Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Kenmore oven model 790 takes a long time to come on. when it does it makes a big bang
    President:
  • 744 Answers
Hi the reason you are hearing a big bang is because your igniter is old and needs to be replaced. Over time these igniters don't get up to the temp needed to ignite the gas quick enough but they do draw the amps in order to open the gas valve. so what happens is the oven fills with gas and then when the igniter finally ignites the gas you hear a boom because the oven is full of gas. replace the igniter and you will be all set. If you have any other questions please feel free to comment. Mike
Posted on Dec 10, 2009
  • Kenmore Master
  • 3,361 Answers
You have a gas leak. Do not use the range until you call a service company to correct the gas leak problem.
What is error code E035 on a Kenmore electric range w/ an invection top and a convection oven
Kenmore 790 Model Induction Cooktop Error Codes Sears PartsDirect
Take a look at this link ... for model 790 it indicates that error 35 is:
Improper power supply voltage (low voltage) or failed wiring connections
Check:
Disconnect power. Check the power supply wiring. Have an electrician check the supply voltage. If the connections are good and the voltage is normal, the main power control board or filter control board is defective.
So it may need a new control board...
Mar 14, 2018 | Kenmore Kitchen Ranges
Removing the top of my Kenmore model 790
You could have asked in the original post. :>)
Look at the upper rail of the oven at the front. Look for clips that unscrew and will allow you to tilt the top backwards.
Oct 29, 2015 | Kenmore ELITE 790 30 FREESTANDING DUAL...
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Electronic Oven Control for Kenmore model # 790-30172400
If the part numbers are the same then you can use that board. The revisions are to so that the control boards can be used on models that may have other features that yours may not.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 23, 2012 | Kenmore Ovens
My kenmore 790 oven will not lite is there a pilot light?
if you have no bake most likely you need to change out the ignitor,next time send the model number,if it's a stove with the burners on top open the utility draw and on the left or right side on the frame you'll see the model number
Oct 17, 2010 | Kenmore Ovens
Oven doesn't work. Display F30 code. Gas Range model: 790-78579405. First time usage for oven. All stove burners does work. Some blogs mentioned "reset" red buttom but couldn't find it from the back metal...
Part of the model number 790 says, that the range is made by Fridgidaire. F30 means the sensor is bad and/or main board. There is no red button. You can find you part here: www3.sears.com
Kenmore range repair in orange county, ca
Feb 11, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore oven error code f10
on that type of range F10 indicates a problem within the electronic control, but it could possible be caused by a faulty temperature sensor.
I would recommend service from a technician
May 27, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
267 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
