Question about Whirlpool Washing Machines
Whirlpool mod. wfw8300sw03.it is leaking around bottom of door
I have a whirlpool model # wfw8300sw03.Is there any adjustments to door or do I have to replace the bellow. I have a leak around bottom of door when washing.
  • 1314 Answers
SOURCE: Kenmore 44082 Front Load - Door Leak
you did fine several companies built kenmore for sears yours looks like a frigidaire on some models there is a problem with water collecting at the bottom of the door where the bellows or boot is and leak to correct this they came out with a new boot that has a channel at the bottom with three holes in it so the trapped water can drain back into the tub the parts kit for that is 5303937187 now on washers with rubber boots its recommend that you shut the door with a little force to make sure it closes tight against the boot sorry about the letters they came with the part number you might want to call kenmore parts to ask about the boot kit if i was there i could tell you but it looks like a frigidaire to me
Posted on Mar 13, 2008
SOURCE: whirlpool duet front loadsher leaks at the bottom of door. how do you replace the seal around the door
On this same machine, I need to replace the boot, but I also need to replace a broken baffle. Is this a very difficult task? The old one seems to have been snapped to the tub.
Posted on Mar 22, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore HE2 Washing Machine Leaking
Have you looked behind the bellow under the folds to make sure there's no rips or tears? The bellow could appear okay on the outside, but still could have a tear somewhere out of plain view. I had this happen to me before.
The inner seal from the bellow to the tub could also be loose now. If you said a garment got stuck and the washer continued through the cycle, this could have loosen the seal where it attaches to the wash tub. You would need to tighten the band clamp around the facing of the tub if this is the case.
A good way in determining where the leak may be coming from is to remove the lower panel under the door. Start a wash cycle and watch to see where the water is coming out.
Now...if the tub seal is loose it may require some disassembly to get to. If you're going to go the route of disassembling the washer front, and have never replaced the bellow before, it probably wouldn't hurt to replace it anyway. My rationale: It's better to disassemble the washer once, rather than possibly having to do it all over again in the near future.
You can get a replacement bellow at searspartsdirect.com. Just type in your model number and look under the "Door and Latch Parts" section for item number 1 (part #8540952). It only costs about $32.
If you need instructions on how to replace the bellow, just go to my profile and look under my "Tips and Tricks". There is a write I posted there giving step-by-step instructions. If you cannot find it, or have any further questions, please post back and let me know. I hope this helps answer some of your questions.
Posted on May 04, 2008
SOURCE: Kleenmaid top loader Washing Machine Mod KAW 793W leaking
Problem turned out to be a leak from the top, not the bottom and was caused by debris blocking an overflow trap
Posted on Aug 07, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool washer WFW8300SW03 bellows replacement
The following link explains, step-by step, how to replace the door bellow on a Whirlpool Duet:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If you have questions about this repair, or require additional assistance, please let me know. I hope this helps you.
Posted on Jul 19, 2009
Duet sport wfw8300sw03
try unplugging and plugging back in. a reboot of sorts.
i am not a repair man, but I own one too. good luck.
Jan 28, 2018 | Whirlpool WFW8300SW
DOOR LEAKING
Check to see if door is warped or dropped down. Adjust same. Clean boot & door where they meet with detergent. Door lock mechanism worn & not holding door closed tightly. Some model have adjustments on door.
Dec 21, 2013 | LG WM-2277HW Front Load Washer
F28 code on a whirlpool duet sport model # wfw8300sw03
There is also a safety switch on the bottom compartment, if the cover is off it will display F28.
Aug 11, 2012 | Kenmore HE2 Plus Front Load Washer
I just installed a new Whirlpool Mod # DU 1300XTVT8 and it is leaking around the door. Is there anything I can do about it.
Hello, Thank You for using FixYa. I will be helping you today. Usually when there is a door leak it is due to the unit not being level and square i would start there.
Thank You and please rate my answer if it was helpful..
Jun 21, 2011 | Whirlpool DU1300XTV Builtin Dishwasher
A built in whirlpool dishwasher is leaking around the door seal, right side to be more specific. cleaned the seal, and along the bottom and it still leaks. Is there an adjustment that can be made to...
There is no adjustment per say on this door or seal. If water spray directly on the door it can cause this, what I mean by that is if the spray arm, either the upper or lower is stuck and continually sprays in one place it can cause the water to leak by the door.
If the wrong type of detergent got in the dishwasher and there are suds or foam this could cause the dishwasher to leak a bit too.
If the dishwasher is not level or not mounted tight the door may not be hitting the seal right.
If all of these are not the problem I have heard of people putting a bit of silicone behind the gasket in the area it leaks, this will make the gasket a bit thicker to possibly help.
Apr 24, 2010 | Whirlpool Dishwashers
How do I change the door gasket on a Whirlpool Duet washing machine model WFW8300SW03 I have the new part
The following link explains step-by-step how to replace the door bellow on a Whirlpool Duet series front loader:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: You can view helpful exploded view diagrams of your washer at searspartsdirect.com for assistance as well.
Apr 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Bosch dishwasher door leaks
Hi have you adjusted the door striker on the top part of the dishwasher? This is the part that the main door latches onto and can be adjusted in or out!
Feb 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
The door leaks on my whirlpool front load model wfw8300sw03, looks like the door isnt sealing tightly, if I push on the door it stops lealing, any ideas?
you might have a bent door hinge, but most likely you have a worn door boot. its the grey rubber thing that the glass seals to.
try to lift up on the door to get the hinges back into place and if that doesnt work then you might need to replace the door boot.
look at the edge of the boot where the glass hits it. the glass must seal to the rubber and if the rubber is worn or torn then it wont seal.
not an easy piece to replace but it can be done. i wouldnt recommend trying it first as you will find it very tight to get your hands into and the clamps are hard to figure out as well.
Feb 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
145 people viewed this question
Sal De
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
