Question about Hitachi 46W500 46 in. TV/DVD Combo
Sound but no picture
I have flashing colors on my screen,first a red screen then a blue and then green. Sometimes black and white and rolling like the old tvs when the horizontal hold was out. Sound is good. When I select picture in picture The small picture plays beautiful. but the large pic. is still out. has anyone experienced this type of problem. I have some electronics background. Can I fix this? What do I need to fix it?
  • Sniper 67 Jan 22, 2008
    Thanks for the advice. I have two tuners in my tv. I swaped them and my tv works great. I don't have picture in picture mode now, but I never used it anyway. I did order a spare one from for 70.00 Thanks again
  • 86 Answers
If PIP works, have you tried to swap pictures. You may have a tuner out.
Posted on Jan 20, 2008
IGO tv connected with dish sound come from tv but pictur not show only blue color show
Component RCA Connectors are RED, BLUE, GREEN for picture. Sound is RED and WHITE. The red and white for sound work the same with the YELLOW that does picture. If the RED, BLUE, GREEN are in the wrong order you will get a blue or green picture. For the sound, try the other red and white connectors nearby. Make shore the right red connectors are connected correctly for sound or picture. Otherwise there could be a cable fault or a TV fault. If you get the picture right but not the sound, connect the sound into a stereo.
Jul 17, 2017 | Televison & Video
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
Picture is black and white, but I have sound. I have red, green and blue plugins. The green one is fine, but I'm not sure which spots to put the red and blue wires in to fix the color.
blue is always in the middle and the green / red are on the ends. Black / white means you have the wrong matching cables. You need to make sure to match red to red, green to green, blue to blue.
Sep 09, 2011 | Sceptre Televison & Video
Plugging red to red, white to white, and yellow to SPDIF (black) and got no picture with sound. Plugging red to red, white to white, and yellow to green and got black and white picture with sound. How...
First you need a component cable to solve your problem.Since you have not mentioned what device you are connecting to your TV, I''ll assume its a DVD player or a settop box.There is a Red and White audio sockets + Red / Green / Blue component video socket. Just make sure you connect the corresponding two sets of jacks at both end of your TV & DVD player and everything will work. bobhifi_21.jpg
Mar 27, 2011 | Philips Televison & Video
No sound on play back using camcorder on technika tv
Looks like you are using Component cables. There are five cables. The first three cables are Green,Blue and Red. These are the ones that are molded next to each other and are the Video signal cables. The other two cables are Red and White and they are the audio cables.
First to correctly hook up these cables you need to Connect (Match) Color for Color. (Green to Green, Blue to Blue, and Red to Red. To tell if you have correctly connected the Video cables is to look at the screen. If the picture looks ok (Normal with no colors missing then you have connected the video cables correctly). If you see a missing color meaning red, then switch the Red cables. The picture should be ok now. The remaining two cables are the Red and White cables. The "Red cable" is for the "Right" audio input and the "White" cable is for the "Left" audio Input". If all is connected correctly then you should have a good picture and Left and Right audio.
Jul 05, 2009 | Televison & Video
My screen turns green and then turns off
you need to adjust the screen voltage. behind the front grille and inside cover. a small black box 6 adjusters protruding from it. only adjust the the color counterclockwise that matches the problem in this case it's the green so look for the knob with "G" marked by it. there are 2 with "g" marked by them the row across the top of the box are for focus don't adjust. back the knob off untill the raster is blank with your input set to an inactive input, the picture should be blank and black.
when it is you have the adjuster close to where it should be, now change the input to an active signal and turn the color off so that you wil have black and white picture. adjust that knob untill you do have a truely black and white picture not too green or red or blue. go back to inactive video input and check that there are no lines of any color on the screen. repeat if needed. always adjust these knobs slowly the set will be watching you ! if your autofocus won't work now you have the adjustment set too low. check this function before putting back together again. these adjustments can be real touchy so be patient
Feb 20, 2009 | Sony KP-57HW40 57" Rear Projection...
32'' Insignia LCD is flashin colrs. wh,blk,rd,grn,blu. audio wrks
It could actually be quite a few things, loose wire, loose solder piece, bad crt's/picture tube, bad system board, or others. It's would have to be diagnosed with testing equipment. It will probably cost you another 150-200 for the new part to be put in.
Jan 28, 2009 | Televison & Video
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Hitachi 46W500 46 in. TV/DVD Combo Logo
254 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
