Question about Boating
How do you replace the throttle only button mechanism ? 1986 Mercury 50hp outboard engine with Quicksilver shifter. Throttle only button does not work. I took it apart but the piece inside was broken in the process and now I need to put it back together again. I bought a Mercury service manual but it only covers the engine. I need a manual or other help for the shifter.
2 Suggested Answers
  • 5676 Answers
SOURCE: I have a mercury outboard 50hp engine that will not start
If you are saying the Flywheel is locked or Frozen then I imagine the starter Bendix was found extended and jammed against the Flywheel.
If the motor ran when it was shut off last, then your rings and/or bearings rusted in place. You don't want to grab the prop to turn it because it will strip the Rubber hub.
I would take out all the spark plugs, tilt the engine up as close to level as you can get it and spray WD40 into the cylinders. If you did not have water connected to the engine the pump may have crumbled but if the engine did not turn at all the pump may still be good.
Give the WD some time to penetrate and crank the engine to see if it broke loose. If it did not, you may as well drop the lower unit and eliminate jammed gears with a second try at cranking the engine.
If still no luck, you might try to rig an Air fitting to the Sparkplug holes and hit each with about 80PSI and another squirt of WD. This will force the WD deeper and force the pistons down with no damage.
Still no luck, then its disassemble time. Good luck on this.
Posted on May 27, 2010
Power trim on. Throttle will only raise the engine up not down, 50hp mercury outboard. Works manually on engine.
I recommend looking at swapping the solenoid. It's not that expensive to do. There is one for up and one for down. Sometimes you can bang on them with a screwdriver and it will work again and get unstuck, but still would replace even if you get it working. Cheap fix. Usually 3 wires.
Jul 12, 2017 | Mercury Boating
50hp Mercury outboard electrical schematic
Hey David,
Yo should find all the info you need here..this will be very very helpful...' Mercury Outboard Manuals by Seloc 1965 2014
Jun 07, 2017 | Mercury Boating
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
2000 Mercury 115 ELPTO impeller replacement. The Quicksilver replacement kit comes with various washers / face seal. The water pump housing didn't have a seal on top of the old one. Am I supposed to use...
if you mean a large flat sided 'O' ring then this is to help keep water in the impellor housing !? some housings have gaskets between the base plate and housing , check the impellor in the housing and see if it stands proud as then you need the gasket ! compare with the old one as it mite have been forgotten !! check the seal and tube for the water pipe also ok!
Sep 23, 2013 | MERCURY / QUICKSILVER Mercury/Quicksilver...
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
Quicksilver throttle
I recently aquired a 1982 Merc Bigfoot 60hp with a quicksilver throttle control. I am trying to find a manual as to the throttle operation. Any suggestions?
Chuck flochu1@yahoo.com
Jul 27, 2010 | Boating
Smoke coming out of bottom carb on mercury 50hp outboard engine
It's possible that a little fuel vapour come out of a carb on an hot engine that has just stopped.
Does the motor starts again and runs well in higher rpm ranges? Is the stall only when idling? If so, enrich the idle fuel mix ( screw out the idle mix screws half a turn t a time )
Aug 06, 2017 | Boating
Re-assembling lower unit of 40HP Mercury 4 stroke
I found a lower gear case assembly diagram at http://www.crowleymarine.com/mercury_parts/6995/240.cfm which helped me understand how the shift mechanism works. This clued me in to the fact that I was missing the cam follower rod which I then found I had inadvertently mopped up in a shop towel when cleaning up spilled gear oil. After that discovery, assembly and operation was quick and successful.
Nov 11, 2009 | Quicksilver Quiksilver - DEEP 300 - SILVER...
It will not go into reverse but will go into forward. what should i do first? 1986 mercury outboard
You did not tell us if you have a small outboard or if you have remote shift controls. If you do have remote shift controls you can try reversing the cable ends if it is a 2 cable system or disconnect the cable at the engine. By disconnecting the cable at the engine you isolate the problem to the motor. Then you can grab the shift lever manually at the motor and see if it will now go into reverse. Some remote levers lock out reverse if the choke is engaged or if you are new to this boat there may be a button to push on the throttle to allow reverse to engage.
May 17, 2009 | Boating
Quicksilver throttle assembly
yes the switch could be bad. Is it on the throttle? Does it work on the engine? I have had my switch go out twice on my mercury.
Aug 25, 2008 | Boating
Boating Logo
148 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
