Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Lights stay on in fridge
Light stays on when doors closed. temp in fridge is 85 degrees, cover for bulb melted and bulb sockets burned, wires to sockets burned.
  • 6,784 Answers
HI. The door switch will be the culprit here.
The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Posted on Dec 11, 2009
LIGHTS STAY ON IN FRIDGE
LG had a problem with the control board going bad allowing the interior lights to stay on even when doors are closed. you need to get in touch with LG concerning repair MY UNDERSTANDING is there is a safety recall and it will be repaired for free. in the mean time unsrew the light bulbs so they dont melt down your liner...
Oct 03, 2012 | LG Refrigerators
We have a Lg LFC25760SW fridge and the lights stay on in side the fridge
LG had a circuit board malfunction with many french door models with fridge lights staying on with the door closed. the bulb lens usually overheats; deforms; and falls off. the plastic frame surround is warped too. the bulb sockets are darkened too. if this is the case, call LG and they will usually repair this overheating issue for free. you can just unscrew the bulbs for the meantime.
Jun 15, 2010 | LG LFC25760TT Titanium Bottom Freezer...
Inside lights do not go off when doors are closed
Good day,
All refrigerators have light switches, that depress and shut off the lights when the doors are closed.
First, make sure the bulbs are left out. I would replace all of the light switches because of the newness of the machine.
They are easy enough to replace, and you can purchase them at any appliance parts house or a Sears service facility.
They pry out, and may be destroyed on removal. Unplug the machine.
After connecting the wires, the new ones just push in.
To test, close the doors slowly. The lights should go out just before the door closes.
Some states have what is called "Implied warranty of serviceablity". Which means what should a consumer reasonably expect irregardless of the warranty limits.
You might want to contact Sears and express your opinions regarding this matter, and if they'll consider making you whole.
The above paragraph are my thoughts only. They in no way reflect the law, Sears policy or liability or this site's policy.
Dec 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Crafstman garage opener is melting my light bulbs!
Rather than new bulbs I suggest you unplug the unit and use a small screwdriver to pull out on the center contact of the light socket.
Nov 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Same thing
the flickering lights may be caused by a bad bulb
and/or socket, perhaps the bulb needs to be tightened.
get a different fridge!
Sep 19, 2009 | Refrigerators
LG Design defect - Light stayed on and melted the fridge.
yes, contact LG for this known problem. it's a circuit board defect. the tech should replace both bulbs w/lower wattage, plastic bulb lens, lens surround and bulb sockets themselves. be sure to have your fridge model # and serial # handy.
Jul 12, 2009 | LG LFC25760 French Door Refrigerator
My fridge has decided that the light in the top portion is going to stay on all the time. It got so hot that the light cover melted. I've taken out the light bulbs and everything else works fine. The door...
heck you door alignment to be sure when the door closes it is hitting th lite switch and turning the lights off. sometimes it is necessary to put shims on the door hinges to raise the door to cause it to hit the switch properly.
Jul 04, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
HAVE AN LG FRIDGE MODEL LRFC22750. THE LIGHT
EFFECTIVE FROM(SERIAL NO.) from 704MR***** to 801MR***** Subject Lamp Cover Melting Improvement (LG 3D Basic) / 2nd No. Loc No. Before Change After Change Note K-Code Remark Part No DESC./SPEC. Part No DESC./SPEC. 1 501A 6871JK1011A PCB Assembly,Main /
6871JK1011D PCB Assembly,Main /
WINNER1 DISPENSER ENERGY STAR '08 C 3 Change Relay SPEC. 2 503F 3111JJ1001X Case Assembly,Display /
WINNER1 BASIC BRAND ABQ33905315 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 3 503F ABQ33905304 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 4 409B 6912JK2002C Lamp,Incandescent /
60W 120VAC 0.40A 480LM - WHITE 6912JK2002E Lamp,Incandescent /
C 3 60W to 40W
Jun 12, 2009 | LG 22 Cu. Ft. French Door Refrigerator,...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
465 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Mike
Mike
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
