Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
KODAK HOW TO REFILL KODAK COLOR INK
  • 103 Answers
No need of refilling it , call Kodak and tell them u have bought a new pack of ink cartridges and its not detected. Will ask you for serial numbers. Provide the one written on your old ink cartridges.
You'll get inkk cartridges free of charge.
Posted on Jan 26, 2010
SOURCE:
Need help with the kodak verite 55 plus printer. does it have a reset chip so i can refill my own ink? if not whats the easiest way to dealing with this new printer? it is getting very tiresome
a cruise around the net shows that the cartridges for the kodak printer shows that walmart sells the kodak verite 5xl combo ink cartridge for $38.97 free shipping in 2days
you can get a 5xxl black cartridge which will do 600 pages as well
www.walmart.com
Feb 18, 2017 | Kodak Office Equipment & Supplies
Need KODAK #30 ink refill kit and chips or chip resetter
Kodak # 30 ink cartridge was made just for Kodak to help them get out of the red ink they are in. read the link below and see what they have done.
http://blog.atlanticinkjet.com/general-cartridges-posts/the-latest-printer-ink-from-kodak-inkjet-a-shift-from-the-cheap-ink-approach.html
Feb 12, 2012 | Office Equipment & Supplies
Hello'' can you tell me how to change the ink in the kodak printer?
  1. Open up the cartridge to reach the ink chamber within. For color and photo cartridges, just remove the lid with a sharp knife (insert it where the black and colored plastic meet) to find the three fill holes. On black cartridges, make a hole with a heated pin or drill on top of the cartridge where the letter "K" is.
  2. Step 2 Check the chambers in a color/photo cartridge to determine which color ink is in which chamber. Insert a different toothpick or pin into each chamber to draw out yellow, cyan or magenta ink.
  3. Step 3 Fill a plastic syringe bottle with enough ink in the color you are refilling. A black ink cartridge should need 10 to 15 milliliters. A color/photo cartridge takes 5 milliliters of each color.
  4. Step 4 Insert the syringe needle into the cartridge, sending the tip down to the bottom. The chamber contains a sponge, so you will need a small bit of force to push it in.
  5. Step 5 Inject the ink into the cartridge. Unlike other brands of cartridges, you want to saturate the sponge with ink in a Kodak cartridge. Depress the syringe plunger slowly until you can see the ink begin to surface on top of the sponge.
  6. Step 6 Wash all ink residue out of the syringe after you've refilled one shade of ink. If you intend to refill another color immediately, dry the syringe out first.
  7. Step 7 Replace the lid on a color/photo cartridge. Apply a strip of tape to the spot where you first removed the lid to secure it. You don't need to seal a hole you drilled in a black cartridge.
  8. Step 8 Leave the cartridge standing in a secure spot overnight. This helps the ink settle within the cartridge for even printing once the cartridge is back in the printer.
Apr 30, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How can i refill a kodak color ink
Dec 10, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Esp 7 cartridge resetter and color refill .
no,ink cartridges cannot be refilled .kodak printers dont recognize refilled cartridges and as such,ink price is very reasonable,clear liquid is white coloured ink. no cartridge resetter is available,cartridges are seated in the printhead of the printer
Jul 26, 2009 | Kodak ESP 5 Printer
ESP-5 will not clear low ink message and print after refilling black cartridge.
chip on cartridge has to be replaced as you can not use any cartridge twice. but for two bucks you can get a new chip to put on your cartridge so you can refill
fillerserv.com and 123refills.net you can buy these new chips for 2 bucks you have to get one for the color and one for the black. good luck!
Jul 18, 2009 | Kodak ESP 5 Printer
The printer says i need to put in color ink cartridge.it is in and wont do anything
if the red light is still flashing then try and reseat both the ink cartridges and print head and make sure you use genuine kodak ink cartridges as there are retailers selling look alike and refilled ink cartridges.......if still the same problem then print head problem call kodak tech support they will replace it for you without any charge........
Jul 07, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Pic`s wrong colors
you need to check
1) same color ink of the cartridge almost empty, change a new ink cartridge or refill the color ink (there is only one ink cartridge)
2) the cartridge ink channel dryer and constipated, take out the cartridge put the bottom surface touch down clean water (a little) 1 hr, then set back if the cartridge has enough ink.
Feb 05, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Faded/bad coloring on color printer/scanner - Kodak ESP5
Take out both the colour and black ink cartridge and look on there sides as there would be a number written on the side.......this is to determine if the ink cartridges are genuine or not.........here are few numbers for the ink cartridges if they match and still have issue then its a print head issue else bad ink cartridges probably refilled........
  • 1K3156
  • 1K3157
  • 1K3178
  • 1K3177
  • 1K3189
  • 1K3190
  • 1K3627
  • 1K3622
  • 1K3629
  • 1K3638
  • 1K3620
  • 1K3621
let me know how many have ink cartridges that do not match these numbers.........let me know if this was helpful.........
Dec 15, 2008 | Kodak ESP 5 Printer
How do you reset the chip in the new Kodak Ink Cartridges ?
I've got a solution. We should find a way to file a class action lawsuit against these companies. Not just for ourselves, but for the environment itself. For years I've had issues with bad printheads and the ink costing more than a newer printer that comes with ink! That ink is toxic to the environment. I know places like Staples offer incentives to recycle them now. But what about the years before? Not to mention the idea of an entire printer going to a landfill since it's 'no good' anymore. Plastic produced from crude oil, logic boards silicon, lcd panels, steel roads, etc. Those are finite resources that don't just replenish themselves. What do these companies think will happen when those resources are exhausted and our planet is tainted with toxic chemicals? All the money in the world can't fix that! Nor will it fix what's already been done for decades. If anyone here knows a 'good' attorney willing to undertake this and is ready to have us sign up let me know. Knowing the ink is still in the cartridge that has to be recycled burns me. Knowing the companies that rob us blind, and most likely reuse those same cartridges, just to get even richer disgusts me. If our economy is in shambles why let these bastards push us further into the financial muck any further than we are already?!?!?!
Aug 20, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
379 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
