Question about Frigidaire GLTF1670A Front Load Washer
How do i remove the mold in thewashing machine machine the machine was purchased in 2003. the smell has become unbearable I have read that must clean the filter How do we do that is there a drawing of the piece to simplify the job? I have developed a serious skin problem which seems to be related to this problem please Help me thanks
  • 5,911 Answers
The filter is actually the trap on the drain pump. If the model number you have listed is correct, the drain pump on this washer can be accessed by removing the toe panel directly below the door. Locate and remove the screws that hold the panel in place along the bottom front edge and the panel comes free. The drain pump is located in the front below the wash tub.
In order to clean out the trap area of this pump, you need to remove the large rubber inlet hose from the pump. Using a pair of pliers, you can squeeze to release the hose clamp off the inlet side of the pump and pull it free from the pump. It is common for this area to collect debris and begin to smell. Clean as necessary.
NOTE: Prior to removing the drain hose, its a good idea to remove any residual water from the drain lines and wash tub to avoid a messy clean up. A smart tip is to use a wet/dry shop vac and pull a vacuum on the drain line at the wall. This will pull everything out of the internal drain lines, pump and lower wash tub and minimize any mess.
The following link can give you some excellent tips on how to prevent mold and mildew inside a front loader:
http://www.fixya.com/support/r3608512-getting_rid_front_loader_mildew_odor
Another item to note, if you are using the wrong detergent, or using the improper amount of detergent, this will also contribute to odors in the washer. The improper concentration of detergent will cause soap scum build up in which dirt and debris will collect. It will also contribute to premature wear and tear on the pump motor and seals. Use HE detergent only.
If you have any questions, or if your model number is different than the one you have this question listed under, please let me know. I hope this has been helpful to you.
Posted on Dec 11, 2009
Testimonial: "looks good thanks very much the pipe behind the pump was full of bmack scum I used spray 9 to clean it out and now the machine actually smels great "
2003 aztek water on floorboards, not solvent
theres a box under the dash with a filter and drain tube they are what's probably clogged. your best bet is to get a Hanes book or chilton from your parts store to walk you through it if your set on doing it your self but I will warn you it's a job and it's aggravating.
Jul 23, 2012 | 2003 Pontiac Aztek
Tip
My 20 year old dishwasher never smelled,I use the dishwasher 3 times a week...
Your dishwasher is one of the most used appliances in your kitchen.
No matter what dishwasher model you have, you need to give some thought to giving it regular maintenance. Dishwasher cleaning is one of the things that many people wonder about. The best dishwasher is the one that is kept in good running order by keeping it in top working condition.
If your dishwasher is used regularly you really do not need to clean a dishwasher. Dishwasher cleaning is only needed if you do not use it for a week or more and it begins to smell bad inside. Other wise the only cleaning needed is to keep food particles and waste from building up inside. Some dishwasher can discharge larger particles then others. If you have one that does not do well in this area, then you need to remove the leftover food often. A paper towels works very well to do this. There are commercial dishwasher cleaners that you can run through your dishwasher, to make it clean and smell nice again if you have not used it for a long time.
If you are noticing that your dishes are not being cleaned properly, it may be because you are not getting enough water in the dishwasher. The water inlet valve is what allows the water to flow into you dishwasher. This valve will wear over time and then not allow the water to enter properly. This valve is located right behind the kick panel, and is a very easy replacement for most handyman type people. It is recommended that this valve be replaced as a preventative measure, every three to seven years.
Check the racks in your dishwasher for places that the plastic coating has worn off. When this happens the rack will rust and can stain what is being washed. There are repair kits available to repair the coatings on your racks. If you sand the rust off of the racks first the repair will stack better and last longer.
The spray arms inside your dishwasher can also become clogged. Bits of food, paper, and other things can become stuck in the small holes. Take the time to remove these and clean out all of the little holes. This will allow the pump to move more water and also ensure that you get a good spray pattern again to give you the best cleaning possible.
If you find glass in the spray arms, you should also remove and disassemble the pump. Check it for damage from the glass. Glass can damage the seals in the pump. If left too long it will cause the pump seals to leak. If you have a leak at your pump, it may have been caused by glass.
On some dishwashers there is a filter before the pump. This is located under the lower spray arm, near the bottom of the dishwasher. Clean this filter often and if it becomes damaged replace it to protect your pump. If you do not know how to clean it, check your owner’s manual to see how to do it properly.
These things will help your dishwasher to work well and give you great service for a long time. If you provide service to your dishwasher you will also be assured that you are getting the best performance from your dishwasher also.
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
on Aug 13, 2011 | Dishwashers
There is a musty smell in the maytag washer even b4 I fill it with water, I've disconneted the hoses & flushed with bleach that did not take care of it,Iv'e run washes without clothes in it...
When a moldy or musty smell develops in a washing machine, many times the smell is coming from the open areas of the agitator. Water along with soap and/or liquid softener sometimes splashes into an open agitator, and when the lid is closed it does not dry out. Instead, mold begins to form, and a musty smell wafts from inside the machine, even after the lid has been opened for an extended period of time. Until the mold is removed the washing machine will continue to smell bad, even if it is used and allowed to air dry with the lid open.The tub can also be the source of the smell. Lint can gather and collect in the holes, and when it does not dry fast enough it ends up smelling musty and moldy. Even the top of the rim can become moldy and musty, but proper cleaning can get rid of the odor.
So that said.To clean the machine,fill to just above the top row of holes in the tub.Add 2 cups of bleach.Let sit for 1-2 hours.Then let the machine run it`s wash cycle.Lastly use bleach water and a rag to wipe the machine down inside and out.If the agitator has a cup on top remove and clean with bleach.Leave the top open so the machine can dry.
Now it should smell better,if so use as normal,and leave the lid open when not in use.
May 15, 2011 | Maytag Washing Machines
After I dry my clothes, I smell this dead animal smell. Thought it might be a dead animal, but could it be the ring around the drum that is burnt? My clothes now dry smell stinky. We took it all apart...
thats the mold and mildew on the bellow that you are smelling. thoroughly clean the bellow. i also suggest that you purchase a tablet called affresh. this will help to remove that smell. if your machine does not have a self clean cycle then just put the tablet in and do a regular wash. if you machine has a clean cycle, just put tablet in and set on clean cycle. I also recommend that after each load you thoroughly wipe off the bellow and leave the door open for about 30 minutes so that machine can air out.
Feb 05, 2011 | Dryers
Heavy mold build up around rubber boot inside and out. clothes smell moldy when taken from finished cycle kenmore elite he4t model...
The following link can give you some advice on common causes of front loader washer odors and some preventive measures you can take to keep them from coming back:
The most common causes of persistent odors comes from not leaving the door OPEN between washes. The manufacturer recommends this to allow the wash tub to air out and to prevent mold and mildew from forming.
NOTE: Residual water in the drain lines and pump reservoir is NORMAL. Leaving the door open will NOT make this water evaporate, but will allow constant air flow to prevent it from becoming stagnant.
A common secondary cause comes from debris becoming trapped in the rubber door bellow and/or drain pump. It is recommended that you pull back the rubber folds in the door bellow (gray rubber seal) and check for dirt, debris or small articles of clothing that may have become trapped there. Socks are a common thing that become trapped, and if left for a long period of time, become stagnant. The drain pump reservoir is another common place for things to collect and become stagnant.
If you need to check the drain pump, the following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
You can use use a 50/50 mix of bleach and water to clean the door bellow thoroughly with a scrubbing pad to get rid of mold and mildew. Use the green kitchen type scrub pads as they are not as abrasive. Do not use steel wool. If the mold becomes permiated in the rubber and will not come off, you will need to replace the bellow to get rid of it. The following link explains how: http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load Replacement parts (if required) can be purchased from any of the following websites: searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
All these are preventive measures that can drastically prevent odors, mold and mildew. Read through the advice given and post back and let me kow if you require additional assistance. I hope you find this information helpful.
Aug 23, 2010 | Kenmore Elite 45986 Front Load Washer
We have Fuzzy logic and the smell s unbearable. We
The smell is residual soap and grease left behind in the machine because the wash temperature used is not high enough to kill it off also the detergent has been sanitized to a point where it also dislodges the grease but does not fully emulsify it
Go and buy one or two large boxes of common washing soda mix them in a bucket of very hot water.
Pour this mix into the tub before you start the machine , fill the machine using a high level very hot program and do a wash without any clothes in the machine.
You may have to do this twice.
Change your soap powder to one of the older type brands which contains bleach and soda (Daz, Omo ??).
When the machine has finished its work leave the lid open for an hour or so to allow air circulation to dry out the drum inside
Nov 10, 2009 | LG WFT1071TP Top Load Washer
Odor in front loading duet washing machine
The following link explains how to minimize wash tub odor, and what generally can cause it:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
I personally own one of these washers and have followed this same regiment since I purchased it new 9 years ago. I have never had a mildew or odor problem. Consumers that are not in the habit of using hot water very often will also run into odor and mildew problems, because detergent alone does not always kill bacteria. It is recommended that you run a "Clean Cycle" from time to time, to sanitize. Some newer models have a clean cycle added on the control panel.
NOTE: It is normal to have residual water in the drain lines and in the drain pump. If you need to clean, or check the drain pump, please follow the advice in this next link:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Debris caught in the drain pump reservoir can often cause some unwanted odors.
If the rubber door bellow develops mildew and mold, use a non abrasive pad (the little green pads are considered non-abrasive) and scrub the rubber with bleach diluted with water (50/50 mix). This will often kill and remove unwanted mold and mildew. If the door bellow becomes embedded with mold or mildew, it may have to be replaced in order to get rid of it.
If you establish and maintain a diligent routine, these washers will not mold or smell. Often what seems to be a dream appliance that is supposed to make your life easier, may actually require more attention in order to maintain it properly.
If you have questions or comments, please let me know. I hope this helps you.
Jan 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Musty smell
Make sure the door is kept open when not in use and also make shure that you do the cleaning procedure as described on the book once a month.
May 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My Kenmore Elite He3 sounds like it has water in the tub after washing AND smells of MOLD?
there is always some water left inside the machine and that is probably what you are hearing are you using liquid detergent? if so this is almost certainly the cause of the smell. liquid detergent leaves a nasty slime inside thge machine and smells like drains. put on a boil wash with no clothes and revert to using powder detergent
Apr 02, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
241 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
