Question about Amana ARB2557CSR / ARB2557CSL Bottom Freezer Refrigerator
MODEL# ARB2557CSL STARTED MKING CLKING NOISE TWO
MODEL# ARB2557CSL STARTED MKING CLKING NOISE TWO DAYS AGO NOW HAS STOPPED FREEZING , SOUNDS LIKE A BREAKER CYCLING
    President:
  • 744 Answers
Hello, this problem is going to be with the relay on the compressor or the compressor. Pull the refrigerator out and remove the bottom panel off the lower rear of the appliance. Behind the panel you will see the compressor. On the side of the compressor you will see the relay cover. remove the cover then pull the wire harness off. next give the relay a tug and it should pull off. Once you have the relay in your hand give it a shake. if the relay rattles then your problem is the relay. If the relay does not rattle then the problem is with the compressor. You should call a service guy. If you have any additional questions please feel free to comment. Mike
Posted on Dec 10, 2009
My fridge - model RS583HDP started making a noise in the fridge section a few days ago, like the fan was working quite loudly and every time you openned the fridge section, the fan slowed right down and...
try to lubricate or replace bushing of your evaporator fan maybe it has awear in tear that fan hard to rotate this can cause a noise and poor circulation of air cause of temp. rise
Feb 13, 2011 | Samsung Refrigerators
2002 GE Artica Fridge stoppped cooling and freezing.
Hi monica ,
the heating element in your freezer might be bad or the thermostat. that is way your freezer is not melting the ice inside and the noise that you hear it's the fan that prob' tuch ice or also is getting bad.
let me know if you need more help...
Jan 08, 2010 | Refrigerators
Hi, i've got the arb2557csr. Been great for like five years now. A few weeks ago my water lines in the fridge started to freeze. Takes a few seconds to build up enough pressure to push the icey water out....
when the compresor is failing then you can get uncontrolable tempts this would cause the ice lines . / sounds like it time to replace or do major repair . ****
Jan 04, 2010 | Amana ARB2557CSR / ARB2557CSL Bottom...
Samsung SR S2028CSS Fridge Freezer - Fridge temperature problems
Try setting it to lower temperature. If that don't work the thermostat is bad.
Jun 28, 2009 | Refrigerators
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
Kenmore fridge stopped cooling
sounds like its freezing up on you. check the drain outlet and make sure that its clear. also i would replace the defrost timer on this unit because its suppose to bring on the heaterfs to melyt the ice so thaat yoiu don't have to. they are around 30 mdollars at the appliancew repair store and all you need is the model number and serial number for the uit. after you get it it's either on the very top of the refrigerator section or in the very back. It has 4 wires going to it. good luck.
Jan 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Jun 26, 2008 | Amana AFD2535DES French Door Refrigerator
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Amana ARB2557CSR / ARB2557CSL Bottom Freezer Refrigerator Logo
362 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
