Question about Garden
Left tire is not locking out. When I try to lock it the lock piece spins and it looks like you are locking into a hole but it still doesn't move the tire.
  • jim gleason May 11, 2010
    is this a rear tine tiller or mid tine?
  • 513 Answers
There is a key that goes on the shaft that the tire set on look to see if the key is in the shaft and wheel
Posted on Jan 16, 2010
OK I have a 95 Chevy caprice there is a hole where my trunk lock is suppose to be, I bought the part to put in a new lock but I need to get in the trunk I cannot open it at all I need help
- Look at the part you bought to see what motion will be activated to release the trunk lid once it is installed.
- Look into the hole to see where that motion will happen, and find the piece that will get moved.
- Use a screwdriver or bend a small piece of metal so that you can reach the triggering mechanism.
- Press down on the trunk lid to reduce pressure on the latch mechanism, and move the release linkage appropriately.
- Should pop open.
- Bob's your Uncle!
Aug 02, 2015 | Cars & Trucks
How to take a spare tire off gmc envoy 2004
Since the spare is mounted under the rear of the car, Its not easy...you have to assemble the long crank rod out of its two pieces, then feed the rod through the hole in the top of the rear bumper and lock it into the mechanism that holds the tire in place. Once the crank rod is locked in, lower the tire towards the ground. Once the tire is low enough, you can crawl under the car and release the tire from its mount. The hardest part is locking the crank rod into the spare tire mechanism through the hole in the bumper.
Jun 17, 2014 | 2004 GMC Envoy
Brought riding mower into the garage thru a side door,after that back wheels locked up would not start after that ?
try bringing it in the front door but I don't think that will fix the problem. if the wheels are locked up there is a safety switch that will not let it start if the trans is in gear
May 26, 2014 | Garden
Swingline 74030 manual hole punch handle is locked down
by locked down I am going to assume you mean it will not go back to the normal postion when it is not making a hole. this can be caused by too many of the scrap pieces of paper that are left from making the hole. clogging the punch area. remove all the excess pieces of paper that may be stuck in the whole punch, then try again, you may have to pry the handle and or push and pull it until it releases. do not use again until the handle moves smoothly, clean the areas around the punch.
Mar 07, 2014 | Swingline 74030 Manual Hole Punch SWI74030
When in gear right wheel drives left wheel is locked and will not move same when not engaged
Many snowblowers use pins (or bolts - see image below) that pass thru the shoulder of the rim of the tires thru a hole drilled thru the drive shaft. Removing both of the pins allows the tires to spin freely on the drive shaft and makes it much easier to push, pull and turn the snowblower. If they are not installed again, the machine will not "drive" and make clearing snow difficult to do. Installing only one will make the machine want to go in circles. Make sure you have these pins installed thru BOTH rim shoulders and drive shafts - locked in place. Other machines lock the tires in other ways - since it sounds like one side is working correctly - you should compare the two tires / rims and make them both look like the one that works properly. Good luck!
Jan 06, 2014 | Ariens 926054 Snow Blower 2 Stage 32 In
Left rear tire locks going forward but not in reverse
There is probably parts of the bearing that are rubbing against each other and jamming, lift the rear and move the wheel in and out (like shaking), also spin the wheel and listen for grinding noise, if it moves or makes irregular noise, your bearing needs to be replaced, if everything is tight than check your brake shoe pads, a dislodged piece may be jamming between the shoe and the drum(it happened to me before!).
Dec 14, 2010 | 1995 Toyota Camry
Back right tire is locked
see if brakes are stuck, take apart and see what is stuck
Oct 04, 2009 | 1988 Mazda B2200
Dyson dc07 will not lock into upright position
- Stand behind the vacuum cleaner and look at the right-hand side wheel
- Remove the AI PIPE (it has two purple buttons that you push together to lift it up and out - it looks like a Tuba)
- Lay the handle down and look for a black button that will be exposed in front of the square hole
- Stick your index finger and middle finger into the vacant AI Pipe Hole (the square hole)
- Reach over with your thumb and press the black button in front of the square hole
- Whilst pushing the black button, lift your index finger and your middle finger and move the gray plastic piece up (lift the square hole basically)
- Remove your fingers from the square hole
- Lift the handle and stand your machine back upright again
- Place the AI Pipe back into the square hole
Jul 12, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Transfer case locks into low gear but front wheels do not pull
You have to have your front hubs locked in for four-wheel drive to work
Jun 10, 2009 | 1992 Jeep Wrangler
Installation of mercedes hood emblem e class 1998 E430
Look at the new one real close and you will see the locking device that has to be pulled down and turned. It is locked in place so the ormanent will fit through the hole. Just remove whats left of the old one. Push new one through the hole and hold in in place from the top while turning locking piece under hood  with pliers 1/4 turn. The locking piece is spring loaded so you will have to pull down and turn. That's it.
Dec 30, 2008 | 1998 Mercedes-Benz E-Class
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
