Question about Sharp 13VT-R100 13 in. TV/VCR Combo
Sharp Model 27SC370
Since day 1, TV has turned itself off anywhere from 6 minutes to 8 hours. Warranty service shop could not come up with a fix, but soldered a few connections.
  • madelyn65 Apr 23, 2008
    i have a tv that is 10 yerars old, it just started turning it self off after 10 minutes in use. i would wait a couple of minutes then start it again and again after waiting a couple of minutes it starts again. but only stays on for like 10 minutes. is the tv going and why does keep starting if it is
Same problem here. TV would turn off but would not turn on after a period of time (until waiting a minute or two) then able to start again. Intermittent problem too.
Posted on Jun 12, 2008
I am looking for a download link for the First Alert ET321 with photocell. I have misplaced the original package instructions and cannot find this material anywhere! Your assistance would be greatly...
Here is how it works. The push button repeats itself in following sequence (must plug in). F 1 2 3 4 5 6 7 8 9 A d 1. 2. 3. 4. 5. 6. 7. 8. 9.
F: timer is off. 1 2 3 4 5 6 7 8 9: from dusk to dawn count down number of hours repeated every day. That's most useful to control outdoor lightings. A: from dusk to dawn count down number of hours which is randomly selected by this timer. Which is usually for indoor use to turn lights on and off for number of hours. The randomly selected hours is a security feature so that lights on (I believe the on time is within the range of 1 hour from dusk set by the timer) and off (it is randomly set, you can see the display blinking showing the selected countdown hours) shows no pattern to outsiders. d: just on from dusk and off at dawn. It is also used to control outside lights but just a little wasteful in my opinion. 1. 2. 3. 4. 5. 6. 7. 8. 9.: meaning count down number of hours starts from the time when the button is pushed so that you can have a countdown timer at any time.
Oct 11, 2010 | Impact First Alert Outdoor Digital...
Sharp tv model lc-26sh12u very low vulumn even at max volumn control
Yes, don't buy SHARP, problem solved! SHARP is the worst brand of LCD TV. I had to bring my brand new SHARP TV in for repair within 8 months of buying it brand new, and of course it was no longer under the 90 day labor warranty. Also, every person I know who has a SHARP TV has issues with volume and eventually end up with a black vertical line along the side of the screen within 1 to 2 years. I highly reccomend SONY, PANASONIC, even SAMSUNG, LG or VIZIO. Heck, I'd go with Toshiba or Phillips before I'd ever buy anything SHARP again I was so annoyed with their customer service.
Sep 30, 2009 | Sharp Televison & Video
My Philips 32PFL5403D LCD TV does not turn on and blinks 6
Normally, this happens when the TV detects a bad circuit board and goes into " Protection Mode ". The blinking red light should be a error trouble code. I don't have the Service Manual on hand for your model number to tell you what the code means. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 15, 2009 | Philips 32PFL5403D/27 32 in. LCD TV
My Emerson EWL20D6 turns itself off after about 6-8 seconds
It's the #1 plaguing issue with Emerson flat panel TV.
Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board.
The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can'tactually look at the tv over the internet. I can only make guesses with the symptom.
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
Jul 13, 2009 | Emerson EWL20D6 Television
Sharp D64 37" issue (Power+OPC light flash and won't turn on)
I'm going to guess your friend's model is LC-37D64U. ( 37" screen; D64 series)
It's sounding like a power supply problem for the LCD screen. It's somewhat common problem for big LCD screens. But, too early for your friend to be having this problem with the TV.
I would have your friend use the warranty at this point. Last thing you want to do is void the warranty by opening up the TV.
I would first try leaving the TV unplugged for 30 mins so it can reset. Then, try turning it ON again.
If that doesn't work, it warranty time.
If your friend just bought it, have them exchange the TV for another one. I wouldn't want a TV that has problems that just came out of the box. The Sharp TV only has a 1 year warranty. Upgrade warranty life if possible. A repair for a problem like this would cost about $100 for someone to look at it; and $200 to $400 for the part at a TV repair shop.
May 12, 2009 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Power surge. Now my Sharp LC-46SB54U TV won't power back on.
Just a quick question... Have you called to check the warranty status? I couldn't find anything online about how to check Sharp's product warrantees.
I am not sure of any specific reset codes for your model of Sharp LCD TV; however, you should not be charged for warranty service.
You can always offer the dude a beer in exchange for teh codez...
But...
Here's a good link for warranty phone numbers:
http://www.officeexpressinc.com/warranty.html
Sharp Electronics Calculators, EL Series
Calculators, QS & VX Series
Fax Machines
MultiMedia Projectors
TVs, Aquos
Wizard Electronic Organizers 6 Month Parts and Labor
90 Day Carry-in from date of customer purchase
Sharp warranty requires end user to contact Sharp directly. 3 Year Limited Warranty including 2 Year Express Repair
Sharp warranty requires end user to contact Sharp directly. Warranty for Aquos TVs is One Year Parts and Labor. See warranty card included with product for more information.
1 Year Parts and Labor (800) BE SHARP
(972) 690-9064
(800) BE SHARP
(800) GO SHARP
(800) BE SHARP
(800) BE SHARP
Feb 06, 2009 | Sharp LC46SB54U 46 in. LCD TV
Flashing green power light with no picture
9-if the tv is still under the manufactuer warranty i would definitly give them a call. If it is a Sharp tv I would call the 1-87-BESHARP. I would also try unplugging the tv for at least 2-3 minutes and seeing if the tv will reset itself. Usually what happens with these tv's when the light blinks it locks the tv as a security issue. If the unplug does not help it will more than likely need service to get this fixed for you. The call line hours are M-F 7am-7pm S-S 9-5 and they will be glad to help you from there.
Nov 08, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos red flashing light tv won't get picture
Nov 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
T.V. turning on
yes my 26" sharp aquous LCD does the same thing, turns itself off and on at random times without explanation. I sent to authorized service center they replaced the power supply under warranty then it failed within 6 months and neither the repair center nor sharp will do anything about it other than sell me a new powersupply for $425.00. I have contacted a power supply repair center in Texas who has vowed to fix it once and for all. We'll see in the next week if they fix it or not.
Oct 30, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
TV will lose picture then go into standby!
Yes it is a temp problem as you found out for your self Great call on that BUD.. the best thing to do is contact sharp to see if they have had simular problems and if there are any recalls on this model . If not they will instruct you where to send the monitor into to be fixed.
Mar 31, 2006 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp 13VT-R100 13 in. TV/VCR Combo Logo
188 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
