Question about Philips Televison & Video
Recording with a philips DVDR3480 using dvd+r
I can record on my philips DVDR3480 using dvd+r but they wont play back on any other machine my pc dosnt even recognize a disc is in the tray it plays back on the philips DVDR3480 ok. but that defeats the whole point of it i want to record stuff and watch it in another location. am i doing something wrong what settings if any do i need to change? this is driving me insane please help
My phillips dvdr3480 will not let me record from my camcorder it states writing has failed please help
Posted on Sep 20, 2012
SOURCE:
SOURCE: Discs I have recorded I get the disc can neither be played nor recorder, and it erases what I have already and already watched.
I have the same unit. Similar problem but mine does not erase the disc. It says disc error on almost all dvd that are store bought and kicks them out. Will play almost all of the ones I recorded on it and finalized. I must let a disc in it at all times or door will not open. Lots of bad stuff on the net about this unit. It is a lemon! Mine is out of warranty and sony wants $175 to fix. Saw some blogs where it was serviced 3 times and still not right. Buy a new one before investing in the unit you have as there are many gremlins in it! Sorry I cannot offer specific help but this is where I am at!!
Posted on Mar 11, 2008
pferd
  • 94 Answers
SOURCE: wont play dvds, only cds,
DVD & CD use different wavelengths for the read head. I suspect that the blue laser is out of alignment or otherwise in need of repair.
PhotoCD is a format.
Posted on Jul 22, 2008
SOURCE: Philips DVDR615/69
Take, if good  batteris from the remote controller and recycel the unit, and by a better one. I have the  same problem, recordings will stay on the dvd only a short thime readable and later the disk is empty.
Sorry my english.
Posted on Feb 10, 2009
  • 5 Answers
SOURCE: will not play back disc recorded on this machine
Welcome to the club. My dvdrhd04 is going into the shop tomorrow. I too was overwhelmed with vhs tapes and was excited to transfer them over to dvd...Now I'm unable to watch them. sigh. It was playing the purchases dvd's fine, but recently started stalling and clicking loudly.
I'm too chicken to try the repair myself, so I called on a computer tech to do it for me. I'm going to have him replace the dvd burner, hopefully internally, thus the reason I'm online now, doing a bit of research to hopefully help him out.
I'm not sure what the best type/brand of dvd burner to use, but the ones I've seen so far are relatively inexpensive. They range from 32.00 to 62.00..depending on the type...I even saw a blueray for 152.00, but i'm not sure if it will work in our unit.
Mine started ignoring certain brands of dvd's..then quit reading the ones I recorded...now the door won't open...I think it's time for a new dvd drive. I spent too much money on the unit to trash it, and the hard drive works great, I just can't burn off my favorite shows. I really love the thing so for me it's worth trying to save it....especially after seeing comparible units listing for over 400.00...gotta fix what I have.
I've also heard that the fan isn't big enough and that the heat is what is messing up the burners. I may ask my guy about that tomorrow and see if there is a better fan or if maybe using a laptop cooling pad will help...I'm game. At the moment, I can't remember if there are vents in the bottom. hummmmm. It's just a thought for you. I'm sure you've done a bit of research and seen that many people have had issues with the ilo's and now that the company is no more, we pretty much have to rely on each other for help. Thank goodness for the web.
Try a new dvd drive, & maybe a cooling pad that is not usb powered. hopefully this will help both of us.
Denise
Posted on Jul 18, 2009
  • 16 Answers
SOURCE: Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Posted on Aug 09, 2009
Why does not the philips dvdr3480 record?
I would start with the dvd format used for recording, the simplest being dvd+r and dvd-r. Does the unit play a pre-recorded dvd and/or cd? If not, the laser assembly would be the first suspect. The delay in reading discs can be a sign of a borderline laser. Is your record overwrite function turned on, this overwrites previous material when starting each new recording when using +-rw discs. Verify if a format is required for the type of disc used for recording, page 45. Is the correct country/region selected?
Oct 26, 2017 | Televison & Video
After a Sk to HD upgrade [which should not have affected my DVD recorder], my Philips DVDR3480 will only play pre-recorded DVDs. For files in divx format, even files originally written on the same...
www.p4c.philips.com/files/d/dvdr3480.../dvdr3480_58_pss_aen.pdf
Hi, please find above your user manual and your service manual below/
http://www.fixdevice.com/smanuals/file/38174.html
OK perhaps you may need to now upgrade the firmware or re-set up the player again using the service mode, please find all this info in these manual above. It may just be co-incidental, or perhaps your laser assembly is going faulty. Often though, it has to do with CODECs not being installed. or activated, you need to check your manuals for information.
I would wonder if the swap out, hasn't reset all your playback settings? Or the Brain, is thinking it is a differing unit now? and setting it up again may just fix your problem. Anyway please use the service and repair manual's troubleshooting procedures you should be able to isolate and hopefully repair your unit.
Jun 21, 2010 | Philips DVP5140 DVD Player
I can record on my phillips DVDR3480 but the recorded dvd wont play on any other machine what am I doing wrong?
is the dvd a + or - type + plays all - does only region type and - is a special type...
Dec 10, 2009 | Televison & Video
Recorded discs wont play on an other dvd player
you have to finalise the disc when finished recording then it plays on any dvd player
Feb 15, 2009 | Philips DVDR3380/05 DVD Recorder
Recording from my v-box to phillips dvdr3480
our dvd writer does not detect in device manager ?
Jan 28, 2009 | Philips Phillips 16X External DVD 2XRW...
Wont read dvd+r
This is a pretty generic problem with dvd recording on combos. The problem is that after you record to the dvd there is a procedure that is on your menu using your remote to finalize the recording so that it can be read on different players. Otherwise it can only be read on the one you recorded on. Go through your remote control menu options after the recording and look for the option that indicates finalize recording.
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD recording
WH Smiths DVD+RW discs don't work on this machine
Dec 21, 2008 | Philips Televison & Video
Philips DVDR615/69
Sorry my english.
Sep 26, 2008 | Philips DVDR615 DVD Player
Recording to Dvd-rw
yes u hav eto use dvd +r disk ok try that 1st please thx nick
Feb 04, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Philips dvd player 616k
have you tried to record in sp then playback on same machine if this works then your drum for recording in lp or if yours has ep mode may need replacing as pre recordings are ok you need to get it serviced. hope this goes well
May 25, 2007 | Philips DVP642 DVD Player
Televison & Video Logo
204 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
