Question about GE Cooktops
Large eye thermostat is not working. Heat stays
Large eye thermostat is not working. Heat stays high. Are they replaceable?
    President:
  • 704 Answers
Hello JBlum, Yes, most stove top elements, including those with the thermo sensors, are replaceable. Without the model number, I can't steer you towards the exact part number, but you can look it up yourself at www.searspartsdirect.com
Just enter in the full model number of your GE range and it will bring up all the line drawings and parts lists for it. You can either order the parts from Sears, or use any other supplier you wish.
Just remember to disconnect the range from the wall outlet before you undertake any repairs or attempt to replace any parts, so you'll be safe.
Hope you find this Very Helpful and best regards!
Posted on Dec 10, 2009
My Schott Ceran cooktop will only work on full heat and will not simmer at all. why?
usually there are 2 elements a smal and a large the small one possibly burnt out .
Apr 20, 2015 | Whirlpool 30" Schott Ceran Surface...
We have a dcs 48 inch range/oven and the main oven does not heat. The broiler does and the small side oven heats. Any advice?
You don't say if it lights up! If it lights up and stays on low it's the thermostat that's at fault, they are not adjustable and will need to be replaced.
Mar 09, 2014 | DCS 48 in. CP486GDSS / CP486GDSSL /...
My cooktops eye stopped working
Is the oven not working as well? If it isn't working check your breaker for that appliance.
Oct 06, 2012 | Frigidaire FEC36S6EB
I have a Chef Ceran Cooktop Model EHC64oU with four elements. The problem is that it doesn't seem to cook anything on a low heat. It stays on low for a few minutes and then the the temperature increases...
I am assuming having looked up the model that you have a glass top range. These ranges use a thermostat to regulate cooking temperature, and when they go bad you will either suffer from erratic cooking temperature or have no heat at all. The best solution I can think of is to replace that thermostat.
Aug 05, 2010 | Cooktops
Coil element on kitchen aid model ker1201 slow to
some of the coiled eyes have two coils(elements). one of the coils can burn into at any point around the element rendering it useless while the other can still work. when you lift the glass top you will see the elements are shaped like springs. the elements metal is very britlle.it is you have to replace the entire eye to fix it. the coil most likely had a very gap in the break and acted like a short making and breaking connection until the gap was too wide then nothing. easy fix. just replace the entire eye (power UNPLUGGED!!!) match the old wires with the new part as you take the old part off. I mark them even with a sharpie. it has 3 to 5 wires on that plug into the eye unit. estimated cost for the part online is about 40 to 65 bucks.
Jun 07, 2009 | KitchenAid 30 in. KECC506R Electric...
Light sill not go off, and eye stays very hot. Must cut off at breaker
Hi, You will need to change the switch for that eye. If you give me the model#, I can help you with part#.
THanks
Vic
May 15, 2009 | Cooktops
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Only high setting works on burner
Sounds like the Switch or the element are bad, try trouble shooting them. It's a stove top??
Eddie Rentas
Tupper LAke NY
Jul 17, 2008 | GE 30 in. JP340 Electric Cooktop
Kenmore Electric Counter Unit 43421
You are right it is the infinate heat control. This has no thermostat. It works by letting the burner cycle on for longer periods of time on the higher settings on high it is on constantly. The contacts are probably fused inside This part shouldn't be more than $25.
May 27, 2008 | Kenmore 30 in.44062 / 44069 / 44064...
Frigidaire glass cooktop
first try putting pans on top and see what they do you should not operate these type of eyes with nothing on them as you will burn out the sensors in the eyes if nothing is there to reflect the heat back to them if it does the same thing with pans on them then you will have to replace the elements
Feb 11, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
Cooktops Logo
Top GE Cooktops Experts
Marvin
Marvin
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
