Question about Toshiba 36HF72 36" TV
My hd cable box works great in all of the video in connections on the tv, but my dvd player, hd camera do not work when I plug them in, the picture is like it is scrambled, but if I plug the cable box in it works great. I tried two differant dvd players and it is the same. so i know the cables are good and so are the dvd players and video camera is good... what can be wrong ? the only thing that works in any of the video channels is the cable box?
  • 176 Answers
Are you connecting these devices to the ColorStream inputs?
If so you will need to set the output settings on the DVD player or your camera to 480i. You have an HD capable TV but it is old technology and is not capable of handling the signal levels produced by HD equipment these days.
Look at the menu options on your equipment and most of them have the ability to put out the lower level signal or just hook them up using the standard yellow/red/white inputs. Hope this helped.
Good Luck..
Posted on Jan 05, 2010
SOURCE:
I have a Philips DVDR 3575H. using Comcast's
Try this set up-
Use an RCA audio/video cable for this set up (Yellow/Red/White).
Connect from the Video out (Yellow) connection on the back of the cable box to the Video in on the back of the DVR.
Connect the audio (Red/White) cables from audio out connection on the back of the cable box to the "Audio in" on the back of the DVR.
This should still get you a decent picture but not a true HD picture for your recordings.
When you set the timer to record set it to record either E1 or E2 depending on which input you connected the cable box to and ensure that the cable box is tuned to the channel you wish to record.
*** NOTE: If you keep the HDMI cable connected as you have for the cable box and watch normal TV through the HDMI input on the TV you will get HD programming for your general viewing but still have the option to record with the DVR at a lower quality. ***
Good Luck and please rate this solution....
Jan 07, 2010 | Philips DVDR3575H/37
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Powers on - no output to TV
Ok, this is general hardware failure. This will need to be repaired by a Sony tech asap. the central board is malfunctioning at this time. Contact Sony asap.
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
New XBOX 360 no picture / sound
ok your lucky, you just need to by a new av cable.. or if that dosnt work you need to get the av caple connection fixed (only about $25)
thanks, Domo
Dec 23, 2008 | Microsoft Xbox 360 Console
How do I get sound on my Vizio SV420XVT 42 Great picture but no sound
I had the same problem. I could get an analog audio signal but no digitial signal. My problem was with the cable box setting. I have Cox Cable. With the Cable remote I went to settings/settings/Audio out and selected HDMI. Worked like a charm
Oct 19, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
HDTV OR NO?
You can use a cable box providing that its HD option is working. With many of the cable companies, you have to pay to have the HD option in the cable box activated. Then you have to pay subscription for the HD channels. That is the way it is at where I am located. Without the HD subscription active on our cable boxes this feature is dead!
The only reliable way for you to know if the HD option works in your TV itself is to get a known to be working HD source such as an HD DVD player and try it out.
Jerry G.
Apr 14, 2008 | Toshiba 32AF44 32" TV
LASONIC DVD PLAYER NOT WORKING WITH COMCAST BOX OR SOYO TV
you have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
Mar 05, 2017 | Lasonic DVDP | DVD-7050 5.1CH
Toshiba 36HF72 36" TV Logo
83 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
