Question about Sony Playstation 3 (PS3) Console
My ps3 will boot up and the green light is on but i cannot see what is being displayed. i once changed the settings from the three prong to HDMI cable and since then i have not been able to view anything (hear aswell). My tv is HD so i don't know whats happening please help...
    Problem Solver:
  • 18 Answers
1. Turn off the PS3
2. Plug in whatever cable you are going to use
3. Hold the power button down until it beeps once followed by two quick beeps
This resets the display settings to defaults and you will see the picture again.
Posted on Dec 11, 2009
  • 3 Answers
Http://www.portfolioofpb.com/blog/ps3-blank-screen-switch-inputs-hdmi-to-composite-to-hdmi
Testimonial: "worked perfect! this playstation sat for 2 years because i thought it was broken and had bought a second one"
2 Suggested Answers
SOURCE:
SOURCE: my ps3 display
to all those who cannot see any display..hold down the on/off button until it beeps once, then wait a few seconds until it beeps again, the ps3 will have reset itself and will adjust the visual settings to fit your tv
Posted on Jul 09, 2008
Hi our PS3 has no sound or picture. It does have the green power light on.
What is probably happening, is your PS3 is set for the wrong type of output. If you are using an HDMI cord, try switching to the AV cables that came with your PS3, and set your TV at the appropriate input to correspond with the AV hookups, and see if the picture works then.
If you are using the AV cables, it may have been set to HDMI accidentally. You need to use an HDMI cord, and hook the PS3 up to an HDMI compatible TV or monitor, and select the HDMI input. Once you get the picture working, go to Settings>Display Settings and set the display you wish to use.
May 16, 2011 | Sony Playstation 3 (PS3) Console
When i turn on my ps3, the green light stays on and the tv screen doesn't even change. i changed the cords to make sure the audio/video wasn't just out. i tried to enter 'recovery mode' but it won't even...
If you have a "slim" ps3, it does not beep 3 times. Try this.
First, with the system off,plug in your old red, white, yellow cables into the tv. (make sure your tv is on the correct setting). Now, just turn on the ps3 the regular way. Did you hear the sounds it normally makes when booting up (the ps3 boot music?). If so, thats good. If you did not, check again that the tv is on the right channel, and if possible, try another set of red, white, yellow cables.
If you heard sound, but do not get a picture, turn the ps3 back off. After the red light comes on, hold your finger down on the power button for about 5 seconds. If you have a fat ps3, it will beep 3 times after a few seconds to get back to regular tv mode. If you have a slim ps3, it will beep once, then 1 more time a few seconds later. It should reset and turn back on. If your tv is on the right channel and the cables work, then you should now see a picture and you know your audio/video is working. You can now try your HDMI cable and it should prompt you to use the HDMI at this point.
Hope that helps.
Mike!
Mar 02, 2011 | Sony Playstation 3 (PS3) Console
I turn the playstation on in my television using the three prong wire (yellow, red, white) and it will not work on my television it starts up but it soon sounds like it stopped running. I took the...
Please use HDMI cable to connect the PS3 to your computer when you found that it is working with that it. It only shows that your three prong cable is defective as it fails every time. Try with another three prong cable and see the results. I will still insist you to use HDMI cable which will give you better picture quality and sound.
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
The PS3 switches on, lights up, drive and disc drive working but No Signal on TV. Saw HDMI cable solution previously posted. Does that work for SCART also?
yes just change hdmi for the word scart
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
Ps3 output rainbow blocks and screen flashes
Jun 26, 2010 | Sony Playstation 3 (PS3) Console
PS3 HDMI No picture nor audio
When I turn my ps3 on, there is no audio/video. I don't think it's a software update problem, as I was playing my ps3 about two/three hours ago. I turn it off at the back, chill for a couple seconds, then...
Jun 25, 2010 | Sony Playstation 3 (PS3) Console
My ps3 wont show on my tv anymore. what do i do?
not to worry it is very simple
1. if u are using hdmi port and it is connected to hdmi in your tv
setting might have been changed
1. take out ur nomal av output wire which is given by sony , plug it on to a normal tv (rgb) now u can see the display (if not try mannual swithch off the ps3 and on for 3 to 4 times) u will get the display
2. now go to settings (video settings) there is a option called video output u can change it to AUTOMATIC
3.NOW COME OUT of it and switch off
4. now pug into ur hdmi port it will work
Mar 15, 2010 | Sony Playstation 3 (PS3) Console
My ps3 display
Mar 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
163 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
