Question about Marantz RC5200 LCD Touchscreen Remote Control
Was downloading a file and the battery went flat now the remote is trying to turn on and making a beep noise then rebooting and repeating tried to download again and also update firmware. is there a full system recovery file available to completely wipe and start again
    Top Expert:
  • Marantz Master
  • 79,865 Answers
How do I reset the RC5200
Carefully press the reset button inside the battery compartment of
the RC9200/5200 with a paperclip or sharp pencil. The
RC9200/5200 restarts and beeps to indicate it is ready for use.
If there is a problem stillthe software may need to be reinstalled, see below.
Restoring The Default Marantz software File Via PC
You can restore the default Marantz configuration on any Windows
PC with internet access by using your internet connection to
connect to www.marantz.com. Download RCEdit, a self installing
file. Install RCEditby double clicking on the downloaded file. Start
RCEdit from the Start button program menu. Connect your
RC9200/5200 to your PC. Once RCEdit is up and running, choose
Open Configuration from the file menu. Click on Samples and
double click on the file named “New_ RC9200/5200_Default.” Now,
from the file menu choose Download to RC9200/5200. The file will
download and the Marantz default file will be fully restored
also here is a link to the user manual
http://www.d-mpro.com/users/getdownload.asp?DownloadID=1
Posted on Dec 10, 2009
Philips TSU2000
Hello there.
Please check this link http://www.remotecentral.com/pronto/pfaq.htm
for steps on troubleshooting the problem with the device.
Especially the section:
A6-03 What can I do if the remote will not power up and I hear 4 beeps?
This usually indicates that the CCF file is corrupt. To correct this you can try downloading your file again from ProntoEdit. Otherwise, you must re-flash the firmware using the TOOLS | UPDATE PRONTO menu option in ProntoEdit (or TOOLS | UPDATE RC5000 in RC5000 Setup) while the remote is connected to your PC. You may experience this problem without ever having connected the remote to your computer. The solution is still the same: you must update your remote via the PC software.
Hope this helps.
May 11, 2008 | Philips TSU2000 LCD Touchscreen Remote...
Keyless entry of subaru imperza 2008 is not working
subaru have 2 security codes one for the key/ignition switch(magnetic code)and one for the remote(rolling electronic) the car is reccognising the key but not the remotes signal to the central locking.
try locking the car with the key then pressing and the holding the unlock button on the remote for 30 secs, see if the car unlocks.if not unlock the car etc....or... put key in door and hold over for 30 secs..etc
Mar 02, 2010 | 2006 Subaru Legacy
E6500 making a beeping noise
Does beeping noise happened before turning on laptop? If yes unplug the laptop from the AC Adapter. Just leave AC Adapter ON and connected to the power outlet. Check if AC Adapter is the one making beeping noise. Note: This is an issue with dell AC Adapter laptops
If no beeping noise in AC Adapter then proceed checking it from the laptop. Does beeping noise happened immediately when laptop is turned on? If yes then it might be laptop's hard drive creating the sound. Try to check the BIOS in your laptop under the category performance if the HDD Acoustic is ON either in Normal or Performance. Note: When laptop is in performance the hard drive makes noise due to its speed, this is normal if BIOS HDD Acoustic mode is ON to performance.
If the noise only happens when sometime while working on the laptop, this might be cause by the laptop fan. This also happens after turning on the laptop fan my have dirt and dust, please do check.
If fan was cleaned, HDD performance was checked and AC adapter was checked then, carefully sense if noise is coming from the internal speakers.
Download the latest BIOS update for your laptop then flash the BIOS. Make sure battery and AC adapter are connected when doing these.
Dec 11, 2009 | Dell Latitude E6500 Laptop
Hang computer no beep .
Yea... problem with your CMOS battery, try to replace it and update you BIOS.Updating BIOS can be done through the Internet, download the latest firmware to update your BIOS.
Save and reboot your computer.
Hope this Helped!
Sep 07, 2009 | Computers & Internet
Car used 2 days ago fine. Went to start today and the remote only opened the driver door. Put key in ignition and hazards went off then made a clicking noise when tried to turn over and the lights on the...
Yes, this sounds like a flat battery. You could try to get a jump start off someone else, so that you know it is definately not the engine. Otherwise, purchase a new battery and you should be fine.
Jul 25, 2009 | 1999 BMW 328 Series
Continuous Beeping, new PC
Hi.
Continues short beeps... means a short OR no power OR loose card OR system board.
Test it without the keyboard and mouse too. Just the Processor with heatsink, motherboard, memory and Video card.
Now add the keyboard, no mouse yet.
Check also the voltage of the CMOS Battery it should be 3V.
keep me posted for the result... count also the beeps.
Feb 09, 2008 | Intel Motherboard
HP ZD8000 won't come on
Try to change the RAM and see if that helps the beeping. Normally, repeating beeps mean bad RAM. Not sure what the problem is with the disk drive, seems to be a mechanical problem. Thanks, Lolita
May 15, 2007 | HP Pavilion zd8000 Notebook
Marantz RC5200 LCD Touchscreen Remote Control Logo
63 people viewed this question
Top Marantz Televison & Video Experts
 Grubhead
Grubhead
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
