Question about Dell Inspiron E1505 Notebook
Monitor When the laptop is powered up, it flashes the dell screen and then just goes white. If you connect an external monitor, you can see that the computer is running normal. I replaced the monitor and inverter and had the same result with the white screen. Also, the keyboard is not responding now. The pointer pad does work.
  • tommytool72 Jan 20, 2008
    the cables are all fine and the computer has not been bumped. But why do you mention the right corner? the keyboard was working until i did a system restore.
  • 49 Answers
Probably you have tried opening your laptop and messed up with the cables... or your unit receive a hard bump at the top right corner if i'm not mistaken....
LCD and keyboard laptop cable usually are loosen with this kind of problems... check the cables and you can rank me if this helps... ^_^
Posted on Jan 20, 2008
  • chris albert navarro
    chris albert navarro Jan 20, 2008
    aw why don't you mentioned it earlier that you use system restore? try holding down the Fn key then press the key with monitor icon in your keyboard... do it also with the keyboard icon.. probably its just the windows reset the settings of the keyboard. if your provide more info more people can help you better... note: keyboard layouts is varies on different kind of laptops
Have dell m5030 has white screen when turned on
Most propably its the went bad try to connect to external screen
if it work then its then you have to replace it if the external one doesnt work it meas the the video card is bad.
Mar 04, 2015 | Dell Inspiron M5030 Laptop
Why does my monitor start as white when I turn it on? THe mouse pad does not work as well.
Monitor cable disconnected internally?
and disconnect, clean and reconnect ALL monitor related cables. (You may need a new screen if that fails)
You may check your laptop by connecting an external monitor first.
Aug 21, 2014 | Dell LATITUDE Computers & Internet
I have a dell e1705,and it has a white screen what is wrong?
You could have a loose video cable connection that attaches to the motherboard or you may have a faulty on-board video.
Try connecting an external monitor to your Dell, power up the external monitor fist and then boot up the Dell laptop. The video will automatically divert to the external monitor if the on-board video is OK.
This means the video cable/connector needs re-seating or the video cable is faulty.
Mar 07, 2013 | Dell Computers & Internet
Wont see projector
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 19, 2012 | Dell Latitude D630 Laptop Computer PC...
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
White screen
The white screen you are getting is it just right after turning on the computer? If yes it means that you were not able to see the Dell logo correct?
Try connecting an external monitor thru VGA. While monitor and laptop is on with white screen please do this. Hold down Fn key then press F8 at the same time. This will toggle the display from the laptop to external monitor. If laptop displays to external monitor means that laptop LCD needs to be replaced.
If you do not have an external monitor try this.
While laptop is OFF. Do this. Hold down the D key then press power button at the same time.
Check if the laptop will display colors the whole screen. If you still see white screen then LCD needs replacement.
LCD mean LCD panel or the whole screen together with LCD cable and Inverter.
Hope this helps.
Mar 25, 2011 | Dell Inspiron 1525 Notebook
When power on the screen is white with pixie colored lines going thru can not see screen then screen goes black windows will try to load but goes all black but power is still on
sounds like either an LCD panel problem, or a video controller. First thing, connect an external monitor and test if the same thing happens with it. You may need to press FN + F8 together to switch the display to the external monitor. If same thing happens, there is a problem with the video card. Try to boot in safe mode and if same issue, you either need to proceed in getting a new video card/motherboard if the problem is happening even during the Dell BIOS screen. If it happens pass the BIOS screen only, you may try a reinstall or repair of Windows. If external monitor is okay, you'll need an LCD Panel repair/replacement. Let us know how it goes and your rating/comment would be appreciated.
Oct 04, 2010 | Dell Computers & Internet
Today I noticed that when turning on computer, after 1-2 mins the screen goe black and I cant see anything. I noticed in the past month that occasionaly I get lightening flashes in the background. this...
To determine if the LCD screen is faulty ot the video card, connect an external monitor to the laptop's video port. Power up the external monitor first and the boot up the laptop. The video image should automatically switch to the external monitor. If you don't get flashes on the monitor then the video card is OK and the fault lies with the LCD screen. Flashes coud be caused by a faulty inverter or a faulty CCFL lamp. A fault is usually easier to diagnose when it is not intermitten.
Jun 08, 2009 | Dell Inspiron 6000 Notebook
My dell E196FPF 19'' lcd screen acting strange!
Are You using a extention cord or a ups that is not funtioning properly....?? if yes try connecting the power for the monitor seperately or directly to a plug base...
this mi8 solve ur problem
Apr 10, 2009 | Dell E177FP LCD Monitor
D800 laptop will not display on external monitor
Most laptops go into standby mode when the lid is closed. To stop this, (Windows XP) click Start, Control Panel, Performance and Maintenance, Power Options, then click on the Advanced tab, select "Do nothing" in the drop-down for "When I close the lid of my portable computer"
Feb 12, 2009 | Dell Latitude D800 Notebook
Dell Inspiron E1505 Notebook Logo
129 people viewed this question
Alun Cox
