifier
Kenwood KAC-8401 light goes from blue to red when turned on
Either the amp is ad or the sub got shorted? You can check itby disconnecting the Sub and seeing if the amp comes on blue then. If yes, then the sub is shorted. If no, then the amp is shorted. Also chck the voltage AT THE AMP. Make sure that it is above 12 Volts.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 29, 2008 | Kenwood KAC-9152D Car Audio Amplifier
My amp only powers the subwoofer when the radio is on but wont when the cd player is on
The person(s) who hooked up your system made a boo boo. They wired your remote turn on lead to the power antenna lead instead of the amp turn on line (both are blue and easy to mix up). Thus when your radio is on it sends a signal to the amp and the amp turns on, but when you set to CD the signal goes away and your amp shuts down. Easy fix, just re-wire the amp turn on lead and the problem will be fixed.
Jun 24, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Car Audio & Video Logo
234 people viewed this question
Top Competition Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Competition Car Audio and Video Expert? Answer questions, earn points and help others
