Question about Jensen VM9510 Car DVD Player
Need to replace the main wiring "harness" that connects all electrical components
I need to replace the main wiring "harness" component on a Vm9510 system. To be honest,...I have no idea what this part is called. However,...it's the "main wiring component" that plugs into the tuner unit,...and which has all of the wiring connections that connnect the VM9510 to the antenna,...and to the battery,...and to the ground connection,...etc. From what I can tell from the picture of this unit in the product manual,...there are 11 separate wiring connections coming out of the base piece.
If you understand what I've tried to describe above,...then it will be GREATLY appreciate if you would please answer the following questions:
1. What is this "wiring harness" actually called?
2. Where can I buy it?
3. And, if you know,...what do you think it may cost?
Thank you very much for your help.
Regards,.............................................................j.b.
  • Anonymous Jan 28, 2008
    wiring
  • Anonymous Feb 08, 2008
    jenson vm9510 main wiring need one.
6ya staff
SOURCE:
All of the engine wires in my 1987 e 350 RV burned up 460 motor
Hi David:
That is a really bad experience to have had happen. Serious sympathies to you.
I'm hoping/assuming that the fire did not destroy the entire unit and perhaps was restricted to electrical components.
I've a couple of suggestions that may be helpful.
First, I'd see if I could find a Haynes manual for the vehicle.
If I were to be faced with your situation I would probably sip a beer and ponder the engine compartment for a while. I'd try to determine if major components had been damaged, and then replace any that had been overcooked.
Most wiring harnesses have plug connections and I would try to get as complete a harness as possible from an auto salvage company.
Then, as each component was replaced or confirmed undamaged, I would try to splice or plug in the appropriate section of harness.
Reply as a COMMENT to this post if you wish to discuss more.
All the best.
May 29, 2016 | Cars & Trucks
I recently replaced the catalytic converter to my 2000 bmw 300I and now It is giving the p2096.
Possible causes
- Oxygen sensor harness is open or shorted
- Oxygen sensor circuit poor electrical connection
- Exhaust system leak
- Faulty front or rear (pre-cat or downstream) oxygen sensor
what it means Harness is open or shorted It means that the wire(s) connected from and to the component (sensor, solenoids, actuator, etc.) is either open (cut, broken, disconnected) or shorted (touching other wires, components, body). "Open" and "short" are common electrical terms. An open is a break in a wire or at a connection. A short is an accidental connection of a wire to ground or to another wire. In simple electronics, this usually means something won't work at all. With complex electronics (such as ECMs or PCMs) this can sometimes mean something works, but not the way it's supposed to.
Circuit poor electrical connection It means that the component (sensor, solenoids, actuator, etc.) connector is not fully connected or is disconnected. Before replacing any components, try fully disconnecting the connector, reconnect and test the system or component again.
Faulty or Failed component It means that the component it's more than likely the cause of the code and that needs to be replaced
Engine mechanical problems When a code list as possible causes an engine mechanical problem, it means that the problem is not caused by electronic component, but rather by a mechanical component such as pistons, valves, mechanical pump
Mar 26, 2015 | BMW Cars & Trucks
GE Model WCVH6800J Error Code 04. I do not have list of codes for this model, so I need translation.
TROUBLESHOOTING CHART
Codes Description Action
22,23 Fill problems
• Ensure manual water valves are fully open.
• Check if water strainers on solenoid valve assembly are clogged.
• Check for obstructions inside inlet water hoses.
• Ensure solenoid valves do not leak when the valves are de-energized and the washer is powered down. • Measure coil resistance for both valves; if outside range (1000-1250 ohms at room temp.), replace solenoid valve
assembly.
IF ABOVE STEPS DO NOT CLEAR THE PROBLEM, OR FOR ERROR CODE 23:
• Replace solenoid valve assembly.
30, 31 Drain problems
• Ensure pump strainer is clean and free of debris.
• Check for obstruction inside the drain hose.
• Check pump impeller blades and bearing; if evidence of blade damage or seized bearings are present, replace the pump.
• Check electrical connections at the pump motor and harness.
• Measure pump motor resistance; if outside range (9-14 ohms at room temp.), replace the pump.
38,39 Dispenser problems
• Check for obstruction in dispenser mechanism and linkages.
• Check electrical connections at dispenser motor feedback switch and in the harness.
IF ABOVE STEPS DO NOT CLEAR THE PROBLEM:
• Replace dispenser motor assembly.
42,45, 49 Motor Drive operation above design limits
• Ensure all 4 shipping bolts have been properly removed.
• Remove all foreign objects that may be lodged between inner and outer basket.
• Look for signs of seized bearing(s) on basket and drum motor, replace components as necessary.
• Inspect condition and mounting of door gasket, replace and re-mount as necessary.
• Ensure inner basket (drum) can rotate freely.
• Replace motor drive or drum motor.
43,4A, 4B,4C, Motor Drive internal problems
4E,4F, 50,52,
53,54
• Measure AC outlet voltage, ensure correct range (102V to 132V AC).
• Check electrical connections at the drum motor, motor drive.
• Check harness integrity between main control and motor drive.
• Unplug the unit, wait 30 seconds, restart the unit.
• If the fault persists and re-appears -replace the motor drive.
problems
57,58,71 Main Control internal problems
• Unplug the unit, wait 30 seconds, re-start the unit.
• If the fault persists and re-appears -replace the main control.
60,61,63,64, DOOR LOCK assembly problems
• Check integrity of wiring and connections between main control and DOOR LOCK mechanism.
• Investigate DOOR-LOCK mechanism, check door microswitch operation, lock and unlock solenoid continuity, contact integrity;
replace DOOR LOCK mechanism if necessary.
• Replace the main control.
65 Water Level Sensor problems
• Check integrity of wiring and connections between main control and Water Level Sensor.
• Check integrity of Water Level Sensor, replace if necessary.
66,67 Water Temperature Sensor problems
• Check integrity of wiring and connections between main control and HeaterfThermistor Assembly.
• Using ohmmeter, measure Thermistor resistance; if outside expected range, replace HeaterfThermistor Assembly.
70 "Stuck" key
• Press each key. There should be mechanical "click" feedback with every press.
• Enter Service mode, use 104 test to check key operation. Press every key. Every keypress should generate audible
"beep." Press "Power" key last to avoid premature exit from t04 test.
• Separate control and control housing from the front panel; clean and remove all foreign matter and debris from keys,
front panel and control housing, re-assemble. Ensure all keys can be operated freely without "sticking."
IF ABOVE STEP DOES NOT CLEAR THE PROBLEM:
62 System Contact Failure
• Check integrity of wiring and connections, look for insulation breakdown and short circuit conditions on the harness, replace
harness if necessary.
• Check integrity and electrical connections of all loads (heater, pump, pressure switch, door lock, solenoid valves,
dispenser motor), replace respective components if necessary.
Jun 23, 2011 | General Electric WCVH6800J Front Load...
How to check temperature sensor and how to replace it on a 2003 chevy impala 3.8l
Testing: many intermittent open or shorted circuits come and go with harness and connector movement caused by vibration, engine torque, bumps and rough pavement, etc.
Test the wiring harness and connectors by performing the following:
Move the related connectors and wiring while monitoring the appropriate scan tool data.
Move the related connectors and wiring with the component commanded ON and OFF, with the scan tool. Observe the components operation.
With the engine running, move the related connectors and wiring while monitoring engine operation.
If harness or connector movement affects the data displayed, the component and system operation, or the engine operation, inspect and repair the harness or connections as necessary
Test the electrical connections and/or wiring by performing the following:
Inspect for incorrect mating of the connector halves, or terminals not fully seated in the connector body, backed-out.
Inspect for improperly formed or damaged terminals. Test for incorrect terminal tension.
Inspect for poor terminal to wire connections including terminals crimped over insulation. This requires removing the terminal from the connector body.
Inspect for corrosion or water intrusion. Pierced or damaged insulation can allow moisture to enter the wiring. The conductor can corrode inside the insulation with little visible evidence. Look for swollen and stiff sections of wire in the suspect circuits.
Inspect for wires that are broken inside the insulation.
Fig. Identifying engine coolant temperature sensor-3.1L, 3.4L and 3.8L engines
3.8L Engines
NOTE Use care when handling the coolant sensor. Damage to the coolant sensor will affect the operation of the fuel control system.
  1. Partially drain the cooling system.
  2. Disconnect the ECT sensor electrical connector.
  3. Remove the ECT sensor.
    Fig. Removing and installing ECT sensor-3.8L engine (click image for zoom)
To install:
NOTE Replacement components must be the correct part number for the application. Components requiring the use of the thread locking compound, lubricants, corrosion inhibitors, or sealants are identified in the service procedure. Some replacement components may come with these coatings already applied. Do not use these coatings on components unless specified. These coatings can affect the final torque, which may affect the operation of the component. Use the correct torque specification when installing components in order to avoid damage.
  1. Coat the threads with sealer GM P/N 12346004 (Canadian P/N 10953480) or equivalent.
    NOTE Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  2. Install the ECT sensor and tighten to 15 ft. lbs. (20 Nm).
  3. Connect the ECT electrical connector.
  4. Fill the cooling system.
Hope helps (remember to rate this answer).
May 10, 2011 | 2003 Chevrolet Impala
The screen comes up with F 11 and will not spin at all
HI, this is a Serial communication error. This issue will more than likely concern the wiring harness.
The Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component.((Usually the wiring harness will need to be replaced))
Aug 04, 2009 | Whirlpool Washing Machines
F11 SHOWS ON THE PANEL.
HI. This is a Serial communication error
Potential Causes
• Check MCU
• Check CCU
• Check Motor
Replace failed component.(usually the wiring harness will need to be replaced in this case, but a faulty Motor Control Board is not uncommon)
Aug 01, 2009 | Kenmore HE5
96 Civic power window, driver's side
before replaceing check voltage from switch to regulator then to motor that will tell you which component is bad when you find that out look at the mounting styl off the failed component mos are held in with clips or rivets if they are riveted in you will have to drill them out
Jun 03, 2009 | 1996 Honda Civic
Kawasai z750, keeps blowing main fuse
To my knowledge, there are no onboard electrical/electronic components capable of shorting and blowing the fuse with out blowing any of the secondary fuse. The main fuse could possibly blow due to a short in the wiring or an exposed/frayed wire touching the body. The three most likely areas would be:
  • wire harness leading to the regulator;
  • wire harness leading to the fusebox; and/or
  • wire harness leading to the ignition switch.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 19, 2008 | 2005 kawasaki EL 125 Eliminator
Jensen VM9510 Car DVD Player Logo
405 people viewed this question
Top Jensen Car Audio & Video Experts
Larry Tezekjian
Larry Tezekjian
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
