The HP2200 printer will not pick up the paper from the tray or the bypass. It goes thru all the motions but does feed the paper.
  • 10,515 Answers
There is Already a solution Offered By HP. It is :-
Follow these steps to check the condition of the printer and the paper and to resolve the paper feed issue.
  1. Make sure there is paper loaded in the tray. Fan the paper before loading.
  2. Look for paper jammed in the printer.
  3. Adjust the paper guides to the correct markings in the tray for the paper size you are loading. The guides should be snug, but not tight, against the stack.
  4. Make sure the printer supports the paper in use.
  5. Make sure there is only one type of paper in each tray.
  6. Make sure the tray is inserted correctly.
  7. Uncurl any curled paper by bending it in the direction opposite the curl.
  8. When using thin special paper, completely fill the tray (the printer picks up some paper more easily when the tray is full). If you have a small quantity of the special paper, place other paper of the same size under the special paper to fill the tray.
  9. When using thick special paper (such as brochure paper), load paper from 25% to 75% of the tray's capacity. If you have a small quantity of the special paper, place other paper of the same size under the special paper so the stack height is within this range.
If Problem Persists, you need to Call HP to get Repair Quote.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 18, 2009
HP designjet 130NR won't pick up paper from the tray.
paper tray lift clutch failure is likely the cause - common for this machine - repair with new feeder assy ordered whole from HP/ or Partsurfer
Jan 28, 2014 | HP DesignJet 130NR InkJet Printer
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
Paper feed does not pick up properly
Clean the tray paper feed roller rubber,or try using the bypass tray(manual alimentation).
Apr 22, 2013 | Samsung SCX-4521 All-In-One Laser Printer
Di2010
C0960
Manual Bypass Paper-Lifting Failure
The Manual Feed Tray Lift-Up Sensor (PC29) is
not blocked or unblocked even after the set period
of time has elapsed after the Manual Paper Feed
Pick-Up Solenoid (SL3) is energized after the manual
feed paper take-up operation has begun.
Check the bypass tray for obstructions and damage.
Jan 23, 2013 | Konica Minolta Office Equipment & Supplies
Cannnot copy a double sided document to cardstock
This is normal. The cardstock is fed from the manual feed or bypass tray and when selected the duplex option goes away. Many manufacturers do this....meaning they do not allow duplexing from the bypass tray. For the same reason they do limit automatic duplexing to standard or near standard papers. Cardstock is specifically excluded from duplexing obviously due to it's thick nature and when duplexing the paper has to be turned over and go thru paper paths that are not suitable for thick paper. If you must make a 2 sided copy using cardstock you will have to run the sheet thru the machine 2 times, also known as manual duplex.
Hope this helps.
Apr 12, 2010 | Copystar - CS-3035 Printer
Will not pick up paper from tray. Red light blinks indicating a paper jam. Prints fine if single sheet thru bypass slot.
Not picking up paper indicates either a worn nip roller (rubber on feed spindle) or you have a broken gear in the feed mechanism.
Aug 14, 2009 | Brother HL-2040 Laser Printer
Xerox 7132 noise when picking up paper from bypass
there is either paper stuck around a roller (3) that feeds the paper or you have a bad clutch, most mnfs use magnetic clutches at the rear of the machine or bypass that get a red rusty dust in them causing squeal. recommend xerox takes a look...sorry they are quite expensive hourly
Aug 04, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Paper feed
Check tray 1 there should be an arm hanging down in the center of the tray the arm goes thru a slot in the metal plate. This arm moves when you install paper in tray 1. If the arm is missing or not in the slot the machine will think paper is in tray 1 and try to feed from tray 1. You can try changing the paper size setting for tray one to something other than the size in tray 2.
For example If tray 2 is set for 8.5x11 set tray 1 for legal.
The machine should then pull the correct size based on the print job.
Hope this helps
Jan 21, 2009 | HP LaserJet 5si Printer
Pagepro 1350 will not feed paper
I have the same printer and had the same problem.
Cleaned takeup roller wit isopropyl and it has worked now for 18 months. If you dont use it often, remove top sheet from stack and blow the dust off it before printing.
Nov 14, 2008 | Konica Minolta PagePro 1350W Laser Printer
Can not copy from tray/drawer, but get copy from multi-bypass tray
Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
Jun 25, 2008 | Sharp AL 1631 Copier
48 people viewed this question
k24674
jasbo
jasbo
