Question about Nintendo Wii Console
What channel should the tv be set to?
For nintendo wii what channel should the tv be set to? i do not have a remote, so i can only choose some channels, not aux
  • carolmodz Dec 12, 2009
    thanks,but how do i change the input on the tv?
  • 8,197 Answers
Tv needs to be set to channel 3 or you need to change the input on the tv if you are using the rca jacks on the tv. The other way to hook it up is if you have an rf modulator. You can get the at walmart or radio shack for 20.00 dollars.
Posted on Dec 11, 2009
What channel does my tv need to be on? and what button do i press on my dish network remote to get me to the wii screen
Usually it depends on how you connected to the TV/satellite box- for instance, I have mine set on channel AUX 1 since I have connected my Wii to the TV using the component cables (the red yellow and white cables) to the port AUX 1. If you've hooked it to the Dish box, then it would be whichever accessory you connected is the channel to select in the dish system, but on the channel that your dish is hooked up (it's situational!)
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Jun 25, 2011 | Nintendo Wii Console
Trying to hook up my wii to an very old model phillips magnavox
I think you have two options here:
1-Maybe your TV aux input is the type where the AUX channel is before channel 2, or after whatever your highest channel number is. If so, you can access that AUX channel by either going channel UP or channel DOWN.
2-If that doesn't work, maybe it's worth the $5 for a cheap universal remote, that you can program, and thereby access the TV INPUT mode.
Hope this helps.
Mar 06, 2010 | Philips 19PR19 19" TV
I need to know what channel to operate my wii on. I have a toshiba tv that is about 8 years old.
Try changing the TV inputs to VIDEO or AUX, using the remote or a button on your TV. If there is not a way to connect the Wii to the TV using the 3-cable system (Yellow, Red and White), then you might have to use a VCR or DVD player to plug the 3 cables into and then transmit the audio and video from the Wii using the regular cable line of VCR or DVD Player on TV channels 3 or 4. If your Wii has a regular TV Cable jack on the back, connect that to the jack on the back of you TV and select channel 3 or 4.
Jan 05, 2010 | Nintendo Wii Console
Input select sttting
Normally, your TV or VCR is probably set to display the television channels you watch, through a standard cable input. In order to play your Nintendo using the A/V cables, we need to tell your TV or VCR to switch from the normal tv channels, and instead display the signal coming in from the A/V cables of your Nintendo system. There is no one particular way to do this, as it varies between brands, but below is some information that may help.
Quick Tip: Grab the original remote control for the TV or VCR you have plugged your Nintendo into, and look for a button that could be labeled:
  • TV/Video
  • Input Select
  • Line or Line In
  • Source
  • AUX (auxiliary)
  • EXT (external)
  • any other button that seems to indicate it would switch between the TV signal and the game system.
If the above tips did not help, it is possible your Input Select is a little more difficult to locate. Here are some other common ways to access an Input Select:
  • A button on the front of your TV or VCR located behind a door or a hidden panel, or located on the original remote control that came with the device. If you are using a universal remote, it may not work when pressing the "input select" button. If it does not work, try to locate the original remote.
  • A high or low end channel. Try channel surfing through every channel, even the ones that do not normally broadcast a TV show. Many times the input select is a high channel such as 90, 91, 92, 93, 99, or even 999. You should also try low channels such as 0, 00,001, 1 or even 2. For some televisions, you may need to manually select these channels by using the keypad on the TV or remote control.
  • Found within an on-screen menu. Search the menu for words such as Input, Setup or Source. Select one of these words, and another menu will usually appear that asks you to select between TV and either AV, AUX or Line. Select AV, AUX or Line to display the Nintendo game.
If you are still unable to find your input select, you may want to consult the operation manual that came with your TV or VCR, or contact the manufacturer directly.
Nov 19, 2009 | Nintendo Wii Console
There is power to the console. We can hear the
Check the input cables coming from the Wii to the TV. Then check to see that your selecting that right Aux channel. On most remotes there is a source or input selection. Pressing this should cycle through all input channel selections. One input should be the Wii signal.
Bret
1-2-1ComputerServices
Oct 06, 2009 | Nintendo Wii Console
Trying to connect a wii to my curtis mathis tv and we can not figure out how to set the tv on aux with a universal remote
Theres Either Gonna Be A Tv/Video Button On The Remote Or The Tv. Also Try Going To Channel 01 And Then Going Down A Channel To See If You Can Access The Aux Function That Way.
Jan 30, 2009 | Curtis-Mathis CM27101S TV
I can't figure out the input select
Try leaving the Wii on and switching the TV off then on. I have an old TV and this is the only way I can activate the AUX
However sometimes even this will not work and you have to plug the Wii into a DVD player or Video player then plug that into the Aux to get it to work
Dec 26, 2008 | Nintendo Wii Console
No Aux Channel but I have the yellow and White plugs in the front!
Certain Universal remotes have extra menu and input buttons. Take a look around and see what you can find.
Apr 24, 2008 | Orion STV2763 27" TV
Take out the channel up button and use a small, long object (like a pencil or pen) and repeatly press the button under until AUX comes up.
Nov 21, 2007 | Orion1934 19" TV
Nintendo Wii Console Logo
328 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
