Question about Konica Minolta Maxxum 3Xi 35mm SLR Camera
Replaced battery, turned on, camera will not operate. Window shows mfocus, P, flash, Auto, .......1
  • 667 Answers
Try removing the lens from the camera and re-mounting it while the camera is turned on
Posted on Dec 11, 2009
How to reset windows on is 350 lexus 2007
(a) Turn the engine switch on (IG).
(b) Halfway open the power window by pressing the power window switch.
(c) Fully pull up the switch until the power window is fully closed and continue to hold the switch for approx. 1 second after the power window is fully closed.
(d) Check that the AUTO UP/DOWN function operates normally.
If the AUTO UP/DOWN function operates normally, reset operations have been completed at this time. If not normal, follow the steps below.
(1) Disconnect the negative battery terminal for 10 seconds.
(2) Connect the battery terminal.
(3) Turn the engine switch on (IG).
(4) Halfway open the power window by pressing the power window switch.
(5) If the AUTO UP/DOWN function operates normally, reset operations have been completed at this time.
(6) Turn the engine switch on (IG).
(7) Halfway open the power window by pressing the power window switch.
(8) Fully pull up the switch until the power window is fully closed and continue to hold the switch for approx. 12 seconds after the power window is fully closed.
(9) Check that the AUTO UP/DOWN function operates normally.
Feb 05, 2017 | 2007 Lexus IS 350
Sony Cybershot DSC-W55 Flash Error Code
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Mar 24, 2008 | Cameras
How to turn the flash off DMC-TZ1 camera?
On the menu set button at the bottom right at the back of the camera, if you press the right hand side of this you can change the way the flash operates from auto, auto/red-eye reduction, forced on... and the final one would be forced off. You can download the manual from http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_222458 enter DMC-TZ1 into the enter model box and then download the operating instructions and on page 40 it will show you how to do it.
Jan 25, 2012 | Panasonic Cameras
I changed my battery and now my window auto-up does not work but my auto-down works. How do I fix this?
Your vehicle has an anti pinch feature for auto up so your fingers or a childs neck is not harmed. It is possible 1 of 2 things has happened, either the module was damaged when you changed the battery, or in some models this was a programmable feature. So heres what I would do, look in the owners manual and see if its programmable which will be a simple task of cycling the key on and off and operating the window button or you can call your dealer and ask for the readers digest version...if your model is not programmable I would first try to remove the negative battery post for 1 minute with the key off and OUT of the ignition and then reinstall the cable and then insert your key, start the car and then try the window...failing that you will need to have your window control module replaced or re flashed by the dealer.
Aug 05, 2010 | 2007 Infiniti G35 Sedan Sport Sedan
Can't turn the flash off
Hi The product you have given has Built-in flash with Auto, Forced on, Red-eye on, and forced off (Red-eye reduction On or Off).
There is a 1 1/8" diameter lens with a built-in lens cover that automatically opens and closes when the on/off button is pressed. Above the lens is the viewfinder window, flash and tiny (almost unnoticeable) microphone. There is also a small circle that has three functions: the autofocus assist beam, red-eye reduction lamp, self-timer lamp. A wrist strap comes with the camera and attaches through a slot on the front of the camera near the side.
To the right of those buttons is the four-way controller, used for menu navigation as well as:
  • Up - Metering (Evaluative, center-weighted, spot)
  • Down - Drive (Single-shot, continuous, self-timer)
  • Left - Focus (Auto, macro, infinity)
  • Right - Flash (Auto w/redeye reduction, auto, flash on w/redeye reduction, flash on, flash off)
Dec 28, 2008 | Canon PowerShot A400 Digital Camera
My camera wont stay on after i turn it on
Hi. It can be a problem with flash capacitor. To check if it is the case you should be able to power your camera at least for 10 seconds. If you can not power your camera for this time from batteries, try to use external DC 7.4V 2A power supply. After powering your camera just follow this procedure. 1. Turn on the camera. 2. Turn off the flash by pressing flash button (be sure that flash is OFF but not in AUTO regime). 3. Turn off the camera. 4. Turn on the camera. If after these operations camera can be powered from batteries and you can make pictures than the problem is in the flash capacitor which should be replaced. Or you still can make pictures with your camera without using a flash.
Jun 10, 2008 | Canon PowerShot S1 IS Digital Camera
Short or No Battery Life
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.
Hope its helpful to you
Oct 09, 2007 | Canon PowerShot S1 IS Digital Camera
Battery problem
did you use comapny authorised battery if not go for it
Apr 24, 2007 | Canon PowerShot S1 IS Digital Camera
Flash doesn't work
Hello Laura, Try to hard reset the camera at first. This can be done by removing the battery and pressing the power button for about 1-2 min (keep it pressed). After that, press every other button twice (including zoom, menu and shuter buttons). Then press again the power button for about 1-2 min. After that reconnect the battery and go to auto-settings. If this doesn't work there is a problem with either the camera's firmware or the internal flash capacitor. Either of these will require service intervention because they will need to dissasemble the camera and run a diagnostic. This shouldn't be an expensive repair IF the camera doesn't show on the screen an error message something like E:16:00 blinking (when you take pictures). If this is the case, the flash assembly is damaged and needs to be replaced (this costs about $50-$60) otherwise it should be cheaper. For more informations please reply back.
Mar 28, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Going through batteries abnormally quickly
Hi. I bought a used A70 that had that problem. I disassembled the outer body panels and found that a base panel assembly screw was too long, and was touching the LCD's ground cable, at the cable's tip. I changed the screw for a shorter one and it was settled. It never happened again.
May 31, 2006 | Canon PowerShot S1 IS Digital Camera
Konica Minolta Maxxum 3Xi 35mm SLR Camera Logo
112 people viewed this question
Top Konica Minolta Photography Experts
Steven Wander
Steven Wander
arjoy ceniza
arjoy ceniza
Computer Links
Are you a Konica Minolta Photography Expert? Answer questions, earn points and help others
