Question about Samsung Eternity Cell Phone
My touchscreen won't respond at all. I've rebooted it a few times and it just stays on the security password screen. I can ''lock'' the phone using the shoulder button and the hangup/call button but i can't dial in my code using the touchscreen... what to do what to do? anyone know a solution to this beside having to call ATT to get this replaced?
My touch screen isn't working
Brother 8200 8500 8500d screen ..just found this on youtube not sure if this will help you out
Dec 03, 2016 | Brother Sewing Machines
Changing passwords on a used D 307.
Try this:
1. Reset to original factory setting by typing *2767*3855#, youre phone will reboot
2. Then insert a sim card that is from another network that your phone is not locked to.
3. An Wrong sim message will come up on the screen
4. When message appears type in* #9998*3323#
5. At this time a white screen will appear which says “exit”
6. Tap the rigth soft key, (occasionally it will not go to the next screen, if so press the down key)
7. From the menu that appears scroll down to the malloc Fail option, this will reboot, and normal service screen will appear.
8. Then type *0141# and press the green call key, Personalized will appear on the screen, and the name of the current sim card provider will appear on the screen.
9. Turn phone off, and then turn on
10. Go to menu by tapping left soft key, then settings in bottom right hand corner, then choose option number 7 security, then choose option number 6 Sim Lock, select option 1 disable
11. Then enter 00000000 (eight zeros), the message will come up sim lock disabled with a check mark, your phone is now unlocked to use with other carriers.
Dec 24, 2007 | Cell Phones
Touchscreen not responding on Alcatel 4015t
seems like the phone is locked in restricted sight mode.
Feb 26, 2015 | Alcatel Cell Phones
How to work my touch screen on my jelly bean 4.1 10in
Android 4.1 (Jelly Bean) your device now has several different lock options available.
To access your lock options, touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> > > Security & Screen Lock.
Screen Lock Options
  • Slide - provides no protection, but lets you get to the Home screen quickly, or open Camera and start taking pictures immediately.
  • Face Unlock - lets you unlock your phone by looking at it. This is the least secure lock option.
  • Pattern - lets you draw a simple pattern with your finger to unlock the phone. This is slightly more secure than Face Unlock.
  • PIN - requires four or more numbers. Longer PINs tend to be more secure.
  • Password - requires four or more letters or numbers. This is the most secure option, as long as you create a strong password.
The Lock Screen on Android 4.1 (Jelly Bean) uses two timers. The first timer is the "Sleep" timer which turns off the device display to extend battery life. You can turn the display on and swipe to unlock. The second timer called the "Automatic lock" timer turns on security features like pin, pattern, password or face unlock and protects the device from unknown users. This"Automatic lock" timer begins after the "Sleep" timer expires and you will be asked to enter personally recognizable data like pin, pattern, password or the face unlock when the display is powered on.
Note: The Automatic lock option will only show after a screen lock option (other than Slide) has been set.
To adjust the "Automatically lock" timer go to Settings > Security & Screen Lock > Automatically lock > Select desired time frame.
To adjust the "Sleep" setting go to Settings > Display > Sleep > Select desired time frame
If you are using facial recognition and do not want the "slide to unlock" to appear, set the "Automatic lock" timer to "5 seconds".
Power button instantly locks
There is an option in Android 4.1 (Jelly Bean) which will automatically lock the device when the display is on and the power button is pressed. As soon as the power button is pressed your device will lock.
Note: The Power button instantly locks option will only show after a screen lock option (other than Slide) has been set.
To activate the "Power button instantly locks" setting, go to Settings > Security & Screen Lock > check the Power button instantly locks checkbox.
It is important to note your phone may contain security policies set by your IT administrator which may override any settings you attempt to set under screen security. For example, if you set your phone to automatically lock for 30 minutes and phone locks after 10 minutes, it may be due to security policies set by your IT Administrator. Please contact your IT Admin for more information.
For more information on using your new lock features select one of the quick links below:
Lock and unlock basics
Set screen lock
Respond to incoming calls
Face unlock is grayed out
To unlock the screen, press the Power key, then touch [img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics06.png">and flick to .
[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/spdrics01.png">
To add a message to the lock screen:
1. From the home screen, touch Menu [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/JB/razr-menu.png" width="34" height="23">>
2. Touch Security & Screen Lock > Owner info and type your message.
Set screen lock
Depending how you use your phone, you may want to set some form of automatic screen lock to prevent unauthorized access. If a screen lock has been set, the screen locks when your phone's display goes to sleep. It is important to note your phone may contain security policies set by your IT administrator which may override any setting you attempt to set under screen security
Before setting a screen lock it is important to note that you will need your Gmail / Google Account credentials to reset any security lock, so please do not set a security lock on your device without first setting up a valid Gmail/Google Account you can remember and access.
To adjust your phone's lock settings:
1. From the Home screen touch Apps [img border="0" alt="Image" src="https://motorola-global-portal.custhelp.com/euf/assets/images/faqs/ICS/spdrjpn13.png"> >
2. Touch Security & Screen Lock > Screen lock.
3. Touch the type of lock you want and follow the onscreen instructions.
If you have previously set a lock, you must enter the pattern, PIN, or password to unlock the lock settings.
4. You can choose among these lock options, listed in approximate order of strength: Slide, Face Unlock, Pattern, Pin, and Password
After you set a lock here, a lock screen displays whenever your screen wakes up, requesting the pattern, PIN, or other specified key
Respond to incoming Calls
While the screen is locked, you can respond to incoming calls in three ways.
  1. To answer a call, touch[img border="0" alt="Image" src="https://motorola-global-eng.custhelp.com/rnt/rnw/img/enduser/icsphoneicon.png">and flick to .
  2. and flick to .
  3. and flick to . Select a message to immediately send it.
    Tip: To silence an incoming call alert, press the Power key or the volume keys.
Face unlock may be grayed out due to security policies set by your IT administrator which may override any setting you attempt to set under screen security. Contact your IT admin for more information.
Was this answer helpful?
YesNo
Sep 13, 2013 | Computers & Internet
I have a phone and it has been working for a very long time perfectly. The only issue is it got a little bit wet. I've accidentally let it get wet a few times, but it has never had any issues. This...
You need to try Silica Gel Packets. There was a good article on associatedcontent.com that explains how to dry an iPod, MP3 player, cell phones, or any electronics. You need to place your phone in a zip lock bag with Silica Gel Packets. Silica Gel will remove all the moisture from the phone and its components, something air drying will not do!
Just Google "Silica Gel Packets" and you will find several companies selling these products. There is also a web site called: http://www.SilicaGelPackets.com that has them.
Sources:
http://www.associatedcontent.com/article/1060656/how_to_dry_out_your_ipod.html?cat=59
Jun 12, 2011 | LG Vu CU920 Cellular Phone
My Samsung Pixon screen freezes quite often & just doesnt respond. After a few minutes it work again. This happens frequently. This seem to be a common problem with this model. Can someone give a...
The problem is a faulty contact from the touchscreen leading to the phone board. To be short: on the right side of the phone were the volume buttons are, under the touchscreen is the screen's contact. Try "detaching the screens face a little from the phone body exactly at the volume down button(using ur fingernail or something) and see if the touchscreen is responding in anyway. IF this is your case too...I suggest get a screw-driver and open the chassis, and trying to make the connection permanent, somehow.PS: you can send it back to warranty of a repair phone shop, only to force you to buy a new touchscreen and pay for the repairs, on a 99% working phone, with a faulty contact. The choice is yours:)
Good luck
Dec 21, 2010 | Samsung M8800 Pixon - Unlocked QuadBand...
Screen works but dosent respond to any touching?
Check that the "touch screen lock" is not engaged. To avoid accidental activation of the touchscreen, many models use some kind of "security" so that after a fixed time, the touchscreen will stop responding unless you (e.g.) click an unlock button. Verify this on the user manual.
Nov 05, 2009 | Samsung Instinct Cell Phone
My MC70 work symbol wont respond to my touch screen pen
Does it respond to keyboard entry? If not, check to see if the "lock" icon on the screen is in the locked position. It's real easy to accidentially lock the device. If it is, just click on the lock and confirm that you want to unlock.
The next few can be a problem if the screen is not responding, so you'll need to figure out the keyboard equivalent:
You may also want to check the system settings. I believe there is a setting that will enable you to "turn off" the touch screen function.
Finally, try a touchscreen alignment in the system settings.
Jan 17, 2009 | Symbol MC70
Touch Screen
Hi Blu,
A friend had a similar problem, with the touchscreen not responding at all. I read somewhere on the internet that if you press the four corners of the screen very hard with your thumbs it may come back. I tried it...and it worked!
Phiv.
Jun 25, 2008 | HTC Touch P3450 Smartphone
Samsung Eternity  Cell Phone Logo
147 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
