Question about Coby MP-705 Digital Media Player
MP705-4G BATTERY REPLACEMENT
HOW TO CHECK IF THE BATTERY IS OK
My 06 honda pilot runs great. 10 minutes after i've shut it off and try to start it, it sputters and coughs but will not start.
Check that the battery is not faulty, if it is OK then check that it is charging looking at the battery voltage from the alternator. The voltage should be 14v over the nominal 12v. Then you have a wiring or alternator issue.
Check the link for battery replacement issues:
2006 Honda Pilot Battery Replacement
Feb 11, 2015 | Honda Cars & Trucks
Battery changed ok on battery but not transfering to Line
Not making contact at the terminal clean terminal ,s check connector at starter.
Aug 28, 2014 | UPG 12V 12Ah Battery Replacement for APC...
Sukam 800VA not charging my battery
Check the charging voltage if you know how to use a multimeter .
if it is 13 volts then it is ok.please tell me how old is your UPS and battery.if the battery is 2-3 years then it may need replacement.
after checking the charging voltage charge the battery or some 6-8 hours promptly maintain charging .
Aug 10, 2014 | Computers & Internet
Interminent battery drain on 2000 ford windstar
Check the voltage you are getting from the generator on the battery terminals with help of a multimeter. Check the continuity of the harness from alternator to the battery terminals.
If the voltage levels are below 13.0V and harness is OK, then get your alternator checked. (it may need replacement)
Oct 21, 2010 | 2000 Ford Windstar
Hace a APC XS 900 that said battery needs replacement, unit is about a year old. I replaced the batteries & it lasted about 2 hours & again says replace batteries. I know the new batteries are OK...
disconnect one terminal of the battery then measure charging voltage betwen +ve and -ve it should be 13.8vdc for one 12v battery if charging voltage is not present then battery is ok then connect ammeter to measure the current in Ampere .take care it should be in series if current if no current then battery must ok opern the ups there is a charger transformer measure i/p voltage to transformer if not present then check i/p path if present then check diodes at o/p of charger if faulty replace it also check capacitor and regulator ic if faulty replace it your problem must be solved
Mar 13, 2010 | APC Back-UPS XS900 (BX900) UPS System
Installed new battery and still shows low battery after 2 holes and 24 hours of charging
if all cables on battery are clean and tight, then most likely it is the alternator putting out a low charge. test the alternator it should be at least 14 or a little more when running. 12.5 to 13 when off. if alternator is ok, then check all wiring from alternator to battery, and make sure the battery ground is ok!! best of luck carl,
Dec 04, 2009 | SkyGolf SkyCaddie SG5 Car GPS Receiver
Have a motorola RAZR v3x battery will not charge battery is good will charge in another mobile how do i repair connection to charge phone
If the battery is working fine then the issue is definetly with the phone, so you need to check its connection where the battery touches the points of metal tip, or you can get the same checked with the service center as they will be able to check from the phone from inside also, opening it yourself will end up the warrenty
Nov 27, 2009 | Cell Phones
2001 bmw x5 when I try to start it the light flicker and makes a clicking noise. Is it just the battery
First check the battery terminals are clean and firmly attached- if terminals are ok the battery may be either discharged or faulty.
Get the engine started by jumping from another battery- then check battery running terminal voltage is approx 14.5 volts with load such as headlights or heater fan on.
If voltage ok and battery still doesn't hold charge, the battery is probably faulty - replacement required.
Oct 26, 2009 | 2002 BMW 5 Series
Engine will not start,fuel pressure ok,no spark and no injection pulse.sensors check out ok.problem appeared few weeks ago after aborted start.after disconnecting battery and reconnecting after a while...
Try first checking all the connections, then if you can try to use a different battery just to make sure that the battery is still working fine and check also the starter ,becase this can be a problem also with the starter solenoid that may need repair or replacement...
Hope that helps.........
Sep 19, 2008 | Audi A6 Cars & Trucks
162-System options not set
I tried to find how old that model is but had no luck; this message may mean that the CMOS backup battery, normally a small 'coin' cell, needs replacement. That message says that it can't remember who and what it is and that happens when the battery is depleted. Check you user guide about replacement of that battery; it should be a DIY job. The battery will cost <$10 US even if you stumble across a crook selling them. Wholesale, they are about 20-30 cents.
Sep 11, 2008 | Compaq Armada M700 Notebook
Coby MP-705  Digital Media Player  Logo
81 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
