Have american standard lifetime whirlpool tub problem with white drain popper will not go down all the way just got replacement part for company same problem
yes, it could be.also may be build up of waste,(hair,etc) is the rest of bath room performing ok,has this problem just appeared ?just something's to look into
Chances are that the drain assembly was not part of the tub but a 'generic' plumbing part. Is this pop up drain the type that you push down and it clicks closed and push down and then it pops up? It unscrews from the drain fitting and you can get a replacement at a big box store. A better pop up replacement is one called a Rapid-fit. It drains faster.
You will need plumbers putty and a plumber's drain tool. Put a ring of putty around the piece that will be on the inside of the tub to seal it. Then insert it through the hole making sure the rubber gasket is on the bottom side of the tub and tighten it down.
