Question about Sanyo EasyStreet NVM-4370 Car GPS Receiver
Will not load maps from sd card - Sanyo EasyStreet NVM-4370 Car GPS Receiver
    Problem Solver:
  • 4 Answers
I actually bought a cheaper gps before buying this sanyo product. This sanyo is garbage sold at a high price cut your loss move on and try not to stress over these money mongers they don't care!!!!!
Posted on Dec 12, 2009
SOURCE:
Need to know how i update the maps card for it
The latest version of Garmin Express provides the ability to install a map update directly to an SD card.
The SD card installation option will only appear when updating a compatible device that does not have sufficient internal memory for the largest allowable map region. When using the SD card installation option, critical files are loaded to the SD card so it must remain in the device after the update to ensure full functionality. For the largest size SD card a device can use, refer to: What is the largest size Secure Digital (SD) card that an automotive device can accept?
The SD card support during the map update will only function with up-to-date software. It may be necessary to update the device's software with Garmin Express prior to updating the maps. These devices do not support the SD card option:
  • Nissan 700
  • nuvi 295
  • nuvi 300 series
  • nuvi 500 series
  • nuvi 600 series
  • nuvi 800 series
  • nuvi 805 series
  • nuvi 5000
  • StreetPilot series
  • zumo 450
  • zumo 550
  • zumo 665
For devices that do not support using the SD card with the map update application, any maps that do not fit in the internal memory can be installed to the SD card manually, using these instructions:
Try the link.it may help.Under support.
Garmin United States Home
Nov 09, 2015 | GPS
Garmin nuvi 200 SD card
Did you rename the file extensions? On the unit, the map file and map unlock file must be named gmapprom.img and gmapprom.unl
On the SD card they must be named gmapsupp.img and gmapsupp.unl.
Also copy your garmindevice.xml file over to the SD card too.
Feb 26, 2013 | Garmin nuvi 200W GPS Receiver
I cannot locate topo maps loaded via sd card
If you have the TOPO maps loaded to an SD card and the card is inserted all you should have to do is go to Tools > Settings > Map > Info in this menu you will find your map sets if you see TOPO make sure it is activated if not you may need to re install them to the SD.
Hope this helps!
Feb 12, 2011 | Garmin nuvi 1490T GPS Receiver
APPLICATION INTELLNAV.EXE HAS PERFORMED AN ILLEGAL
Was the SD map card specifically designed for your GPS model number?
You'll want to double check since map cards are not universal. Even if you load updated IntelliNav maps onto an SD card, it usually just crashes.
Sep 23, 2009 | Nextar X3-03 Car GPS Receiver
Maps on SD card not recognized by Garmin C330 GPS
I dont thinki the 330 handles 4Gb SD cards I think 2Gb is the maximum that is why it isd taking so long and runds out of space so cannot properly load the maps.
Jul 22, 2009 | Garmin StreetPilot C330 GPS Receiver
I cannot access any of the maps I loaded onto my SD card
First of all, the maps must be created and match the serial number of the GPS you will run it on. Next the maps must be transferred to the SD card in the directory /MAP_DATA The GPS always looks at this directory for any map.
Apr 11, 2009 | Magellan Triton 1500 GPS Receiver
Add Europe sd card to Garmin 660
No. When you plug in the SD card, the Nuvi will load the map from your SD card. Once you get to the main menu, select the wrench symbol, then the map symbol and then "map info". You should see both the US and Europe map. Make sure the Europe map is checked. You can uncheck the US map. This is how you switch between maps. The reason why you have to have the extra map on the SD card is because the Nuvi can only have one map on it's internal drive, one at a time.
However, backing up your US map is a good idea.
Good luck,
- Jim
Nov 21, 2008 | Garmin Nuvi 660 GPS Receiver
Cannot load maps onto micro SD card.
Yust go to www.mapwel.biz/down.htm get software MapUpload and now you can upload any map to micro sd card without loosing your existing map.
Feb 17, 2008 | Garmin eTrex Vista GPS Receiver
Map loading from SD card
Yes go to the Lowrance web site and down load the fix to a sd card , put the sd card in the i finder and it will update it automaticlly. I have not done it for map create 7.0 but have for map create 6.3. On the web site look under suport or downloads and you should find it. There is also a lot of free lake maps that you can download to sd card also. Good luck
budman630
Feb 11, 2008 | Lowrance iFinder GPS Receiver
Garmin Streetpilot i3 GPS cannot load map to memory card
The Garmin C340 comes preloaded with maps while the I3 require that the maps be installed onto a micro sd card.
You can place the micro SD card into a SD adapter and use a regular card reader to download your maps. When the software ask for 'Device' to download to use the drop down arrow and find your drive letter associated with the card reader. Using a card reader will be much faster since the it is ubs 2.0 vs ubs 1.1
You could also go to Garmin website and download and install the USB drivers, see link below.
http://www8.garmin.com/support/agree.jsp?id=591
Dec 27, 2007 | Garmin StreetPilot c340 GPS Receiver
Sanyo EasyStreet NVM-4370 Car GPS Receiver Logo
182 people viewed this question
Top Sanyo GPS Experts
Rochell Cruz
Andrew Taylor
Andrew Taylor
Are you a Sanyo GPS Expert? Answer questions, earn points and help others
