Question about Samsung Jet S8000 Cell Phone
Blue hue or color on screen of samsung jet
My samsung jet is having a blue colour over the actual screen
I have a sceptreflat screen hdtv that display a red picture Always
go into settings and check your hue settings.
This setting controls your color mix ratio
of primary colors red, blue and yellow.
Apr 22, 2017 | Televison & Video
Colour prints coming out with a lilac hue
check whether the printer is in proper mode or not
Feb 29, 2008 | Epson Stylus Photo 950 InkJet Printer
What is the perfect amount of red,blue,and yellow hue for the screen
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Mar 29, 2016 | Element Electronics FLX3210 32 in. LCD TV
There is too much blue on the screen & not enough green coloring
Have a very close look at the blue and see if it's perfectly uniform across the whole screen.
If it is then altering the hue or colour temperature settings in the menu may help.
If it's not then either there are heaps of pixel failures (appearing as small rectangular spots) or degradation of the polarisers (green may be affected more than the others).
If you show the menu, do the white areas appear bluish.
If the lamp is very old then colour changes start to happen.
Jun 23, 2011 | Canon Office Equipment & Supplies
Problem with the Toshiba 50H13 50 in. Rear Projection Television. Green tint
The tubes have aged and the colour balance between the tubes has shifted. You will need to redo it using a black/white test image: first the black (the cutoff point), then the white (the gain) on each tube - always start with the green colour. This is done on the final video amplifier of each tube by adjusting the corresponding semiadjustable resistors.
Jun 02, 2011 | Toshiba Televison & Video
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
Feb 06, 2011 | Samsung Televison & Video
Blue hue on right side screen
Try changing your vga/dvi cable,or it could be colour decay.
May 07, 2010 | Panasonic PT-AE700U Multimedia Projector
My Samsung HLR5064W just started to make a grinding/rubbing sound. The colour/picture immediately became distorted. Colour is now incorrect with green and red the dominent hue.
Bad Color Wheel call Encompass for part 1-800-638-3328 Heres another Tip these TVs have high failure rate on Light Engine, DMD Board. For Light Engine Call UED 1-800-648-6657
Sep 28, 2009 | Samsung HLR5064W DLP Projection TV
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Samsung Jet S8000  Cell Phone Logo
174 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
