Question about Nokia N95 Cellular Phone
Upon turning on it just shows the 'Nokia' emblem but won't proceed pass this step. Locks up at this point.
  • 2,069 Answers
It needs re-programing. You may not have the required hardware to flash( reprogram) it so I would recommend you take it to a qualified repair center and ask them to do it for you.
good luck
Posted on Dec 11, 2009
How do i factory rezet my nobis tablet when its froze and wont go past the nobis emblem screen?
Hi Jeffrey, The link below is a YouTube video showing how to fix your tablet, Also there's video's down the right side of the link that may help as well....CHEERS..
How To fix any Android Phone Tablet that won turn on
Apr 30, 2016 | Tablets & eReaders
How to replace front grill emblem on 2010 Volvo xc70
It takes less than 2 minutes and is very easy. Just did it on my 2010 XC60 (which should work the same as the XC70). Step 1: Get the new emblem from your Volvo Part Department (approx $35). Step 2: You will need a thin flat screw driver. Step 3: Remove the old emblem by pull the center of the emblem to where you can slip the screw driver between the grill and emblem to pry it off - once you get it started you can pull it off by hand. Step 4: Install the new emblem by inserting it in the various holes where it will snap into place. Rember to be careful so you don't scrath or dent the grill on the removal step. You can do it!
Apr 13, 2012 | Decals, Emblems, & Detailing for Volvo...
I am holding nokia 5230. I am faceing bluetooth connecting problem " When i turn on the bluetooth it show a message "UNABLE TO PERFORM BLUETOOTH OPERATION". Kindly advise me who to resolve...
This problem can be fix in 2 steps.By updating the firmware or a bluetooth IC replacement.
If you want DIY method for fixing the software,
* download this application to your computer and install it. NOKIA SOFTWARE UPDATER ,if installation is done, run the software and plug your phone to the computer by using usb cable,be sure internet connection is stable and back up all data first before proceeding,also battery must be full charge to avoid errors. Upon plugging the phone to computer,some driver installation takes place and let it finish,then follow the instruction on screen when updating,then wait until the update is done.
Now if the update is successful and then the bluetooth still don't work, just bring the phone to any service center near you for a complete diagnose and troubleshooting.They know what will do further.
For any question,please reply here to know the status of your mobile,
Thank you for visiting FixYa...
Jul 06, 2011 | Nokia 5230 Cell Phone
I have a bmw 330i and the doors will not lock using key, i have replaced the key but it didnt solve the problem... what needs to be replaced?
if the door locks work manually with using the key in the door then probably will need to just reprogram/initialize the key especially if its a new key. if the power door locks dont work at all using the key manually then first check the fuse.
initializing key:
all these steps must be completed within 15 sec. of cycling the key i.e. turning the key off
step 1: get in vehicle close all doors and trunk
step 2: turn ignition on tell all dash lights are on but engine is not started
step 3: turn ignition off pull key out
step 4: press and hold the unlock botton down while then at the same time press the lock button three times in a row
step 5: door locks should initializ at this point they will lock and unlock on there own to show process is completed
Mar 04, 2011 | 2003 BMW 330
Error #0502
The steps below will help you to identify and resolve each of these four issues.
pattlnk_4242006_196-lable.jpg Legend:A: Encoder Strip (semi-transparent grey strip)
B: Carrier Belt (black and brown toothed belt)
C: Cartridge Carrier
Troubleshooting Steps
Cleaning the encoder strip
WARNING! Be very careful when cleaning or adjusting the printer's encoder strip.
Required materials
You will need a dry, soft cloth
Embedded links in the table will take you to specific troubleshooting steps.
Step Action 1 Turn the printer off and disconnect the power cable from the back of the unit. 2 Open the printer's front cover.
Pinch the top of the carrier belt and gently move the cartridge carrier to the center of the printer.
pattlnk_4242006_1911-beltmove.jpg 3 Remove both of the cartridges. 4 Move the cartridge carrier over to the left-hand side of the printer using the carrier belt. 5 Gently clean the encoder strip with the cloth. 6 Move the cartridge carrier back to the right-hand side of the printer using the carrier belt. 7 Reconnect the power supply and turn the printer back on. 8 Perform the printer hardware test. Click here for instructions.
Did the printer pass the hardware test?
If yes, proceed to step 9.
If no, proceed to Reseating the encoder strip.
9 Power the printer back off and disconnect the power cable from the back of the unit. 10 Open the printer's front cover.
Move the cartridge carrier over to the middle of the printer using the carrier belt.
11 Reinstall the printer cartridges and move the cartridge carrier back to the right-hand side of the printer. 12 Reconnect the power supply and turn the printer back on. 13 Perform the printer hardware test.
Embedded links in the table lead to specific troubleshooting steps.
Step Action 1 Turn off the printer and disconnect the power cable from the back of the unit. 2 Open the printer's front cover.
pattlnk_4242006_1911-beltmove.jpg 3 On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Gently push the encoder strip down and then back up to get it into the slot. If the strip is completely out of the slot, it may be necessary to move it first forwards and then back.
pattlnk_4272006_149-reseatenc.gif 4 Move the cartridge carrier back to the left-hand side of the printer with the carrier belt. 5 Reconnect the power supply and turn the printer back on. 6 Perform the printer hardware test.
If yes, proceed to step 9 of Cleaning the encoder strip.
If no, proceed to the Black/Photo cartridge troubleshooting steps.
Black/Photo cartridge troubleshooting steps Embedded links in the table will take you to specific troubleshooting steps.
pattlnk_4242006_1911-beltmove.jpg 3 Remove the black/photo cartridge. 4 Move the cartridge carrier back to the left-hand side of the printer using the carrier belt. 5 Reconnect the power supply and turn the printer back on. 6 Perform the printer test.
If yes, repeat steps 1-7 with a new black/photo cartridge.
If no, continue to Color cartridge troubleshooting steps.
If you attempt the steps with a new black/photo cartridge and the error persists, proceed to Contacting Lexmark.
Color cartridge troubleshooting steps Embedded links lead to specific troubleshooting steps
pattlnk_4242006_1911-beltmove.jpg 3 Remove the color cartridge. 4 Move the cartridge carrier back to the left-hand side of the printer using the carrier belt. 5 Reconnect the power supply and turn the printer back on. 6 Perform the printer hardware test. Click here for instructions.
If yes, repeat steps 1-7 with a new color cartridge.
If no, proceed to Contacting Lexmark.
If you have attempted the steps with a new color cartridge and the error persists, proceed to Contacting Lexmark.
Feb 21, 2008 | Office Equipment & Supplies
Messed up with garmin
(1) Disconnect any external GPS antenna. (2) Do not turn on auto engine. (3) Turn off any other peripheral devices. (4) Simultaneusly hold down the PAGE and MENU buttons while turning on the 2620. A prompt box will appear asking if you really want to delete all user data. Touch the NO selection. Then turn off the 2620. (5) Simultaneously hold down MENU & ROUTE buttons while turning on the 2620. (6) A self-running diagnostic program will appear. Allow it to run for a couple of minutes; check to see that all parameters indicate "PASS" or other indication of being OK. If any parameter is not OK, make a note of it for potential communication to Garmin, then proceed with the following steps (7) Turn off the 2620. (8) Simultaneously hold down the PAGE, MENU & ROUTE buttons while turning on the 2620. A SCREEN CALIBRATION adjustment screen will apear. Quickly touch the points indicated as the calibration program runs. At the end of this procedure, the screen will display a window indicating that the calibration either "PASSED" or "FAILED." If it "PASSED," continue to steps (8)-(9). If it "FAILED," turn off the 2620 and repeat this step. If, after three calibrations attempts, each one is "FAILED," then also turn off the 2620 and proceed to steps (8)-(9). (8) Turn on the 2620. Press the "OK" button each time prompted to do so. Wait for maps to load and for the 2620 to initialize, acquire satellites, and display your position. (9) Press FIND button, then touch the right-hand vertical screen position adjustment to scroll screen display down to reveal WAYPOINT selection box. If unable to select WAYPOINT, or if attempting to do so only selects an adjacent box, then repeat step (7), and return to this step. (10) When various waypoint selections appear, attempt to scroll down to a selection not visible when the list of waypoints first appears, and select one of them. If still unable to select WAYPOINT box, unable to scroll screen down (or if trying to do so selects a stored waypoint instead), once again repeat step (7). If successful,then proceed to step (11). Also proceed to step (11) if you have repeat step (7) but then still can't select WAYPOINT, can't scroll down after selecting WAYPOINT, or can't select a particular stored WAYPOINT. (11) Press the upper-right hand "X" to close out the FIND screen or sub-screen within that function. If unable to close the screen, press the PAGE button. (12) Press FIND button, and when selection screen appears, touch ADDRESS. On next screen, touch the STATE line and touch the ENTER A CITY in (name of state). When keyboard appears on screen, use it to enter your city, then touch OK. Continue this procedure to enter your house number and street name, then press "OK." If all screen keyboard keys not responding, repeat step (7), turn the 2620 off and on again, wait for it to initialize, and then attempt this step again. (13) Repeat this procedure several times if not initially successful. By the second or third run-through, the touch screen should respond fully and accurately. If, after many runs through this procedure, the touch screen still will not respond, the screen sensor probably will need to be replaced ($255). The foregoing procedure brought my touch screen back to life last evening, much to my delight. Do not be too concerned if the SCREEN CALIBRATION step does nto produce a "PASS;" on my third calibration attempt it produced a PASS but all of the touch screen points still had not returned to functionality. I was unable to get a PASS during the screen calibration step after that, but the many repetitions apparently nonetheless made the difference, as by patiently following the above prcoess for five cycles, full screen functionality was restored.
Sep 03, 2007 | Garmin StreetPilot 2620 GPS Receiver
Touch screen does not work.
Jun 18, 2007 | Garmin StreetPilot 2620 GPS Receiver
Garmin touchscreen
This was just suggested for the exact same problem with my StreetPilot 2620 and worked like a charm: (1) Disconnect any external GPS antenna. (2) Do not turn on auto engine. (3) Turn off any other peripheral devices. (4) Simultaneusly hold down the PAGE and MENU buttons while turning on the 2620. A prompt box will appear asking if you really want to delete all user data. Touch the NO selection. Then turn off the 2620. (5) Simultaneously hold down MENU & ROUTE buttons while turning on the 2620. (6) A self-running diagnostic program will appear. Allow it to run for a couple of minutes; check to see that all parameters indicate "PASS" or other indication of being OK. If any parameter is not OK, make a note of it for potential communication to Garmin, then proceed with the following steps (7) Turn off the 2620. (8) Simultaneously hold down the PAGE, MENU & ROUTE buttons while turning on the 2620. A SCREEN CALIBRATION adjustment screen will apear. Quickly touch the points indicated as the calibration program runs. At the end of this procedure, the screen will display a window indicating that the calibration either "PASSED" or "FAILED." If it "PASSED," continue to steps (8)-(9). If it "FAILED," turn off the 2620 and repeat this step. If, after three calibrations attempts, each one is "FAILED," then also turn off the 2620 and proceed to steps (8)-(9). (8) Turn on the 2620. Press the "OK" button each time prompted to do so. Wait for maps to load and for the 2620 to initialize, acquire satellites, and display your position. (9) Press FIND button, then touch the right-hand vertical screen position adjustment to scroll screen display down to reveal WAYPOINT selection box. If unable to select WAYPOINT, or if attempting to do so only selects an adjacent box, then repeat step (7), and return to this step. (10) When various waypoint selections appear, attempt to scroll down to a selection not visible when the list of waypoints first appears, and select one of them. If still unable to select WAYPOINT box, unable to scroll screen down (or if trying to do so selects a stored waypoint instead), once again repeat step (7). If successful,then proceed to step (11). Also proceed to step (11) if you have repeat step (7) but then still can't select WAYPOINT, can't scroll down after selecting WAYPOINT, or can't select a particular stored WAYPOINT. (11) Press the upper-right hand "X" to close out the FIND screen or sub-screen within that function. If unable to close the screen, press the PAGE button. (12) Press FIND button, and when selection screen appears, touch ADDRESS. On next screen, touch the STATE line and touch the ENTER A CITY in (name of state). When keyboard appears on screen, use it to enter your city, then touch OK. Continue this procedure to enter your house number and street name, then press "OK." If all screen keyboard keys not responding, repeat step (7), turn the 2620 off and on again, wait for it to initialize, and then attempt this step again. (13) Repeat this procedure several times if not initially successful. By the second or third run-through, the touch screen should respond fully and accurately. If, after many runs through this procedure, the touch screen still will not respond, the screen sensor probably will need to be replaced ($255). The foregoing procedure brought my touch screen back to life last evening, much to my delight. Do not be too concerned if the SCREEN CALIBRATION step does nto produce a "PASS;" on my third calibration attempt it produced a PASS but all of the touch screen points still had not returned to functionality. I was unable to get a PASS during the screen calibration step after that, but the many repetitions apparently nonetheless made the difference, as by patiently following the above prcoess for five cycles, full screen functionality was restored. Thank you for rating this solution. Good luck and save you $250 for something else!
Jun 06, 2007 | Garmin StreetPilot 2620 GPS Receiver
Touch Screen Issue
Hi Troy, same problem with my 2610, It seems to be related to a voltage problem in my ford f-150 07. When starting the truck I think it sends current the wrong way because if i start and turn off the truck it goes back to normal, the problem comes back if i start the truck with the 2610 on. If this can help, the garmin tech also told me about the 225$ repair. Try turning the unit on and off and also your vehicule. Once it is ok, dont forget to turn the unit on and off while the car is on. It worked for me. I also know that this is not a definitive solution but it can help. Patrick
May 31, 2007 | Garmin StreetPilot 2620 GPS Receiver
Nokia N95 Cellular Phone Logo
37 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
